Case Mod - In Progress Project COSMOS by ThePunisher
Discussion in 'Project Logs' started by ThePunisher, 21 Jul 2016.
  1. ThePunisher
    ThePunisher Minimodder
    19 Jul 2016
    One part from Bykski block make PCB bent so I must cut it, new revision of this block dont have this problem.
    This show how I can remove Front Radiator
    I changed fans on top radiator. Arctic P12 have same performance as PW2 but are much more quaiet so now I have same noise but highe rrpm and performance. P12 can run on 850 rpm and give much more static presure than pw2 on 650 rpm with same noise.
    I bought bykski's GPU holder but I must cut some parts if I want to fit it.
    Jean R built and Cheapskate like this.
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Why didn't you build it ? You seem to get some skills for !?
  3. ThePunisher
    19 Jul 2016
    But what do you mean? Bykski holder or copper element in water block?
    If you have meane element in block which i cut off It was easier to cut off the disturbing element and make it look right than to do it from scratch.
    If you have mean VGA holder I must say that I don't have enough time to do elements right now, bykski was very cheap and solid, I must only cut it a little bit.
    Jean R built likes this.
  4. Canardwc
    22 Sep 2011
    Sorry, i meant about Holder :dremel::)
  5. ThePunisher
    19 Jul 2016
    Ok
    Project is finally done!
    I OCed my G.Skill Trident so cooler was necessary (3800 15-15-15-36-1T, 1,43V)
    Of course big thanks for my little fluffy friend which stole me a lot of screws :D :D
  6. Cheapskate
    13 May 2007
    Run a magnet over that cat. I'll bet there's still screws in that fluff somewhere. :lol:
  7. ThePunisher
    19 Jul 2016
    Haha, probably :D
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    nice great job
    Did i just look @ 20+pics of the exact same thing :wallbash::duh::eeek::lol:
  9. ThePunisher
    19 Jul 2016
    Thanks.
    I couldn't decide which pics chose so I upload all :D
