Case Mod - In Progress Project: Cosmos SLR
Discussion in 'Project Logs' started by coolmiester, 22 Sep 2007.
  1. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Why are those fans mounted as intake ?
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    because they look cool! nuf said!
  3. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Couldn't have put it better myself:hehe:
  4. Burnout21
    9 Sep 2005
    i have a nack at that..ROFL!
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    oh how I love chrome and this mod
  6. coolmiester
    31 Dec 2002
    To be fair Koradhil, personally i try to build show cases to show the things that matter off rather than hiding them and if that's to the sacrifice of a little performance hit so be it but a couple of degrees at best is all i will loose with the setup this way so i'll go form over functionality every time and let everyone else worry about those eth degrees.
    No different to what i did here and here really apart from the fans are pushing rather than pulling through the rad but if this case was about performance i wouldn't be using an X-Flow 240 GTS to start with tbh
    Hope that helps clear the reasoning why i mounted it this way:)
  7. coolmiester
    31 Dec 2002
    Had to dig deep today and after an 8 hour shift managed to get the other side panel finished which was a lot easier second time around as there wasn’t any trial and error, it was simply a case of copying the previous one in reverse so got that done then went onto polishing the two top grab handles and painted the bottom two matt black.
    Anyway did a bit of a mock up to see how things were looking……..minus the front door as I left it at work and didn’t really want to go and collect it as I was covered in polish grime.
    So at long last its starting to come together….
  8. khanage0
    khanage0 Minimodder
    2 Sep 2007
    dude this is looking awsome:thumb:
  9. Virus-Frederic
    Virus-Frederic What's a Dremel?
    17 May 2007
    :) hello coolmiester
    Very very :jawdrop: nice mod that you have done :thumb: But for the inclusion cosmos account you put something else like "KOMPRESSOR"
  10. Godric
    Godric What's a Dremel?
    23 Jan 2007
    Looks really nice, are you going to change the colours of the jacks for sound and mic? They ruin the nice colour combination.
  11. Koradhil
    9 Nov 2004
    Looks kickass :thumb: Might have been even nicer if the exhausts would point farther backwards though. I love the polished bars on the top.
    I have another question for you. How did you remove the double sided tape which is used to mount the foam padding and the plexi on the door ? It took me an hour to get the stuff off one of the sidepanels, using heptane solvent (I guess the english word is white spirit).
  12. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Looks really excellent :rock: Here's a couple of small, tiny suggestions to try and possibly improove on what is a practically perfect case mod :D
    Godric does make a point about the jacks up top. Maybe painting the top rim of the jacks black would be good, that way people would still be able to see the color inside of the jack so they can still be easily identified without standing out so much.
    I also think you should recess the black panel that holds the exhausts into the case a little, say ~1cm. A bit of mdf could be cut out like a "C" but with the same curve as the exhaust panel, then painted black and used as a border to fill the ~1cm gap, so the mdf wouldn't really be seen from the outside. I don't know how quick it would be tho because i don't know how the black panel is attached :confused:
    Do these two things and chances are i will be coming over there to steal this case asap :jawdrop:
  13. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    There are small icons beside each jack, so he could easily paint them entirely red and still be able to identify which is which.
  14. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I was worried that the red would predominate the rest of the colors, but it turns out to be just the color of the 'interior' :) Keep it up!
  15. Guest-23315
    Guest-23315 Guest
    Perfect as usaual Paul :thumb:
    Got any plans on the loop going into this bad boy/girl?
  16. Burnout21
    9 Sep 2005
    well lets hope there will be lots of black delrin topped blocks in there..:D
  17. coolmiester
    31 Dec 2002
    Just a quick teaser picture with the front door on before the Coolermaster closing date in a couple of ;)
    Suggestions appreciated and taken on board but I’ve still got to get a complete system in there so not sure I’ll have time for much more tbh
    GaryP likes this.
  18. khanage0
    khanage0 Minimodder
    2 Sep 2007
    looks to me like ya nailed it man:thumb:
    anymore an it'll take away from the clean an simple effect i think
  19. Teyber
    Teyber ******
    18 Mar 2007
    beautiful! like stated above i think a "kompressor" sticker would look awsome, over the cosmos.
  20. Koradhil
    9 Nov 2004
    There's some things I'd done differently, but...
    "Overall, this is a kickass product" :D
