Case Mod - In Progress Project "CORSAIR 760T Black & White"
Discussion in 'Project Logs' started by Gas_designs, 22 May 2016.
  1. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Hi everyone and welcome to my new project. :thumb:
    After the last experience on a Desk ( Dragon Desk), I decided to modding a case, this time ... especially a Corsair Graphite 760T V2 - black / white
    A short complete description of the entire project and job accounting.
    Ago if you wish, you can also follow me on my Facebook page:
    https://www.facebook.com/GasMod-267934856887732/
    Motherboard: UNDECIDED
    CPU: Intel i7 6700K
    Memory: Corsair Platinium DDR4 3000 32Gb
    GPU: Asus Strix GTX 970
    PSU: Corsair HX 850i
    SSD: 2 Corsair Neutron Series XT 480GB
    CPU Block: Phobya CPU-Cooler UC-2 LT - Silver Nickel Plexi Edition
    GPU Blocks: Bitspower VG-NGTX970ADIIS Acrylic Top With Stainless Panel (Clear)
    Radiators: NexXxoS UT60 Full Copper 360mm
    Pump: Alphacool VPP655 - single edition
    Reservoir: Alphacool Eisbecher D5 250mm Plexi
    Tube Fittings: Alphacool
    Coolant: Phobya ZuperZero Clear
    Case: Corsair Graphite 760T V2 - black/white
    Fans: Corsair Air Series SP120 High Performance Edition 120mm
    Cables: Corsair sleeved DC Cable Kit, WHITE
    Keyboard: Corsair Strafe RGB MX Silent
    Mouse: Corsair Gaming Sabre RGB
    Lighting: Phobya LED-Flexlight HighDensity 60cm white (72x SMD LED´s)
  2. Gas_designs
    29 Sep 2014
    Corsair Material
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    The MbK moniker is already taken fella.....
  4. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Ohhhh, and I thought it was another Kier project :duh:
    Best change the moniker Bud :thumb:
    Edit: Sorry, I didnt see that Mr. Neg has already mentioned this!
  5. Gas_designs
    29 Sep 2014
    Aquatuning Material
  6. GeorgeK
    18 Sep 2010
    Morning
    What exactly is the problem here?
    GK
  7. B NEGATIVE
    8 Aug 2011
    There isnt one,the OP realized that the MbK monicker is 'in use' already and has altered his title in response.
  8. Gas_designs
    29 Sep 2014
    Thank you for having changed the title, and excuse the error. :thumb:
  9. Gas_designs
    29 Sep 2014
    Here we are guys, it's time to start editing some part of the Corsair 760T.
    So hand Dremel, and flexible. :dremel: :dremel:
    I start to remove the front part of the dvd. Unfortunately goes brutally cut, because it is not fixed by simple rivets, but it's all a folded block. :thumb:
    Now is the best part of the cuts, after careful measurement..... :thumb:
    I also have to eliminate this part:dremel, as the VGA will be placed vertically. :dremel: :dremel:
  10. Gas_designs
    29 Sep 2014
    Hi guys, I continue staring and realizing the support to fix the VGA vertical .....
    Recovering the "support" of the vga from an old case, and working with an aluminum plate, to fix everything. :dremel: :dremel:
    And fixed all the time with the aluminum rivets. :naughty:
  11. Praelia7or
    Praelia7or What's a Dremel?
    16 Apr 2016
    Interesting with the vertical GPU mounting, looking to do something similar so will be keeping an eye on this :)
  12. Gas_designs
    29 Sep 2014
    Continue , with realize with an aluminum bar, the internal level to securing homes with more and aluminum rivets, and some small allen. :dremel:
    ............... :clap:
  13. Gas_designs
    29 Sep 2014
    This afternoon I began to fix the front aluminum bar, putting it level with the rest of the case. :thumb:
    In the lower part will then fissta an aluminum plate, laser cut. :dremel:
    .................. :rock:
  14. Gas_designs
    29 Sep 2014
    Hi .... :clap:
    Today I decided to enter the inside of the radiator, this grid to fix the slats of rad.
    You will need some cut, since it is the largest of the radiator.
    Some cut with flexible and will be perfect.... :dremel::dremel:
    ............. :thumb:
  15. Gas_designs
    29 Sep 2014
    It 's time to discard the plexyglass..... The plate is white, but slightly transparent. :thumb: :thumb:
    Now the realization of the depth of the radiator box. :dremel:
    Finally try the shelf .... :thumb:
  16. Gas_designs
    29 Sep 2014
    Hi boys .... :thumb:
    Because I have to wait until I arrive the mobo, Today I began to fix the pump and tank on plexy.
    I also decided to put the fans inside the Corsair. :dremel: :dremel:
    I have also connected the radiator using his elbows to 90° of Alphacool, and pierced the Plexiglas to accommodate the bulkhead. :D
    ................ :clap:
  17. Gas_designs
    29 Sep 2014
    Hi guys. :clap:
    Meanwhile I had to wait until I arrived a bit of material to continue ......
    A few photos of the new WB.
    Who immediately mounted on Asus 970 Strix, to have the footprint measures in case. :rock:
    Also during this period I also got the processor that will be used in mod. :thumb:
    Now I must wait until I arrive the motherboard..... :D
  18. Gas_designs
    29 Sep 2014
    Hi boys :thumb:
    Today I started working the front of the Plexiglas, from 5mm.
    And after the necessary measurements, I can start.
    And I start with the cuts. :dremel: :dremel: :dremel:
    And finally here is how: :D
    ............... :clap: :clap:
  19. DEEPCOOL-Maxwell
    DEEPCOOL-Maxwell What's a Dremel?
    4 Jul 2016
    Hello there, it's really a nice build! I'm Maxwell from DEEPCOOL, just sent a friend
    request to you. Could you send a message back to me when you see it? I have some good news you would be interested in.
  20. Gas_designs
    29 Sep 2014
    Hi boys ... :thumb: :thumb:
    And finally, after a thousand problems with shipping, and the first motherboard stolen a customs, then finally it came:: :grr: :grr: ;)
    Some pictures, and ready to mount processor - ram - wb.
    ................ :dremel: :clap: :clap:
