Project Crystal Meth
Discussion in 'Project Logs' started by Lon3R, 11 Jun 2004.
  1. Lon3R
    Lon3R What's a Dremel?
    8 Jun 2004
    EDIT:
    black and white theme with some arcylic being used and prolly some mesh , Liquid cooled side and top window .
    block to be used Dtek Customs TC-4
    Hydor L30
    chevette heatercore
  2. Lon3R
    8 Jun 2004
    sorry for the big pics i thought i had them resized correcty.
  3. Lon3R
    8 Jun 2004
    once i get my board back from RMA i will be savin up for my TC-4 block with a HYDRO L30 pump and w/e rad and stuff illl find.
  4. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    So are you going to resize them ?
  5. tekcajder
    tekcajder What's a Dremel?
    1 Mar 2004
    yea, they're a bit much.
  6. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    dont get a hydor pump :) i had one and tbfh it was crap :D
  7. Lon3R
    8 Jun 2004
    thanks for whoever edited my post. this log is gonna be going fairly slow coz i have no $$$ as of now
  8. asfd
    asfd What's a Dremel?
    29 Jun 2002
    What'S that green wire coming from the front panel?
  9. ClearCaseMan
    ClearCaseMan Acrylic GOD
    13 Apr 2002
    Might I suggest you contact C3 directly for those the ones you are going to get from frozen are designed for the c3 cases they will not fit a standard case very well. :worried:
  10. naelq
    naelq What's a Dremel?
    14 Oct 2003
    some note:
    > stealth pic within the thread plz! :wallbash: :wallbash:
    > resize pics a bit! ;)
    GOOD LUCK! :thumb:
  11. Lon3R
    8 Jun 2004
    thanks guys im sorta a newb to this project loggin .
    as the beast lol sits now as i wait for my RMA'd Epox board and my case to be painted for the most part
  12. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    when you resize the pics make sure "keep aspect ratio" is checked in whatever program you use.
  13. Lon3R
    8 Jun 2004
    Update
