Project Compucase update 02/08
Discussion in 'Project Logs' started by e.c, 1 Aug 2004.
  1. e.c
    e.c What's a Dremel?
    11 Jun 2004
    My Hardware:
    Case: Compucase 6A19
    Motherboard: Asus A7V600
    CPU: AMD 2500
    CPU Cooling: Vantec AeroFlow VA4-C7040 :(
    Memory: OCZ 512MB 3200 Enhanced Latency 2-2-3-6 1T
    Video Card: Asus Radeon V9600XT /TVD
    Hard Disk: Western Digital 120GB 7200 rpm 8MB Buffer SATA
    CD-RW: Lite-On LTR-52327S
    DVD: Toshiba 16/48
    Monitor: LG F700P
    My Case:
    Currently the project would be a window in the case-door(more mods are to come in the future :) ), the window is based on the Web-Sun grill:
    I redrawed the grill (I copied one "flame" from the grill and multiplied the others by necessity). The hole in the middle of the drawing fits for a 80mm fan:
    Printed it on a couple of A4 pages(it was too big to fit in one):
    I put the pages together(overlapping):
    And copied to a A3 page:
    I put some glue on the door, the A3 page came on it. Then I usef glue/tape on it:
    After 2+ hours of work and beating the crap out of 5 cutting-heads I got the result(it's not final ofcourse) :
    I still need to finish the cutting and do some sanding.
    To be continued :)
  2. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Looking good mate, Nice and clean
  3. e.c
    11 Jun 2004
    update! :)
    one last corner and some fixs :)
  4. b!p
    b!p What's a Dremel?
    6 Jul 2004
    We have the same case ;)
    It looks very nice and clean ! Good beginning !
  5. borumas
    borumas What's a Dremel?
    22 Sep 2003
    Nice job on the cutouts, keep up the good work man. :rock:
    PS That's a sweet case, love the 120MM in front and back. :)
  6. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    case looks very nice, i you are doing some nice cutting too
  7. e.c
    11 Jun 2004
    finish to cut :)
    now some sanding :)
  8. khendar
    khendar What's a Dremel?
    25 May 2004
    Nice cut. I was wondering how you were gonna pull that off when you asked about the grill in the Modding thread :D
    Looking good. Keep it up.
    :thumb:
  9. Darth Joules
    Darth Joules Minimodder
    29 Feb 2004
    e.c. in your opinion does using a flexi-shaft (as in your pic) make it easier to cut fine designs than just using the rotary tool by itself? :confused:
    Also how do you drill out the lines in the center so thin without snapping them?
  10. RubberDuck
    RubberDuck What's a Dremel?
    23 Jul 2004
    That Compucase door is one though heavy metal, i guess it took him some time and alot of carefull patiance...(i have the same case..)
    P.S. : the shaft really makes it easy to trace lines(just like using a pencil).
  11. backseatmiddlehump
    backseatmiddlehump What's a Dremel?
    8 Feb 2004
    Impressive dremel work
  12. e.c
    11 Jun 2004
    hmmm
    my dremel get hot really quickly and the flexi-shft not..
    and the dremel is heavy not like the flexi-shaft
    and its really like a pencil
    for your second question
    this metal is hard.. you can cut it even thiner
    p.s
    sorry for my bad english :)
  13. Darth Joules
    29 Feb 2004
    In that case does anybody know if the Draper flexi-shaft will fit a Dremel? I'm not keen on forking out £45.00 for the Dremel version. :sigh: I've just wasted some money on a 12W soldering iron when I should have bought a 25W one. :duh:
    Hey e.c....excellent dremel work!!! :thumb: :thumb: :thumb:
  14. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I'm not seeing any pics at the moment.....
    Sounds like a good project, I just wish I could see it.... :sigh:
