Scratch Build – In Progress Project; Command & Conquer GDI Base Station
Discussion in 'Project Logs' started by Frenkie, 25 Sep 2008.
  1. WakoNako
    WakoNako What's a Dremel?
    22 Jul 2008
    your 'structure' paint is also known as textured paint. You need to be careful clear coating it though. Nice work on the mod... and the mobo ;)
  2. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    Ahh very good, thanx for the tip !
  3. Frenkie
    3 Jul 2006
    Allready mentioned the containers that this mods uses, but this update covers all the pictures.
    Containers
    Out of polystyreen I made a container, which is used a lot in the game.
    Glued it together with modelling glue.
    Made another 3 of these for the backlot.
    With painterstape I marked the small pieces on the edges.
    Try out with a light behind it.
    Time for some paint. I had to gamble on the color, but this is the best what I found.
    Here the 4 containers are drying after the primer and second coat.
    Added the warning decals one by one, by hand. What a **** job !
    This is how it looks like now.
    Added on one of the containers a small print with 3 leds, that slowly fades in and out.
    Below the warning decals, I did not paint, so the green glow comes through it very lightly.
    I decided that light glow was not enough after all, so I ordered another 100 green ultrabright leds in Hong Kong.
    Desoldered the old ones and attached the new ones.
    It is now a lot brighter. ( sorry my camera doesnt grasp the fade-in-fade-out )
    To enhance the effect, I added 4 blocks of polystyreen, measuring 1.5 x 1.5 milimeter.
    Now the glow shines underneath it better.
    And finaly the effect in a 10 second YouTube movie.
    http://www.youtube.com/watch?v=Q2A56RkKXa0
    ( am I doing the youtube link wrong? )
  4. Frenkie
    3 Jul 2006
    BTW, this is the new base in Red Alert 3. Looks quite different, doesnt it?
  5. Djayness
    Djayness phwupupupup
    7 May 2008
    The level of detail is absolutely stunning, subscribed!
  6. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Looking forward to seeing the boxes with the crane and the whole thing together.
  7. Frenkie
    3 Jul 2006
    Well, I can give you a glimpse of the crane allready. It is not finished yet, but it will give you an idea where we are heading;
    The Crane
    This is how I made the C&C GDI Base crane vehicle. From the ingame screenshote I tried to estimate the length and width, and used polystyreen to replicate it in about the same dimensions as the Recom case.
    The grippers have exactly the same dimensions as the container.
    Close-up of the cabine buildup.
    Made some hinges out of old bolts and nuts.
    Slowly the crane is beginning to take shape.
    Through Marketplace, I found these children's tractor and trailer, cost € 8, -. The wheels of it have the perfect size for the crane.
    Too bad for the children, but those wheels are perfect for my mod.
    From the game....
    ..into polystyrene.
    This shot is just before spraypainting.
    Then the warning decals.
    Started with some small details.
    Like in my Wall-E mod, this whole thing needs to be "aged". Still some work to do. :D
  8. Frenkie
    3 Jul 2006
    From the screenshots I see on both sides of the case some kind of windows.
    I will try to imitate that. First, I purchased some strips of perforated steel and made them to size.
    This is thin aluminum foil which is often used in airconditionings.
    I cut some strips to size.
    Here they are on the case where the windows will be.
    And on top of them, the steel strip that I primed and sprayed.
    And the same two more times for the two sides.
    :D
  9. samkiller42
    25 Apr 2006
    Wow, utterly amazing, The powersupply is a great trick.
    Please, keep the updates comming.
    Sam
  10. turboshifter
    turboshifter What's a Dremel?
    29 Oct 2008
    i love the cold fusion reactor type psu
    what a great idea
  11. jhanlon303
    7 Sep 2006
    I have rolls and rolls of that chrome tape! I got it years ago at a Dollar Geneneral. I used some of it when I insulated and sheetrocked my tackroom.
    Never would have thought of it for a mod.
    Excellent use of available materials. I'm impressed.
    john
  12. Djayness
    7 May 2008
    thats crazy, love the attention to detail here.
  13. Frenkie
    3 Jul 2006
    You did WHAT to your WHAT ? :D
    thanx John.
    This mod is almost done, and still a month to go before the deadline. I can take a break now, and work on my STING project. In two weeks the Dutch Championship is here and I am one of the final 5 in the caseconstruction catagory with my R2-D2 case. I'll let you know what place I will end there. :)
  14. jhanlon303
    7 Sep 2006
    A tackroom is an outbuilding like a garage but not attached to the house, supposed to keep saddles and other "tack" for horses in it. Mine is 12' X 24'. I wired it for electricity and insulated the walls. After you insulate the walls, you can apply a plastic barrier - like a garbage bag but thicker and comes on rolls. The you take the tape and seal all the joints where the plastic comes together. Cut the holes for the electric outlets in the sheetrock drywall and put that up. Everything sealed and a small 1500 watt heater will keep it warm in Denver. Looked really cool with the black plastic and the chrome tape.
    I was being frugal so I used the Dollar store brand.
    john
  15. Frenkie
    3 Jul 2006
    Black and chrome, looks good on casemods, and on tacksheds too ! :D
  16. DuVeL
    DuVeL What's a Dremel?
    4 Apr 2007
    GL & HF Frenkie. The case looks nice so far.
    Got a link for the Dutchsite?
    Mzzls.
  17. Frenkie
    3 Jul 2006
    Thank you and yes, here you can see the other 4 worklogs too from the competition.
    Look for these 5 names there:
    [BMTIP] Ronde 3 - Flythe
    [BMTIP] Ronde 3 - Jeroenotje
    [BMTIP] Ronde 3 – Chatlie
    [BMTIP] Ronde 3 - k_a_lf
    [BMTIP] Ronde 3 - Frenkie
    Around half December the cases should be finished and presented. I'll post my last pictures just before the deadline :)
    Here are my last shots before the finals.
  18. Frenkie
    3 Jul 2006
    These are the final pictures of my entree for the third and final round of the BouwEenPc.nl website modding competition. It turned out to be a bit more then asked for, but what can I say... sue me.
    As the really really last thing, I'm posting here a very irritating movie I made ( hehe ) of the lights which the two vehicles make. This mod is without any PC inside, but it IS totaly prepared for it. This contest was all about the outside, not the inside.
    http://www.youtube.com/watch?v=dddSMnkELeU
    I hope you enjoyed reading this worklog as much as I enjoyed making it.
    I wish the other contestants of this competition the best of luck ( well, not TOO much ofcourse...)
    greetz Frenkie
  19. Guest-23315
    Guest-23315 Guest
    Thats just awesome :D
  20. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    I've found a way to youtube link it- Get the code in the embed section of the youtube page and paste it into the post, then use the advanced editting options to wrap youtube tags around it... like so:
    Hope you don't mind me fixing the videos... I'm just obsessive like that! :lol:
    Frenkie, you are the master at this stuff! Great work, and good luck with the contest. I'm sure you'll do well. :thumb:
