Scratch Build – In Progress Project "Cube" - Small Update [December, 15]
Discussion in 'Project Logs' started by Pashtet, 12 Aug 2009.
  1. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    LOL
    I've been thinking on desoldering blue LEDs from the fan controller... don't even know :)
  2. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    my MOBO died! Damn that northbridge cooler! It killed my lovely mobo :(
    now I have to find some ways to get a new mobo for the project.
    if only someone from MSI or DFI could hear my prays...
  3. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    how did it kill ur mobo
  4. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    the northbridje chip is broken (@ bottom left corner) - during POST the speaaker beeps 1 long and 2 short (problem with video),
    i've tried 3 different videocards and tried to use integrated widoe, but nothing helped - the mobo thinks that's something wrong vith the videocard
  5. Validus
    Validus What's a Dremel?
    25 Aug 2009
    I never really enjoyed changing out motherboards, but when it's the part that fails I'm generally relieved. Of the other culprits (Memory, CPU, GPUs) the Mobo tends to be on the cheaper side of failures.
    BUT, it's never fun losing a component =^/
  6. cmd_
    cmd_ What's a Dremel?
    4 Jul 2008
    How the corner was broken? a wrong manipulation? mmm maybe you can use the warranty, try it. :duh:
    Ah! You're doing a great job taking these photos, attention to details like light, great! well light it's essential :p
  7. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    cmd_
    thank's bro!
    i think, the warranty is somewhere "out there" :)
  8. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Got some new goodies for me and for you, guys!
    First of all - new motherboard. It's an Asus M4A785D-M Pro.
    It's new, shiny, tasty, and it works :D
    Then, my order of the watercooling loop came ^__^
    Watercool HK 3.0 LC
    XSPC RS 240
    Phobya DC12-260
    Masterkleer 16/11 tubing and 13mm High Flow barbs
    So now, it's going to be a watercooled case :rock:
    Now I'm searching for the block for one of my video cards. They are both non-reference - Sapphire 4850 Vapor-X and Force3D 4850 black edition. I think, that EK waterblock will fit on my Sapphire with some modifications. The PCB's are identical. I think, that I can make it fit :)
  9. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Nice mod man. You look funny in those gloves on first page:)
  10. cmd_
    4 Jul 2008
    So sweet watercooling :thumb: What about a reservoir/fillport? seems challenging fit a thing to purge air in this small cube.
  11. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    Awesome work! :thumb:
    and cool kit. Keep up the good work.
  12. StEm
    StEm What's a Dremel?
    30 Nov 2009
    very nice work!
    will be doing a build in the new year, just wish i could afford water cooling, but its not gonna happen! looking forward to the finish, keep it up.
  13. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Thank's guys! I want to finish the case before Christmas
    I'm planning to make a res myself :blush: make a res even smaller, than swftech micro res :D
  14. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Update time!
    Got some free time and redid the frame. Now all the panels align perfectly.
    The only obstacle that separates me from powdercoating is countersinking the mounting holes on the side and top panels. Had no time to get the tool for it. After countersinking the holes everything will be ready for powdercoating "matte black"
    I've made a test assembly of the case, and the result is very promising :)
    Here are some pics of the case so far:
    Then I added a DVD drive to the front to make sure that the pump and res will have enough place: white cardboard box simulates the res :blush:
    So, here's where I'm now with the case. Tomorrow a waterblock for my videocard should arrive, and only powdercoating will stand between me and my new case :)
  15. stuartwood89
    20 Aug 2008
    nice to see this revived :)
  16. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    There's some really nice photography going on here :)
  17. stonedsurd
    11 Mar 2009
    Excellent photography and a very neat build!
  18. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Hope to finish it as soon as it's possible
    Thank you! I'm pleased you like my photo skills
  19. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Hey.Nice project.I like cube cases.One question.The rivets on the frame,do they let the side panels to fit correct?
  20. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    there will be recesses in the panels, and, btw I flatened the rivets so they stick from the chassis for about 0.25mm
