Planning Project: COOOL DUUUDE
Discussion in 'Modding' started by bigsharn, 10 Jul 2010.
  1. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Ok, well as a few of you know I overheat easily, especially when out on bike rides, so I was after a way of cooling myself down without forking out a fortune on cool suits etc.
    Roll on: Project COOOL DUUUDE
    Basically, the plan is to find a way to keep me cooler at work (and less so on bike rides), knowing that I have a few no-name case fans around I was thinking of mounting one in the hat of my uniform so that when I take it off, it won't be caked in sweat... As such I'll need (at least):
    A pressure switch
    A PP3 battery and connector
    A fan capable of moving lots of air, very quickly (though testing will be done with a no-name fan so I don't blow it up)
    A fan guard (so as not to give myself a haircut every time I turn it on)
    Some velcro for mounting
    ...I say "at least" because I'm highly tempted to wire two batteries up at once to the same fan, I don't know what overvolting a fan will do other than make it go faster, but I also want the setup to be waterproof, so I'll need to come up with an enclosure for the entire thing (probably butchering some plastic mack and a lightweight material for the frame).
    Any thoughts? Especially on overvolting the fan?
  2. bushi
    bushi What's a Dremel?
    8 Jul 2010
    How about just a bag of ice under your hat (or helmet) which is strapped to your head.
  3. bigsharn
    9 May 2008
    See the problem with that is it melts and by about midday you need a new ice pack, and the hat will still get sodden from the ice melting and the condensation.
    Thanks for the suggestion though :)
