Project: Computer's King " Expensive " 8/12/2006
Discussion in 'Project Logs' started by ComputerKing, 9 Dec 2006.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Thanks for taking time over the post CK, makes a real difference. Kudos ++
    Anywho, from what I see I kinda like the grill as it is. Although if you took a shot slightly furthur away so the surroundings are more visible it may be better to tell the effect on the overall appearance.
    Lookin' good, keep up the hard work :thumb:
  2. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    I decided to help ur english a bit. Your english is much better than it was in the beginning. GOOD JOB!
    i did my best to clean it up a bit.
    about the 120 exhaust, i think you should keep it. the wire fan guards dont look to good.
  3. ComputerKing
    8 Sep 2006
    Thanks Guys very much ... Also thanks brother for clean my post :D
    So on the Rear ( Back ) the 120mm grill will stay , And some changes will be on the back plate , I will post photo show the final plans on that panel !
    one last thing , The top I changed the idea from 2X80mm fans to 4X80mm it will be nicer on my Opinion if this not good tell me :D so that top will rock . to make the switch panel clear on the dark I will make a big trick there and I'm sure that every one will like it including me :)
    After I done from the Back and the top , I will start to think on that bottom and try to fix it because it was very bad idea to make it intake the air so this means that I must find nice place to intake the cold air ! so I'm thinking on the left side with 2X320mm fan I think , or maybe 5 or 6 from the 80mm !
    Like I said on the bottom that big new body it will carry all electronics crap and controllers !
    I don't want to rush so before every thing I will complete the top and back and post nice photos for plans then move on to the next :D
  4. zhangmaster12
    11 Jun 2006
  5. ComputerKing
    8 Sep 2006
    Lola those fans nice but I don't think I will go with them sorry :(
    I need one help :
    on the left side I want make it go up and down automatically with a motor or some thing , same the lamborghini doors idea
    so if any one have any thing can help me to built it I'm ready to listen to him :rock:
  6. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    probably a linea actuator is what you will need,possibly two but to get it to go the full height of the case means you'll need big ones....which you wont be able to fit.
  7. ComputerKing
    8 Sep 2006
    that is up and down motor , do you mean that thing bigger than my case height ( 40 cm ) means not gonna fit ?
    I want make it same the Lamborghini doors idea ! it will go up and stop there and go down again !
    thanks brother very much
  8. ComputerKing
    8 Sep 2006
    Brother thats what I need , you kickass man . on last thing
    here what I have to get ! ok I'm going to get one of those
    this one maybe big but this not problem now
    but 1 problem now : were I can find it ? mean what kind of sotres sell it ! For example the cars shop or the electronic store or which store that I have to hit ?
    tell me were to go to get one and change this side panels to the Lamborghini style ! :rock:
    thanks very much : im really want do it ! it will be kick ass
  9. Evenge
    Evenge Minimodder
    16 Sep 2006
    Well Lamborghini door is cool idea! :cooldude: :idea:
  10. ComputerKing
    8 Sep 2006
    thanks
    ok , guys I said which stores type I hit ?? and no one answer me ?? I cant hit all the uae stores ?? this crazy ?
    Bump ...
  11. Mother-Goose
    22 Jul 2004
    I'm not entirely sure where you'd get such a thing. Electronics stores are probably your best bet I think :thumb:
    I'm no electronics wizz but I think you'll need to check how much current is drawn when the acutator is activated and then make sure your psu can handle that as well as running the system, you dont want to the door panel to open and suddenly your comp turns off :)
  12. Jipa
    5 Feb 2004
    Those things are pretty expensive.. I have no idea what kind of shops sell those, because I don't think people usually need bare actuators. They usually come installed into something.
  13. Khensu
    Khensu likes to touch your special places
    22 Feb 2007
  14. ComputerKing
    8 Sep 2006
    ROFL . I called that shop in Dubai . :D the price was absolutely surprise it cost more than my power supply :D it cost 400 $ in Dubai I think this is really crap .... lol this is a lamborghini bet cost :D
    lol of course I cant get this thing to make the door go up and down ?
    so you guys must think on way to make it but not cost 400 $ :wallbash:
    I'm making searches but I need your help too
    I think to get the Mercedes windows motor that make the window go up and down ? but it will take a lot of time to built it into the side ? so if it worth and I can built I will go with it , but I need to see other easy solutions :d
    I'm waiting for cheap and east solutions , about the power I'm think on 12v dc 7 amp battery to make that motor work :D and this battery change automatic when it empty
    thanks and I'm waiting
  15. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Expensive = Fast solutions without alot of work to do.
    Cheap = Alot of stuff to learn/do by yourself :S
    I guess you could buy a small motor and design your own board and schematic for it then make the program yourself... But thats a bit painfull way :S
  16. ComputerKing
    8 Sep 2006
    lol dude the electronics things No problme with me !
    just the moving things and this things crap ...
    but both need work ? I need any nice way and cheap ..
    I want hear from you guys
    thanks
  17. Khensu
    22 Feb 2007
    Maybe you can try to find two or three small, not very expensive motors. I think that as long as it can carry the weight of the side panel and the "sticks" you will attach to the panel (to lift it up) it should be fine.
    I'm anything but an electronics or mechanics expert though, this is just a layman's view.
    Basically, what I am trying to say is that maybe you could look into buying only a motor, and then attach all the junk to it yourself; as opposed to buying one of those door-lifting things in one piece. It could be a much cheaper solution.
  18. ComputerKing
    8 Sep 2006
    ohh. I get you but motors they spin round not go up and down ? so which kind of motors you mean if you have some photos it will be nice to make me understand
    Thanks
  19. Jipa
    5 Feb 2004
    You need a DC-motor with a gear to lower the speed and increase the torque! Something like this http://www.balbots.com/images/Products/parts/Motor_103031w.jpg The motor is attached to a gear.
    With the motor you also need some switches to prevent them from spinning too much. Something like this http://www.clrwtr.com/Panasonic-Limit-Switch.jpg to both ends of the travel to shut the motor off when the door is in place.
    Thanks to the gear, that kind of motors also slow the door down so it doesn't accidentally flip open/close.
  20. ComputerKing
    8 Sep 2006
    you mean that motor need gear !! yeah but the problem to to build a gear box or a hands or that things to make it go up down ? so if you have idea how I can build it lets do it !
