Project: Coolermaster Stacker by Snakez & Ediejo - Completed 100% !
Discussion in 'Project Logs' started by Snakez, 13 Sep 2006.
  1. customh
    customh conflagration.
    22 Oct 2005
    I'm enjoying it, you're welcome. :hehe:
  2. chase
    chase What's a Dremel?
    11 May 2006
    Sweet, food for me :)
    Petter
  3. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    After having taken a little rest friday and saterday, the batteries where charged again. That meant starting one hell of a job Sunday morning.:
    Placing 25 LEDs, connecting them, ánd solving another big problem. The Musketeer wouldn’t fit.
    The start: the protection tubes for the LEDs.
    Putting the LEDs in
    Outlining the extra holes in the plexiglass:.
    Solder away!
    And then we have thirty wires:.
    This really is a delicate job…
    The we have the big problem. It seems the connections for the sound are too long, so now the Musketeer doesn’t fit for the second time in a row.
    So what I did is cutting of the connectors (first looked where the plus and min of the sound are and the desolder…
    Then we drill the holes in the circuit board.
    Where once the connector was are now three wires.
    Cut them of and it looks just fine.
    Did you think i was ready? Not realy, the power connector had to go off too.
    So you see, for every problem we have a solution. The Musketeer is in place and doesn’t have to come out ever again!
    No, Ediejo isnt ready with the solder iron yet. This site isn’t thát much….
    But the other side…
    To be clear, that big bunch down there too…
    Later on you won’t see much of it anymore
    The oc-press tube barely fits through the holes, but it fits just right!
    This is everything of wiring that will be in sight. The two wires for the sound in and out of the Musketeer and the two black/red wires for the light of the Musketeer and harddrive will fit nicely behind the motherboard.
    After a twelve hour day in my moddingroom i think it’s enough for today. Tomorrow more soldering and if everything goes right we’ll finish building Tuesday. But then everything has to go right.. or else Wednesday is another day ;)
  4. Franklin
    Franklin Minimodder
    24 Oct 2004
    Many wires Ed, but not a record :D I would love to see the endresult.
  5. customh
    22 Oct 2005
    As will I franklin, as will I. Looks great!!
  6. Ediejo
    31 Jul 2005
    I dond’t want that record franklin. ;)
    For the end result have some patience. And I know that you have that. ;)
  7. Jipa
    5 Feb 2004
    This is definitely the coolest Stacker I've seen and I guess it's just gonna get better :)
  8. Ediejo
    31 Jul 2005
    Thanks Jipa. But I also understand if people say I don’t like the color combination.
  9. SnowPunk98
    SnowPunk98 What's a Dremel?
    15 Jun 2004
    Lookin good so far
  10. elliod
    elliod What's a Dremel?
    1 Oct 2006
    great work man hope that nothing goes wrong really want to see the end result.
    keep up the good work.
  11. Ediejo
    31 Jul 2005
    A small update today because of a small issue which delayed the whole lot a bit (with a size of approx. 5mm ;)
    I looks like all leds are operational …..
    With exception of one ;-) because the stock is gone, all leds are used and there is still one which needs to be replaced.
    This is the guilty one , the pain in the ass, it’s already removed but now we need to replace it with a new one and you can be assured that it’s not easy because of its location.
    It it’s not easy to spot, but to get the perfect result it must be replaced …
    The case fans who provide the wanted result, the produced light is superb.
    A shot with the side panel. As you can see the number of led’s did not change, due to the fact that the resistors are changed the leds produced more light then they suppose to do. This will have a negative impact on the life/endurance of the leds, that why we swapped the resistors which decreased the brightness of the leds but improved the life. That’s also the reason that now more leds are used to get the same result.
    Tomorrow my Canon 350D should be ready after it needed to have some repair. This means the quality of the photos will improve dramatically. :rock: The Fuji camera which I used today is not able to cope with the UV light …..
  12. Yosemite
    Yosemite What's a Dremel?
    6 Jul 2006
    yay, i love seeing this mod come to life :D
  13. SIMSY
    SIMSY What's a Dremel?
    7 Sep 2006
    That looks amazing.
    exelent work :D
  14. Neoki
    Neoki Minimodder
    26 Oct 2004
    You never did answer me about the paint. Can you give me the info on what the exact process you did was and what the exact paint was please.
    Looking top notch love it:D
  15. Ediejo
    31 Jul 2005
    @Neoki, the First thing that I did was making the parts who must be painted a bit rougher with sand paper 240.
    Then I spray it 3 times in the primer.
    Then I spray it 4 times in the colour. Click ;)
    Than the next day I spray it 3 or 4 times with varnish.
    Distance to the material 30 cm ;)
  16. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    Today first thing i did was pick up de Canon 350D up.
    So i can give you guys some better pics:p
    This is what the 350 makes of it :)
    With the lights on.
    Then a little darker.
    Then totall darkness.
    After that started on exchanging the led that doesn't work. To get there the whole stealthing plate needed to go out again. What a job.
    De top led is changed in a few minutes. Now i can start working on hiding all the wires. And even when it takes 2 days for the led to arrive , it doesn't matter . Still enoght work to do.
    Cool , fans not working lighting up like that.:)
    On this pic you can see the prurple uv glow comming out of the case. :p
    It seems we did do not much today....It was hours of work changing the led.
    He's fine like this for today , back again tommorow.
  17. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Looking good ;)
  18. customh
    22 Oct 2005
    agreed, keep it up!!
  19. SIMSY
    7 Sep 2006
    I want it :p
  20. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    The fans are spooky :p
