Erm... looks like a toaster Dude its pritty cool, and with that big azz LCD would be sweet, but if you want my honest opinion right now it just looks like a shiny new black toaster. Half expecting burnt bread to pop outta the top. Keep modding it man! >>Greg And what the hell IS a dremmal?
you know... thats not a bad idea, you'd never have to get up! hey morphine, i think i figured out a way to coll your PC, put all the heat into a peice of bread!!!
A dremel is a rotary tool. Dremel is actually the name of a company that makes some of the best quality rotary tools, so we just refer to all rotary tools, Dremel brand or not, as dremels. Dremel: Go to your local hardware store and ask them to show you the rotary tools (most likely they won't know what you're talking about if you ask to see a dremel). P.S. It's a common tool of the modder, because it is a cheap tool with a wide variety of attachments that can get many jobs done.
hmmmm, think the toast idea wont work. The liquid cooling might make for some soggy results. Dremmels own, though they are not the best tool for certain jobs. Kinda like the jack of all trades, but specialized tools will still give better results 90% of the time. But I will admit, cutting through thick steel with a dremmel is fun, even if the only reason you are cuttin the steel is just to see the huge rooster tail of sparks itll throw off.
that brings me back... ever turn the lights down low and double dremel it? beautiful... or goose someone with a couple sparks?
hey, does anyone else have access to a plasma cutter? i do! those things heat the metal into the fourth state of matter, plasma! it then blows the white hot plasma with an air compresser. that makes some nice fireworks.
Actually, if the metal did indeed turn into plasma, it would vaporize everything within 100 yards of you!
your school has a cnc. man when i was in school all we got in metal class was a pair of metal snips and a torch JEEVES
at school here we have cnc metal lathes, huge cnc milling machines, small cnc machines for really precise jobs, and just about every other tool you can think of, even a laser cutter
yeah what he said. I want to go to your school for about a month or so, have some things i want to do . JEEVES
its in australia, but the thing is you have to be good friends with the teachers if you want to use the machines for your home projects, and i aint really that good with the teachers
actually, i kinda forgot about the lcd. I'll try my hardest to remeber to finnish it this weekend. I'll at least get it wired and somewhat tested. The thing is, some of the pinout decriptions in the LCD's data sheet differ from the controller board's data sheet, which in turn has one pin labeled differently than the schemetic for the software I'm using. I'll have to hunt down a few people who are slightly more (read: hella ****ing smarter at this lcd biz) educated people in this matter. I have monday off from both high school and work.
yeah, my high school, im in grade 11, im gonna be good this year so next year i should be able to use them for my home projects
