Project: Coolermaster Stacker by Snakez & Ediejo - Completed 100% !
Discussion in 'Project Logs' started by Snakez, 13 Sep 2006.
  1. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    That's no problem at all.
    Come by after the HWidays , and it's done :D
  2. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Today i started working on the Metal for the stealthing part..
    For some things a Darley is a great tool to use..
    To cut the steel ….
    Draw it and then polishing it.
    The First piece out...
    Next the cutout for the radiator.
    This one went quickly too.
    And then to the angle folder ,
    Nice fit. Now the last part. :worried:
    And that went great too. :hip:
    Now prepare for the worst job. Galvanised metal is real bad for your health to welt. Normaly I don’t prefer to do it like this , but was no other option.
    Some wires in between for the front opening.
    Welded togheter.
    Its difficult to welt 1,5 mm metal with a 1,2 mm wire
    But the polishing machines are doing a good job. :thumb:
    Next fase holes for powersupply and watercooling.
    But before the next fase we must know of its fit. Snakez is on his way back to his house and he will post the result. :D
  3. Jipa
    5 Feb 2004
    Waah I want access to all those machines too!
  4. Snakez
    23 Dec 2005
    Now that Ediejo did such a nice job on the metal for stealthing part.
    We also must see if it fitts.
    So first remove the hardware and top of the case.
    And now hope it fitts.
    Then also put the window in front.
    Really want to see the result.
    Real great imo:p
  5. ssR
    ssR Carbon God
    11 Aug 2006
    gorgeous metalwork. really gj so far guys, keep it up :clap:
  6. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    how much room is there between the panel and the new piece of metal? :p
    You should dump a load of ultra bright leds around that thing, would make it look gorgeously back-lit
    But it's your case, so you guys decide, hope it'll look nice :) bet it will :thumb: keep it up
  7. Yosemite
    Yosemite What's a Dremel?
    6 Jul 2006
    i think i would want the panel to be the same height as the stealth, but thats just me. looks awesome though.
  8. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Same, and possibly the stealth spanning the entire width of the case.
  9. Snakez
    23 Dec 2005
    Wait and see when it's finished :D
  10. Vermino
    Vermino What's a Dremel?
    4 Oct 2006
    i kind-of see where snakez is going with the over-lapping.. i think it looks good, kind-of like an insert mat in artwork.
  11. chase
    chase What's a Dremel?
    11 May 2006
    :thumb: Nice work, yet again
    Petter
  12. T.M.P
    T.M.P What's a Dremel?
    23 Apr 2006
    Maybe i overlocked something but are the Hdd going to be watercooled to?
    Realy great metal work. :thumb:
  13. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    i LIKE THE METAL
  14. Snakez
    23 Dec 2005
    Nope Hdd's are not gonna be watercooled.
  15. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Nice metal work but is it clearing the main board?
  16. Snakez
    23 Dec 2005
    Offcourse it is :baby:
  17. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    WOW, that thing is gonna be a BEAST :jawdrop:
    I love it though, mod on!! :dremel:
  18. hydro_electric_655
    13 Jul 2006
    Its beautiful
  19. Ediejo
    31 Jul 2005
    Thank you for al the compliments so far. :)
    I read that some people think that the side panel must be the same high as the stealthing part. I think that some effects will disappear. With the different height in both parts we can make more light effect. When we put some led’s there, and also near the motherboard. We have than the same light effect at the front as in the back. So that’s the reason that we chose the different height in the panel. And I think when it have the same height. It looks a bit ponderous.
    But that is my vision. :hip:
  20. Ediejo
    31 Jul 2005
    Today a perfect day to finch the stealthing part.
    First some calculation for the holes.
    Snakez placed the pump.
    Also some UV-Leds for the steahlting part..
    Drilling the holes.
    Last part by hand.
    Its fits.
    Also the tubules for the vga
    Put everything back to look where we need to cut some steel.
    This is what disappears under it.
    Make some extra holes for the cables
    This one fit also.
    One big hole to make.
    I think this one is on his end.
    I am right back with part 2 but first a shower.
