Case Mod - In Progress Project : CopperHead: 6/4/09 Orange:
Discussion in 'Project Logs' started by modsquad, 27 Jul 2008.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    It is a "real stinger" a chip-stinger..
    It's no-longer a prototype..Order yours today.. In universal or board-specific mount..
    GET STUNG..
    I have been "pushing" FRED to start doing videocard Stinger's .. I have "high-hopes" that he will do another prototype for me when that time comes (months away for this project).. POST UP FRED...
    Thanks for the "heads up" on the HARDWARELABS gear. It's an expensive 120mm radiator, but it seems to be the best money can buy..
    I will have to get-me-one.. Can you hear me Performance-PCs..... :D
    MS
  2. The boy 4rm oz
    10 Apr 2008
    I know it's a real Stinger. I meant "real Stinger" as is CPU stinger the big one lol.
    The BlackIce radiators are very good but not the best. If you want the best get a Thermochill or a Feser rad:
    Thermochill PA120.1:
    http://www.gammods.com.au/store/index.php?main_page=product_info&cPath=1_2&products_id=7
    Feser TFC Xchanger 120mm:
    http://www.gammods.com.au/store/index.php?main_page=product_info&cPath=1_2&products_id=577
    Both are expensive but they work really well with low powered fans meaning you get a more silent computing experience with very good temps.
  3. alpha_prime
    alpha_prime What's a Dremel?
    11 May 2007
    They actually make a chrome version, Aquatuning has it...
  4. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Love the mod MS, looking very nice. I am a little concerned/curious as to your ability to get away with a single 120mm rad, though. I have CPU/NB/SB/MOSFET in one loop with a single 120 and a dual 80 with no temperature issues (Q6600 not OC'd stays around 26C idle) but I didn't feel bold enough to attempt it with a single rad.
    I will have to keep my eyes on this, I look forward to seeing how this works out for you.
    P.S. I grew up in Rockford, about an hour northwest of Chicago. Living in Madison now. My what a small world this is.
  5. Multiplectic
    Multiplectic His Stigness
    4 Sep 2007
    MS, have you thought about how much it's going to weigh? All that copper... :p
  6. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    It's FANTASTIC!!!!
    Fredo have done a good job, and my next mod will be watercooled, with Fred's wb!
  7. modsquad
    27 Feb 2004
    backing-plates 1
    first real work I have managed in over a month..
    Backing plates.. After seeing DangerDen's
    I looked and said " hell, I can do that..:dremel:
    And so I did..
    The StingerBlocks are massive (heavy) both the V6i CPU and chip-stinger need (IMHO) backing plates..
    chipset
    then
    Sorry: I have "lots more pictures to show" BUT, I am drunk..Just can't type anymore..
    I should get a package from McMaster-Carr later today containing thumb-nuts and Silicone Rubber Film..
    I promise more to-follow..
    MS
  8. The boy 4rm oz
    10 Apr 2008
    At least you have made some progress :thumb:.
  9. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    There is only 1 obvious solution..... drink more!
  10. modsquad
    27 Feb 2004
    backing plates II
    The backing plates are made from 3mm Lexan
    the mounting hardware
    from EkWaterBlocks
    the CPU plate is EZ
    the only problem is height..
    the answer is to counter sink the bolt holes
    like so
    bolted in
    Lets test fit the StinGer
    ran into a problem right-off
    the EK springs are too long..
    the answer, cut them in half with the :dremel:
    the northbridge plate is next..
    the area around the NB
    the plate needs a center hole
    and more counter-sinking for clearance.
    installed
    that is it Guys.. have a great weekend
    MS
  11. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    :jawdrop: Those are gorgeous!
  12. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    DEAD ON!!!
  13. mr_carl
    mr_carl What's a Dremel?
    2 Jul 2007
    Man, this is so awesome it just makes me wanna cry it´s so beauty full:waah:
  14. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Love the backplate!
    Your attenction to this little details is incredible, you teach me a lot, every items you do!
  15. The boy 4rm oz
    10 Apr 2008
    Sweet work on the mounting plates. See, alcohol does help you mod lol.
  16. modsquad
    27 Feb 2004
    Just as Dracula needs blood, I need alcohol.. With out it I would turn to dust..
    Thanks one and all.. The MB needs those backing plates. The Stinger-blocks are massive hunks of copper. The MB is getting very-heavy.. With it's 40+ Enzotech heatsinks, the pair of Stinger's and a copper videocard waterblock (most likely EK), it's total-mass could be about 5lbs..
    And don't forget the enzo-ram-sinks:
    the box is just sitting and waiting for me to purchase memory (DDR3-1800)
    thanks for the gear EnzoTech
    final MB weight (my guess) could be 6lbs.. :worried:
    MS
  17. The boy 4rm oz
    10 Apr 2008
    Those RAM coolers are amazing. They look sweet and are are packaged better than any other RAM/cooler I have ever seen.
    I think your gonna win the prize for heaviest mobo ever lol.
  18. headala
    headala What's a Dremel?
    9 Oct 2005
    Wow, MS, still looking great. Your backplates look very professional, and will get the job done. Keep going, man!
  19. modsquad
    27 Feb 2004
    Thanks head.. That's what I do (and have been going for years on bit-tech). Simplify the simple ("Go tell the Spartans").. Make plan the obvious. As my last post shows "anyone" can make backing-plates.. It's not-hard..
    All that's needed : "simple hand-tools" and a bit of imagination... Why send money to DangerDen or EK WaterBlocks for something anyone can do (make) themselves..
    I would guess FRED STINGER will finish and ship my prototype " X58 chipstinger" and hose-claps before the week ends.. Pictures are sure to follow..
    I am truly envious of his talent.. If only " I could do that"...:wallbash:
    @ boy4oz.. I am all but sure I will win the MB weight contest when all is "said and done".. (5lbs and counting)...
    MS
  20. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    Very nice work as usual and I always like the attention to detail as well as the hand work. :clap:
    BTW, I have been considering ditching the pair of FMJ's I have in FF. I seem to have lost an Aquastream somewhere and if I can't find it I will probably get a pair of DDC's. So PM me if you want them.
