Project Clydesdale
Discussion in 'Project Logs' started by RonnySteele78, 1 Oct 2003.
  1. RonnySteele78
    RonnySteele78 What's a Dremel?
    25 Sep 2003
    So there's an old Antec case sitting below my desk. So it's got a window, a
    custom paintjob, and lotsa fancy lights, bells and whistles. All done by
    hand, nothing pre-modded about it all. But..it's getting old. And it's loud.
    Too loud.
    So I wanted something...different. Something nice'n quiet. Something with a
    bit of style. That's how Project Clydesdale was born. Why 'Clydesdale'?
    Well..it's my workhorse. Good for everything, and online 24/7. Next door
    there's also 'Pony', the family PC.
    But..back to Clydesdale. Actually I wanted to go for a watercooled setup
    first.. but then I've remembered that occassionally I'm dragging my box
    to the one or other LAN. And watercooling and transportable don't mix.
    Not as well as aircooling and transportable do, anyway.
    Hence it's gonna be an aircooled setup.
    The next decision was, whether to go with the common 'window+blowhole'
    theme seen everywhere nowadays. Everybody seems to have a window. Hmmm.
    I decided against it. I've done windows before..but somehow I don't like
    them much. I want a clean setup. And I want it nicely soundproofed
    from the insides. Noiseblocker mats kinda look silly when stuck to the
    inside of yer window. <g>
    Next up: What case am I actually gonna pick for my little project?
    It HAD to be aluminium. Simply because I like the looks of it. And it
    had to come..well...pure. No window. No blowholes. No icky front door.
    I hate those front doors. All the time they're in the way. Or -even worse-
    yer case looks absolutely icky behind the door. Do I have to say Xaser? <g>
    Well... my 'victim' of choice was standard Lian-Li PC60. I know it's been
    done over and over, and the case isn't anything 'fancy' anymore, with
    all the other aluminium cases that have popped up all over the place nowadays.
    But I like it. It's got clear, defined lines, a very clean look. It's
    so nicely simple and basic. Perfect for hacking it up for modding. :>
    Well.. Two days after coming to that decision, the case was delivered.
    Feels funny when ya first get yer hands on an aluminium case. The parcel
    service guy was worried if there's anything inside that big box he
    was delivering, at all.
    Half an hour later I was busily working on that shiny new lian-li already.
    Hmm..two fan intakes? A blowhole on top? And one at the back? I didn't
    need those. One of the front holes got closed neatly. Scrap aluminium's
    easier to work with than I thought.
    (800x600 pic here)
    The rear blowhole got closed too. I'll install a powersupply with a big 12cm
    fan later, and an 8cm intake fan to cool the harddrives. That's gotta be enough.
    (800x600 pic here)
    About the blowhole on top I had to do something special. Looks icky to
    have that grill there... Especially if there's not gonna be any fan behind.
    Well, the box was going to be named Clydesdale. So why not go with a horsey
    theme too. <g>
    (800x600 pic here)
    Next up: Some sturdy grips to haul the thing around on. At the local
    hardware store I got two reeeeeal nice steel handles. Chromed, of course.
    $6 a piece, and looking nicely industrial.
    (800x600 pic here)
    Now..let's take a peek into the case. To my horror I had to discover
    this vertical harddrive rack Lian-Li designed for their cases. Icky.
    First of all it's taking away a lot of space. Second, it makes soundproofing
    the bottom of the case difficult, with all the corners and angles.
    Third, I don't want to mount my drives vertically. Nope. Not gonna
    happen. Fourth, should I later really decide to switch to a watercooling
    setup, that rack would get in the way. Therefor it was brutally torn
    from it's home. Hah. Garrr! Instead, I'm gonna use a pair of mounting
    plates. Standard lian-li accessoires.
    (800x600 pic here)
    The mobo tray fell victim to my modding madness, next. I like to have
    a couple holes there, for cables. Routing them behind the tray provides
    valuable airflow space. Six Dremel cutting-wheels later the tray looked
    like this. Yup, I gotta clean the darn thing. Fingerprints everywhere. <g>
    (800x600 pic here)
    And then I came across the first severe design flaw of my new lian-li.
    The front-usb terminal. They could at least have put a spring into it,
    to keep it closed. For now, a small magnet and some spare iron scrap
    do the job, for me. Yup, I'm cheap. But it works, no?
    (800x600 pic here)
    Since we're working at the front bezel already... just why did Lian-Li
    seperate the front grill into those two fields? Looks silly. Had to
    be fixed. There.
    (800x600 pic here)
    While working at the front bezel, I also noticed how there's plenty
    of space behind it. Alright, my case's not gonna have a window. But
    there's room for two cold cathodes, and I gotta do something about that.
    First I thought about cutting two vertical lines down along the front
    bezel. But doing that with the Dremel and making it look all clean
    and even would have been a chore. I needed some other idea.
    Gonna go with a different kind of bubble light there. ;) Two blue
    CCs behind the front bezel will provide enough light to make it shine
    nicely.
    (800x600 pic here)
    What was left? Well..for now, the side panels. I wanted to go with
    the clydesdale theme again. Thoroughly cleaned both side panels,
    then cut masking tape and sprayed a nice logo on both sides. Only
    to tear it off again together with the masking tape, later. Chipping
    paint. Arrrrrrgh! What, paint's not gonna stick well on aluminium?
    I'll give ya aluminium! GRRRR! Some hours later there were aluminium
    filings and dust all over my room, and the logo deeply engraved into
    both panels. Now THAT's not gonna come off again. No way! HAH! I've won!
    Gotta llllove my Dremel. :)
    (800x600 pic here)
    So..here's a final impression of the case in its current state.
    (800x600 pic here)
    Now if my hardware vendor finally would deliver the noiseblocker mats
    and blue CCs I ordered TWO WEEKS ago, I could start and write part 2 of my project log soon.
    But till then, that's it for now.
    See ya.
    -Ronny
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Welcome to the forums and enjoy your stay
    I like the horses and etches....
    Dont like the cheese-like holes in the front/side.
    IMO, would have been better with slit(s).
    But on the whole, looks good.
  3. RonnySteele78
    25 Sep 2003
    Like I said..with the dremel being your only modding tool (apart from a power drill <g>) you gotta resort to..uhh..alternatives. I first wanted to cut two slits instead of the holes, too. But doing that by hand and with cutting wheels, it would have turned out anything but straight and even. The holes look okay though, and looks absolutely great with the right lighting. Tested that already with a spare CC I've got here. Just wait for the final pics. :)
    -Ronny
  4. borumas
    borumas What's a Dremel?
    22 Sep 2003
    I think it looks pretty darn good so far, really like the engraving work you did.
  5. KrazyIvan
    KrazyIvan What's a Dremel?
    18 Oct 2002
    Yeah, I really like the engraving work. What kind of bit did you use to do that? Excuse my ignorance. :worried:
  6. RonnySteele78
    25 Sep 2003
    @KrazyIvan: For the engraving job I used three bits, actually. One's a milling bit. CV- steel, with a small ball at the tip. Looks like an oversized dentist's drill. *shudder* That one was nice for the outlines, and downright dug into the metal sheet. Half a millimeter deeper and I'd prolly have broken though the other side of the panels. <g>
    For cleaning up I used a diamond-dust ballpoint bit. Same size as the milling bit, but makes lots smoother lines. And requires more time to work with. :p
    The insides of the letters were polished with a rubberwheel bit that actually was meant for polishing acrylic glas. Works great on aluminium though. :)
    -Ronny
