Case Mod - In Progress Project :: Cooler master Elite 130 Stacker , by iD2
Discussion in 'Project Logs' started by iD2, 10 Oct 2014.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Project name :: Elite 130 Stacker
    Project by :: iD2
    Hello, Today i'll show you my 2 PC case , 1st for my PC and 2nd for CNC Controller.
    Let start ::
    PS. I'm not good in English , If i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Need to move PSU for back to bottom. I do cut angle aluminum and drill cases with 2 hole for mountting angle aluminum and use it for hold PSU.
  3. iD2
    iD2 Minimodder
    25 Mar 2012
    After move PSU to bottom , the heat was more higher than normal so i decide to bought "Samuel 17" & "Corsair SP 120".
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    Just add the white light to it.
  5. iD2
    iD2 Minimodder
    25 Mar 2012
    Ready to glue acrylic to side panel.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    I already finished connector back panel but it make my cases hot , So i decide to make new back panel by using piece of side panel that i cut it out.
    The new back panel will make my cases more cooler.
    PS. Connector back panel not show in this post.
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    When finish new back panel and after try to find my old 80mm fan , now i got one and add it to back panel.
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    OK, just need 2 more fan and mount it to the position that Elite 130 already have.
  9. iD2
    iD2 Minimodder
    25 Mar 2012
    This my old connector back panel that i already finished it before buy 2nd case.
    There connector will support 4 axis stepper motor , 1 e-stop , 3 limit switch.
  10. iD2
    iD2 Minimodder
    25 Mar 2012
    And now finish it. But for CNC Controller i still not buy it , when i have an update about it i'll post it.
