Project: Coolermaster Stacker by Snakez & Ediejo - Completed 100% !
Discussion in 'Project Logs' started by Snakez, 13 Sep 2006.
  1. Yosemite
    Yosemite What's a Dremel?
    6 Jul 2006
    i love the color scheme, as i plan on using the same one, i always envisioned it, this is just the extra nudge, i have to admit i dont like the stealthing, only because i like the unorganized look, sorta like the orac case, it fits my personality(and room :D) anyways its great.
    oh yeah what does part II entail? after you get back from the lan party that is.
  2. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    Then we give a go @ the front of the case.
    Don't want to keep original bezels.
    And use different reservoir and some more things.
    But wait and see :D
  3. Jipa
    5 Feb 2004
    uATX mobo on such a huge chassis :eyebrow: Great work so far!
  4. Snakez
    23 Dec 2005
    Yeah i know, its very small , but maybe i can find some sponsors for some better hardware.
    This is for starters :D
  5. Jipa
    5 Feb 2004
    Just remember to keep the option of a full sized mobo and that's fine :)
  6. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    I ask the person from this case. Do you want to change the mobo in the future? His answer was NO I keep this mobo inside the case. So we make the stealthing like this. He can only change to another uATX mobo. :naughty:
    I make the stealthing part from steel at my work. It will be only 1 part welling together and polish the part. In the slant part we make to big holes for the tubes. We also use some green plexi behind the holes. Also we make a big hole for the psu fan. Than paint it in the same color as the inside from the case. The green plexi is only for some detail.
    When we assemble the steal part in the case. We also make a cover for the hole right from the mobo. In the same color combination greenplexi and a bleu steel plate. :thumb:
    After Netgamez we give the front a new look. Also in the same combination green plexi with a blue steel plate. :hip:
  7. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    Dont like the blue and green mix, but its a very good mod.
  8. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Pictures don't work!! :confused:
  9. Yosemite
    6 Jul 2006
    yeah i noticed the same thing, some work but most dont, maybe its my side, though i have very fast connection(like 400mb/s)
  10. gometro33
    gometro33 What's a Dremel?
    11 Jan 2005
    400mb/s?:rolleyes: Somehow I doubt that...
    Yes, pictures are not working.
  11. Thrillseekah
    Thrillseekah What's a Dremel?
    21 Oct 2004
    Fixed the pictures.
    We give him free hosting space for his pictures but we had the limit to low ;)
    Sorry for this fixed again.
  12. Snakez
    23 Dec 2005
    Thnx guys, great job having them back on so soon :rock:
  13. Yosemite
    6 Jul 2006
    lol, i bet you do, i wouldnt believe it either if i didnt have it, my school provides the connection, and i somehow have the bulk of the bandwith, i would think it would be shared, but im not complaining. thats how schools are, some have slow, some have fast, food sucks, and they overcharge for everything.(though i must add that 400/s is the fastest i get, usually it spikes and fluctuates, not really consistent :))
    also where'd you get the green plexi?
  14. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    i think it's standard AC-ryan modding acryllic, coz' he uses the cardboard packing as stealthing-part template :)
    keep on modding my fellow-dutch-people :thumb:
  15. Snakez
    23 Dec 2005
    It's time for another small update.
    Today we started working on the sidepanel.
    First measure things up.
    Let's see how it looks :)
    Then some fine work by hand.
    Looks pretty straight like this.
    After that the corners nice and straight.
    And the result :D
  16. Ediejo
    31 Jul 2005
    That slanting part in the stealhting, that was snakez idea. That gives me the inspiration to make the side panel in the same style. ;)
    2 people know more than 1 ;)
  17. Snakez
    23 Dec 2005
    Thats teamwork Edje :rock:
  18. LuitvD
    13 Aug 2006
    and the result is amazing :eeek: That's some crazy look there, can't wait to see this in blue-green style :) keep it up
    I see you guys live quite near... mind if I come over sometime to cut my window at your workshop? :blush:
  19. chase
    chase What's a Dremel?
    11 May 2006
    Looking really good that sidewindow, and the cover that is yet to be made.
    Would be really cool if you could make the cover exactly along the bottom line of the sidewindow, that way, it will look like a "floor".
    Good luck!
    Petter
  20. Ediejo
    31 Jul 2005
    Sure, after the HWI-dagen we have some time to do that.
