Project: Coolermaster Stacker by Snakez & Ediejo - Completed 100% !
Discussion in 'Project Logs' started by Snakez, 13 Sep 2006.
  1. itsjustacompaq
    itsjustacompaq Member
    7 Sep 2006
    thanks, but are you worried about them falling out with the fans' vibrations?
  2. Snakez
    Snakez New Member
    23 Dec 2005
    Nope , they are stuck in the plexi , wont come out.
  3. Snakez
    Snakez New Member
    23 Dec 2005
    Also in the plexi between the radgrill we need to put some leds, so lets drill very carefully.
    Thats all we do with this today.Continue with the Musketeer.
    Because we leave the top of it open, we have to sleeve the 2 cable's aswell , because they will be a little visible.
    Then ofcourse whe have to be able to control the musketeer, what a job :p
    And then the hardest job.
    At place:p
    Long enough. ;)
    This is how it looks like from a distance.
    And like this in the dark.
    Buttons working too.
    And dark again:p
    Lets put reservoir in too then.
    When the res light up , the mod is ready
    We are thinking of changing for blue dye for the coolant , because whe think looks better with the rest of the front, what do you guys think about it?
    Meanwhile i will mail o.c.-schop.nlfor blue dye.
    Next project is already waiting. :oops:
    Click.
  4. SIMSY
    SIMSY New Member
    7 Sep 2006
    that has turned out so well
    i cant wait to see the next project, its an amazing case as it is, good luck
  5. Snakez
    Snakez New Member
    23 Dec 2005
    Today some work at the top..
    First solder some leds.
    Seem to work fine:p.
    Lets turn of the lights. :)
    From another angle.
    Look at the shine on the plastic cover.
    In total for top only 9 high bright leds are used , green colored , don't need uv light because is fluoresend plexi. Only thing it needs is light. :)
    Tomorrow no update ,After 16 days non stop working and modding it's time for a day of rest.
  6. Neoki
    Neoki Member
    26 Oct 2004
    Are those paints from the UK is it hard to paint a case as i need to do it by friday morning. Thanks
  7. specofdust
    specofdust Banned
    26 Feb 2005
    This mods coming along extremely well, keep up the great work guys :)
  8. N.A.N.O.
    N.A.N.O. New Member
    26 Oct 2006
    Very nice case,,
    Where there many visitors at HWI days to look at your case?
    I was planning to go to the HWI days but I live in the east of the Netherlands and I had no one who could take to the HWI days. So that wasn't that nice.
  9. Koradhil
    Koradhil New Member
    9 Nov 2004
    I also live in the east of Holland (Hengelo, OV), but I still went to the HWI days (by train)..
  10. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Great mod, great craftsmanship....Not too keen on the colour scheme though, but it's very original. :dremel:
  11. customh
    customh conflagration.
    22 Oct 2005
    Quite fancy, i like it, ill be watching, wish i would have from the beginning, i have to read through it now.
  12. Snakez
    Snakez New Member
    23 Dec 2005
    Some of the paitnwork got messed up , so fix it . Because of the varnish all needs to go off.
    And spraypuddy , tomorrow spraypaint bleu again.
    And when im here , why not sleeve some cables.
    Even the little boults are blue :p
    And here you can see the space between plexi and metalf front again.
    See ya tomorrow.
  13. Yosemite
    Yosemite New Member
    6 Jul 2006
    i love watching this mod, i know a lot of people arent liking the color scheme but i love it, i always wanted to do something like this, though i doubt i would stealth :D i like the cluttered look, well, only if its intentional and looks organized in some way.
  14. elliod
    elliod New Member
    1 Oct 2006
    great project man keep it up
  15. ssR
    ssR Carbon God
    11 Aug 2006
    what exactly happened to the paint? just got scratched or peeled? or something else maybe?
  16. NysoO
    NysoO Handcrafted
    2 Nov 2006
    OK, my first post then.. I'll make it in this thread, just because your project is so goddamn nice! :)
  17. Ediejo
    Ediejo New Member
    31 Jul 2005
    @Yosemite, for me the color scheme was also a shock. ;)
    @elliod, thanks.
    @ssR’ I mesh up the paint job with making some extra holes for the led’s, but I fix what I mesh up. Snakez will put soon a next update online. ;)
    @NysoO. thanks.
  18. Snakez
    Snakez New Member
    23 Dec 2005
    I messed up the varnish drilling extra holes for leds, so to bad.
    So spray it again.
    Snakez building in the pump , when waiting for paint to dry , i've bin working on the wires.
    Also hooked up the reservoir. The OC-press tube is really great.:p
    You can twist it in every direction without folding it , real good stuff:p
    Also there was something in the way , The backside of the Musketeer was in the way for the fittings of the radiator, So what else is there to do then cut away the backside .And look if it fits then. tomorrow i will paint the edge of the Musketeer casing blue , and then problem solved.
    It fitts :p
    Will not say we are there yet , dit has to go on it's place to nice and thight.:)
    Tomorrow and saturday wil be solder day . Lot's of wires to be hooked up and stowed away.
    Total of 44 led's , So 88 wires to hide. :)
    And the wire is teflonwire , hard to strip :p
  19. customh
    22 Oct 2005
    You guys are amazing!! nuts! (crazy), but amazing.
  20. Snakez
    Snakez New Member
    23 Dec 2005
    Lol , thnx :p
