Now I am getting a bit curiouse? about this project. Will it ever get past planning stages or is all this just jibberish. Can't wait to see actual progress.
<ot> CK : Can you please use a spell check before posting. No offense, but to get the most out of a "project log" we should be able to read it. </ot> I like the designs, What do you use to make them?
programes google sketchup + Paint lol this for simpale sketch Aslo I GOT VISTA altimate 64-bit thanks , CK just more 10 days and every thing will powered up , damit exams !!
Where are you getting 500MM fans from? I've only seen up to 250s, and they're already huge. And on your design you have a 500MM fan on the top, which is about the same width as a CD/DVD drive. From what I know about metrics (which might be totally wrong, I live in the US), 500mm is like 50cm, which is like... a foot and a half. A CD/DVD drive, however, is only 5.25 inches wide, so you've got some major proportion issues there... or I could be totally missing something...
oh , I was want get the car front radiator fan !!! I will see what I can do and Post just give me some time to complete my exams still 9 days more Thanks guys , and I'm sure you will like this keep going , Bye , CK
The 500mm is what I was addressing, I don't use sketch-up but there should (hopefully) be some way of making things to scale, be very sure to draw to scale before modding, and measure twice...no way a 500mm will fit on top, on the side sure, that'd be awesome. To put it simply CK, a CD drive is about 150mm, most cases are about 250mm wide, 300mm max. (this is a guess, but should be quite close) It'll be good to see where this ends up though
Thank you very much , I love your advise !!! I will KEEP THIS ON MY MIND !! Thanks man for Advise , Help me this out , But you know my crazy Idea Any Way I will Work On real sketch by hand and little by computer , I want a working computer like old friend on this thread told me Good luck , KEEP Going Guys , BYE < CK Edit : I just See "" !! AbsolutE LEGend !! """ COOOL I love That , This give me Push to be more better and Cool , Thanks Mr.Stuff Who make me This , I Love Bit-Tech !! AbsolutE LEGend !! Lol I will change my Project Idea to make It !! LEGend !! Like me My project From now Called !! LEGend !!
OK I was Just Plan On cooling Part !! I was Getting Water cooling system , But suddenly I got idea than make Inside mt computer like ac !! mean make the case like a special room have his own temps !! example : inside the case the temp 20 or 15 the inside fans will blow this air on the hardware and so !! because my room temp in summer like 25 with a/c working on max ,, I mean the case Will have this own temp with special a/c !!! like the car out side hot inside with the a/c cold same Idea !! SO It's like a central a/c on the case !!! so this will be better than water cooling or what !!! I want Advise to start complete the plan and put them here then start thanks , Bye. CK
It's a good idea, but I see two alternatives. 1) have a duct from your current a/c to your PC's intake, or 2) put a water chiller into a water cooling loop for sub-ambient temperatures.
Its Simple !!!!!!!!! 1) Make Inside my computer like Refrigerators !!!!! and the Cycle like this : And the fans will blow and move the air !!!! its damm Easy !!! thanks , CK
holy **** man,i dont know what you're doing but it sure is "different" Just read the whole thread,and how did you immagined that you could put 2000W subwoofer + speakers system near a case?You wont be able to turn the sound to even 10% before that whole thing crashes. Just saw your sketch of the case, "open dvd-rw working on air","camera","wireless station for mic and speakers" i dont know what all that means but is that some kind of a gadget computer? And how do you immagine you can fit 500mm fan ontop and on the side of the case.You have absolutely no idea how big that thing is,i bet you cant even get 120 mm fan working on top of that sausage. My advice to you is to try to make it a simple,clear case mod,with all that fans,controllers,stations,cameras it wont be even near a nice looking case.
hello , Sup Guys , !! I was waiting Answer from you about my 2 Q , SO I Made some Test , With my Stock Speed , And Stock Cooling ( Stock AIR ) , Stock Every Thing 1) the cooling plans 2 ) http://forums.bit-tech.net/showthread.php?t=127323 About the Cooling I Was Goning to cool Inside the case with one of Car Refrigerator Like this one on the photo : Also the LCD , I will use this one Please Guys Try To understand my idea and Answer me here the results !! Thanks , Good luck , Waiting , CK
mine e6600 is cooler than yours. LOL. jk btw, i like ur ideas. however, please use your ! key a little less and use normal capitalization. i dont mind those 21 smilies though. a few qs your case will be gigantic. over 1.5 feet wide. how does a "DVD-RW work on air?" is it on like on the slim ps2 that is top loading or in a cd player? in your clear section, you said there would be lots of wire and stuff, dont you want to hide wires, not show them? whats the camera for? suggestion, ditch the window on the top where the wires and battery goes, and the window on the bottom, under the wire and battery section. you can put the bigass fan on the window and the other two round things on the window to. overall i think the concept i great and i cannot wait to see it in fabrication.
Whether it's comes to fruition or not, I like your "throw caution and design principles to the wind" attitude We need more guys going for wacky stuff to keep pushing the envelope. Ah, I long for the days when I had to do my own led fans, and they were still cool.....
Agreed. You need to do reading on heat transfer and thermodynamics. If you're watercooling there's no point in two 500mm fans. I think I also saw you mention a refrigerator - a fridge is not suitable for cooling a computer. You need to design to scale and why is there a camera on the back of your case?
Ok I will go with air cooling !!! so the 500 mm fan needed and the a fridge also !! so why "" is not suitable for cooling a computer. """ thanks , I want to know , because this important for me , thanks , CK
