Project: Computer's King " Expensive " 8/12/2006
Discussion in 'Project Logs' started by ComputerKing, 9 Dec 2006.
  1. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    that's the spirit, now show us that this project is worth a way higher rating :thumb:
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    btw comp king, the reason you have patchy colours with the paint is *probably* due to not enough coats of paint. Lots of thinner coats are the way to go that’s for sure. You don't have to key it up each time if you spray the coats every 15 mins or so (probably less in the heat out there).
    I sprayed my case last year and got through a hell of a lot of cans of paint, I think 5 coats of the colour, 2 coats or primer and 2 lacquer did the job, it looks great still so I know it worked.
    One piece of advice is that you should plan everything thoroughly, I like your ideas but you don't always seem to think things through. I'm looking forward to good new pictures, if you can, get a tripod for the camera, even a really cheap one will do, you don't need to spend silly amounts on one :)
    One thing I would really like to see is you taking your time over writing the posts, i‘m sure a lot of people get exasperated because your English is sometimes nonsensical.
    Now, get back in the saddle and show that case who's boss.
  3. Bluefan
    Bluefan test 123
    25 Feb 2005
    Painting takes patience, I screwed it up the first time. I painted only one layer, and even putted the case together before the paint even dried properly. So Messing up just happens.
    Just paint with multiple thin layers, and it's probably good to get a layer of primer to, depending on what you're painting.
    The lighting and the colors are the best when you keep it simple. First, you need a base color, probably black, white, chrome, brushed metal or anodised. Then, you can choose one or two colors that fit that base color. I would take one base color, one filling color and one color for the highlights. My plans are to take brushed aluminium as a base, a blue color for the different components, and small red highlights. But one base color and one other color is problably just as good, and can looks very good. Just look aroud here on the forums, many mods have very few colors, but look great.
    The cuts are a matter of taste, but a good mod can have simple cuts. The cuts don't make a mod, they just add. Also here, look around, many great mods just have a square window. So if you need a window, just choose a simple design, and it will look good.
    The holes don't look that bad to me, but it's just a matter of opinion. Just don't make too much holes, and it will go alright. To begin simple, just make a small amount of simple placed holes in the right place. And mods usually have very few holes, so don't worry too much about this.
    That's what we're here for
    Don't mind the camera too much, focus on the mod.
    I used a dremel clone, a simple saw and a drill. Ok, I screwed my mod, but a giant load off tools doesn't make the mod.
    If you want it sexy and bling bling, consider chrome with red or yellow lights
    Just get one soldering thing, and that is probably most of what you need. And some carefull planning.
    Go for a single nice color. Red or yellow will look good on chome.
    If you spend a lot of money, please do plan carefully, great mods start with planning, and so do the simple ones. And with a decent planning, the mod will be better.
    You mostly need your imagination and a planning to work that out.
    That's the better news, not giving up :thumb:
    It's good to take a good example. You even can try to make something very look-a-like for a start. Just don't dive in too deep too soon :thumb:
  4. Jipa
    5 Feb 2004
    It's not about the tools as much as it's about PATIENCE! Don't rush into things you aren't perfectly sure about. You'll only ruin the case.
    And don't give up, some ppl on these forums do modding for their living! They can put in insane amounts of money and buy any tools necessary. You don't have to compare with them, just make a case YOU are happy with.
  5. ComputerKing
    8 Sep 2006
    OK guys !! that really really help me out !!! now I just have to think again on the plans !!! OK now I think you cleared every thing I want to know , but still some thing what the sand numbers good for sanding that case and make it pure alum !! also I was need a ready print A4 80mm Fan template !! that all I need I was in stores to get the etc for my tools ! but I need to sand that case very dam well so which sands papers !!! :dremel: :dremel: :dremel:
    thanks guys again I will never give up again :D thanks you always pushing me on ! :clap: :clap: :clap: :clap: :clap: :clap:
    thanks , good luck , take and bye :dremel: :dremel: :dremel:
  6. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
  7. ComputerKing
    8 Sep 2006
  8. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    Hes back, hurray! whoo computer king is back, cant wait to see what you do mate. keep up the good work and hope to see more from you soon"
  9. ComputerKing
    8 Sep 2006
    Thank you !! you will see good work soon !!
    Any answer >? :thumb: :thumb:
  10. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    You can use a photo editing software or copy machine or scanner/printer to resize them in any way you want, good luck. Oh, easy on the swearing.
  11. ComputerKing
    8 Sep 2006
    lol ok thank u :D Good luck , Keep going
  12. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I seem to have missed out on the whole discussion.
    But all I can say: glad to see you continue, I want to see how your project turns out. Take your time for it. If you're stuck, take some distance, do something else for a while and the solution will come to you. I've been stuck a couple of times as well. I took more than a year. There are reasons for that:
    1) full-time job
    2) I wasn't that fast with hand-tools, I needed to go through a learning process
    3) (and most important) I thought about everything I was going to do and how best to do it.
    Don't let anyone or anything rush you. If something doesn't work out, look around on the internet or ask it here.
    Just my thoughts...
  13. zhangmaster12
    11 Jun 2006
    download them.
    open them with windows picture displayer thing
    press edit with paint
    go to print, properties, and select fit to page and make sure the print will be 100% of origonal size. if you must, use landscape.
    then press print
  14. ComputerKing
    8 Sep 2006
    OK here some new photos with my new camera !! they fast , Just to see what I mean about things I don't like
    this the inside
    see that , the back ass
    see paint crap , that my problems
    Cutting problems ??
    Paint and plate problems
    Sucrets , Not here only , on the whole case have a lot of them
    some paste crap ??
    that air DVD-rw lol
    Paint crap also ??
    space between the VGA
    cutting and mounting problems ??
    Dudes can any one have solve for this problems or any comments or advise , my work will stop till I get everything perfect !
  15. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    looking fine!Clean up the wires a bit and it should look fine.Just try to get it as clean as possible and paint the other parts black too.
  16. ComputerKing
    8 Sep 2006
    the wire not the problem !! the problem the body and paint ??
  17. Springs
    Springs Boing boing
    29 Aug 2004
    have you tried maybe using body filler to smooth over the bad parts? did u use primer before painting... that can cover up some light stuff... also maybe use some rubber tubing cut down the middle to cover up the "bad" cuts...
  18. mattthegamer463
    26 Nov 2004
    Did you sand the paint? That big drippy spot on the top panel could be fixed with some 400 sandpaper. Sand that spot down and paint it again. Get a file and file the fan holes until they're smooth and round, and bondo those deep gouges and that other messed up spot on the front, and repaint them. Slow down, take your time, and you'll get it right first time. Half of it is preparation. It took me 5 months to paint my case, from primer to colour to clear. Its not a very quick process.
  19. zhangmaster12
    11 Jun 2006
    to get a good paint job, you need LOTS of sanding. check out some other worklogs to see how they sanded. thehourbeforedawn's project is quite informative about sanding
  20. ComputerKing
    8 Sep 2006
    OK Thanks guys ,,, Any more advise !! I used primer !!!
    Guys how many paint sprays I need to pain this whole case ( primer and blue and black and clear )
    can you guys give me the sands numbers that I need to get to make it very good
    about I was have idea , I was want to make a box to control the computer , I mean inside that box some second main switches and fuse and some lights and so on
    last thing I need to know how to do , I need to light up those top switches , I think to put leds next them but I want way to look cool . Any idea
    Thanks for Advise and help , CK
