Story goes......I found an old P180 case Ive had for yonks! and after successfully getting my first WC'ing main system up and running decided to build an OLD skool pc build using all my old parts I have collected with some new shiny gear too what I have already- ANTEC P180 AMD Opteron 165 DFI Lanparty DR SLI - 939 OCZ Plat DDR2 2gig XClio 600 Ive started stripping the case down
+1 Memory controllers in the 939 CPUs only ever supported regular DDR This pretty much wrecks your budget unless if you have DDR RAM lying around.. Performance DDR RAM isn't easy to find anymore, and replacing the mobo and CPU would suck.
Where is the love guys? @bulldog for the last 4 years I've been working on my dastardly plans for global domination. R.L Thou I got married and fathered two children but that doesn't sound half as interesting, does it? And sorry for my noobish blunder it is indeed single ch ddr ocz RAM I am at present selling my ddr2 ocz kits BOT I had some ideas for an industrial looking case black mesh with yellow and Orange fans lights and water features
GEAR SO FAR! i have a load of unused PSU's... My Shiny opty will live again... load of fans and a couple of rads spare My DFI Lanparty NF4 SLi DR and yes its DDR not DDR2 How shakey are my hands its either the bad liver function or the minus four temps
Yes!!! I decided on another TRON inspired case!!! watched TRON:Legacy (Wednesday just gone) I liked it A LOT! My Project is gonna be based on the evil character CLU.... got some rough ideas and artwork in png format what do you guys suggest using for a first time user in 3d rendering software???
For first time 3d model/render I would use google sketchup and kerkethea to get started. For Design I guess its going to be black with orange or yellow. Might be useful do some research for the kind of look you want for your case. Trons visuals seem to be largely based on dark background with strips of light here is a quick google for inspiration. http://www.bit-tech.net/modding/2008/12/16/chiaroscuro-by-nick-falzone/
Tron was the first thing that came to mind when I read Project: CLU, haha. Wonder how it's gonna turn out.
In the original Stargate movie Sha'uri says "It is better to die on your feet than live on your knees". I have the audio CD and the script. Good quote.
Thats so f.funny I'm beat posting my own images!?!?! By infekted_one at 2010-12-24 By infekted_one at 2010-12-24 By infekted_one at 2010-12-24 By infekted_one at 2010-12-24 By infekted_one at 2010-12-24 any thoughts?
I like the idea of the fans running up the front, have you considered either moving the drive up the top or putting it down the bottom. Maybe to keep it even cleaner using a slot loading drive, making it look even sleeker? Keep up the good work, liking the shape of the window!
I have been undecided about the optical drive all together TBH I might revise the plan so far is a front and top mounted dual rads dual loop and the xigamtek hdd caddy mounted up front???
By infekted_one at 2011-01-07 Ive just found this hidden away is it any good?? i guess it must be 939?
