Project: Cold rain : Starting all over
Discussion in 'Project Logs' started by AsEeL, 29 Jun 2004.
  1. AsEeL
    AsEeL What's a Dremel?
    27 Aug 2003
    Hi i'm planning to start my mod all over again.
    I'm going to do a lot of stuff so keep tunned ;)
    The start
    First i have to break down the hole wc and hardware
    My first problem...
    Cpu was stuck on the wc blok, i tought i had broken all my pins but the cpu wasn't harmed in any way and works fine.
    I took out the hole wc in his part
    I took all hardware out and all mod stuff
    Then i went downstairs and took the hose.
    I sprayed and washed the hole case
    The result: one shiny case.
    In the meanwhile i putted my hardware in an other case
    Stay tuned i'm planning to make alot of new things
  2. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Hey AsEeL, that's one sweet case you got there. It's pretty darn big (or it just looks that way ;) ).
    Anyway, are you going to be modding some new stuff on that case?
    What are your plans?
  3. AsEeL
    27 Aug 2003
    Well im planning to make a front mod
    I'm going to do a paintjob
    an improved wc
    Cleaner wirreing and stealhting it
    Next step is to take the mobo tray and all the racks from the case.
    Then you will see what i'm up to ;)
  4. RaZoRbLaDe
    RaZoRbLaDe What's a Dremel?
    19 May 2003
    Is that a Lian-Li PC7323A ? I've got that one too and modified it to fit my prom in. Only thing I hate about the case is when you open the door, the front is kinda ugly compared to the rest of the lian's.
    I'll be following this one ;) .
    Good luck neighbour!
  5. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Pro bed sheets
  6. CT-Petzolinni
    CT-Petzolinni What's a Dremel?
    29 Jun 2004
    i will stay tuned, to see what you are going to do with it.
    the cpu problem is nothing harmless.
    I have the same problem in the store.
    The only thing that happend one's was that some of the pins didn't stand up well.
    see you
    keep up the good work.
    chrz
  7. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    that is a crap load of thermal compound!!! :jawdrop: :jawdrop:
  8. Ampora
    Ampora What's a Dremel?
    23 Oct 2003
    we'll
    i'll follow this mod fo sho'w ;)
    :clap:
  9. AsEeL
    27 Aug 2003
    Update 1
    Yesterday evening i cleaned my gpu wc block :p
    Did some work this noon.
    I started to drill out all the rivettes :)
    The result, one nice frame :D
    Before i started
    Lets penetrate this baby :dremel:
    Top's off
    Clean isn't it
    Time to spray with some paint ;)
    Stay tuned for more
  10. y_N_e_M_a
    y_N_e_M_a What's a Dremel?
    16 Mar 2004
    looks like youve got alot of potential there. :dremel:
    i want that case, so much room :jawdrop:
  11. AsEeL
    27 Aug 2003
    Sry guys but i didn't had much time nor a digicam at my disposal.
    Hope this little update starts the fire of disire inside you guys again :)
    Here you see some parts I painted.
    Its only the first cote so the result wil become better after a while.
    In the end the whole case wil be black but not the panels on the site and top.
    This week i'll try to paint everything.
    As you can see i made some cut outs in the motherboard tray.
    This is for the stealthing of the cables.
    The vents below wil be used in the frontmod :)
  12. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    nice work so far
    keep up the good work :D
  13. Rody
    Rody What's a Dremel?
    23 Oct 2003
    Might want to clean the radiator. Its a bit dusty :eek:. But goodwork so far!
  14. saint
    saint What's a Dremel?
    26 Jun 2004
    Is looking good, mod on :dremel:
  15. ReFredzRate
    2 Sep 2002
    So, AsEeL.... Any updates yet? I'm looking forward to some improvements on this 'little' beast! ;)
  16. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    mmmmmm black=sexy keep it up m8 looks very good
  17. KG Silent
    KG Silent What's a Dremel?
    4 Aug 2004
    Looks great, I can't wait to follow it further.
  18. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    That`s what i said. It looks like he used elmers glue to hold that block on his cpu. You only need a razor blade thin layer.
  19. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looking good so far mate
  20. Firehed
    15 Feb 2004
    That's a whole lotta radiator!
    Looks nice though, keep it up. Definately an interesting setup, and I love lian li mods :)
