Scratch Build – In Progress Project "Coal Scuttle" picture problem fixed + switch and a fan cont
Discussion in 'Project Logs' started by WolfandAngel, 13 Apr 2009.
  1. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    I'v been wondering why people haven't posted any comments and thougt this was a lame Mod but after wanting to show it to a friend i found out that nobody could see the pictures
    now that every on can see I hope its not lame:worried:
    This is my second mod plz check out my other first on "The Noob"
    Recently I got a Coal Scuttle from school because my teacher was going to throw it out anyway
    As you may have seen the Coal Scuttle is very rusty on the inside and it doesn't have a floor
    It's rusty because it was outside for weeks and the floor rusted through
    If you have looked at my other Mod you can see that I've changed my workspace
    more updates coming tomorrow
    Bad_cancer likes this.
  2. WolfandAngel
    2 Dec 2008
    Projekt "Coal Scuttle" some updates
    My plan
    The Floor
    As you can see there are still some adjustments that have to be made
    Finally got a good reason to get out my tool box or dremel box :confused:
    :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel:
    after hours of work
    nothing can fall out now
    The cardboard is where the itx board is going to go
    I cut off a bit of the aluminum L so that the itx would fit
    the idea
    Had to get a new blade for my buzz saw
    cutting a cover/top
    I normally put the second blade here, so if I switch them, I don't have to look for it
    I hated this part because I wanted it to fit perfectly:wallbash:
    note the left corner:waah::wallbash::waah::wallbash::waah::wallbash::waah:
    finally screwed the frame to the acryl glass floor
    Well the big part of the mod is finished; now i only have to paint it,
    get a itx board , hard drive, psu, switch, fan controller, feet and so on
  3. x_JesusNinja_x
    x_JesusNinja_x What's a Dremel?
    8 Mar 2009
    Good start you have thar!
  4. WolfandAngel
    2 Dec 2008
    painting
    Well I have finally painted the scuttle its really shiny now :D
  5. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    A coal scuttle? Awesome! :clap:
  6. WolfandAngel
    2 Dec 2008
    switch and a fan controller
    Today i got a switch and a fan controller
    me trying to find out what goes where
    The white O will fit to the fan and is going to be hd led
    something a Modder needs to survive:p
    going to exchange the nob with the on in the package
  7. Guest-23315
    Guest-23315 Guest
    Mmmm Pizza :)
  8. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    Mmmm... Modding.........
  9. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    MmmmMMmmm... Coal Scuttle... (hehehe) good job WolfandAngel !! I will keep my eye on this project :)
  10. popotheflyingpanda
    popotheflyingpanda What IS a Dremel?
    20 Nov 2008
    wow this is great, very original and i like the over all look so far!
    keep it up, and good luck getting guts!
  11. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    I really like this idea. this is awesome!
  12. longwing
    longwing What's a Dremel?
    2 Jun 2009
    Good luck fitting the parts into such an unusual shape. It already looks brilliant.
    Are you planning to paint the top panel to match the rest of the scuttle?
  13. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Ah, never saw this before (or a coal scuttle for that matter)
    I love putting pcs in unusual cases! :thumb:
  14. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Me too... ow; thats an idea for a next mod :)
  15. Jipa
    5 Feb 2004
    Took me three attempts before I believed it's not Shuttle, but Scuttle :) Good work, liking the inner frame w/o making nasty mods to the scuttle itself.
  16. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    You, my friend, are bonkers. Possibly in the greatest way ever known to modkind :)
    Great Work!
  17. WolfandAngel
    2 Dec 2008
    First thanks for all your post
    I'm planning to finish it by the end of the summer vication
    but first i whant to finish and start my core i7 mod :dremel:
    not really if ther are enough request I'll paint it but I like it the way its know :naughty:
  18. longwing
    2 Jun 2009
    Well if you like the way it is, you should keep it! I was just curious. It's a brilliant mod either way.
  19. Bad_cancer
    7 Apr 2009
    /\ Agreed this is an awesome idea! i really like it! (although im not sure how much my opinion counts for :hehe: )
