Project: Cold Angel - [Drilling and assembly, have jig saw!] - [Updated 22/9/05]
Discussion in 'Project Logs' started by Kaboom22, 17 Sep 2005.
  1. Kaboom22
    Kaboom22 Minimodder
    8 Sep 2005
    Update 22-9-05
    Fixings had arrived from namrick, so I could begin properly building something that didn’t resemble a mountain of metal. I also got a tap and die holder off eBay for £2 Inc P&P, which will come in handy for when I tap the mounting holes. The die I’ll probably use one day….
    Far left – stainless steel dome head hex head bolts and countersunk version. Top left – loads and loads of matching nylock nuts
    Centre – tap, bottoming tap and drill bit. I’m staying completely metric for all the screws in the case.
    Bottom Right – washers….not much else to be said
    Centre bottom – non-locking nuts for use with semi removable parts (such as the switchback design). Also useful for quickly assembling things for photos :)
    Here’s something for you sketchup fans :) the hinge(s) were bought from B&Q ages ago when I first started getting materials.
    Anyhew, after replacing several of my crappy cheap drill bits with yet more crappy drill bits that aren’t quite so bent, I got to work pilot drilling and making the holes. I forgot to take a pic of my drilling rig, I’ll post one next time. Your not missing anything, it’s hilariously antiquated.
    First to pilot drill
    Then to go through with the correct bit, and then add a nice bevel with a slightly larger bit on the edges.
    Things then naturally start to take shape :)
    Corner…
    …edge…
    …and finally one side section completed of the drive cage. Note that the bottom two pieces of metal aren’t joined on as I didn’t have time (darn spooks, such a good prog)
    So far, so good. Progress is slow, but I’m learning as I go, and being extremely careful as I don’t have any money to buy more materials if I screw something up.
    It all seems to fit
    Stay tuned for next update.
  2. Kaboom22
    Kaboom22 Minimodder
    8 Sep 2005
    Argh the project log changes, and im gong to loose my internet soon :( mods, you have my full permission to make this post compatible with the new rules if you choose, i will try and do it tomorrow before the internet dies.
  3. Kaboom22
    Kaboom22 Minimodder
    8 Sep 2005
  4. Fly
    Fly inter arma silent leges
    31 Aug 2001
    The Internet is going to die?
    :jawdrop:
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARGH!
  5. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Looks nice dude! The sketches is wicked, i'll contact you the next time i'll make a case :D
    Just kidding, but nice work!
  6. Kaboom22
    Kaboom22 Minimodder
    8 Sep 2005
    uhm ty, but can you post in the discussion page next time? This thread needs to be killed. My new log is in my sig.
