Case Mod - In Progress Project: Cuda 440 - Matching Keyboard 4/1
Discussion in 'Project Logs' started by TheGreatSatan, 17 Jan 2009.
  1. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    scoop turned out great
    could have mounted the dvd drive in the scoop.
    have it eject through the front opening.
    or can still chop the face off the radio unit lose one dial on each side,and mount it to a blanking plate, then attach the blanking plate to the front of the dvd drive and wire up one of the buttons to work as open/close.
  2. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    nice scoop this will fit nice on the top of the case :thumb:
  3. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    The scoop looks outstanding... although I can't help but think you should have went larger with the fan. :D
  4. Cheapskate
    13 May 2007
    Oh, Man. That radio is such a nostalgia bomb! It would be a shame if you couldn't mount it.
    Do you plan to black out the area under the scoop?
  5. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    No, but I will put in a LED fan under it, so it glows at night. Any thoughts on the color of light?
    There's still nothing inside, so that is still on the table. Although, I don't think much will be visible with that heatsink and motherboard in there
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    True, but a little bit of grey case will show. A quick spray of matt black will make it look more clean & tidy. I had a similar first reaction to the hood scoop, as in maybe that bit of orange under the scoop should have some black on it.
    I'd go for either yellow or orange or red or white with the case lighting. I'd try and guess which color your bro in law would want?
    Tis a shame about the radio being too wide, but that temp gauge is do-able and would look nice :naughty: Car cases are cool :rock: So what's the deal? Did you crash your bro in-law's car or something?
  7. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    You really should paint the inside of the case. It's almost just an automatic thing to do these days. Just use the flat black or something, anything is better than the gray.
    That thing is really looking sweet. I am a gear head so I like to see people incorporate car themes and pull it off nicely.
    I'll be watching.
    mvagusta likes this.
  8. TheGreatSatan
    5 Aug 2005
    I guess I'll do the flat black inside. I don't want red lighting, but yellow or white sounds good because it'll be brighter. I'm gonna cut out the bottom front so the white headlights shine through too
  9. TheGreatSatan
    5 Aug 2005
    The bezel is next. I want to mount the radio in the dual 3.5 inch bay
    Looking like this
    But first I have to trim it to fit the bay
    And that's where I got my first Cuda related injury
    And it's in!
    And then with the face plate. I still have to touch up the sides
    I still have to paint the bottom and inside with the flat black
    And cut out the front where the head lights go
    And get to the hood pins
  10. b00mb1ast3r
    b00mb1ast3r Testdrive unlimited LoVeR
    25 Dec 2008
    its a really cool old radio there is it going to be just for the look or will it do something like a fan controller or something?
    Great job
    // b00mb1ast3r
  11. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    A suggestion for the temp guage, would be getting its own bezel and mounting it on top of the case like an oil or fuel guage on a muscle car:
  12. TheGreatSatan
    5 Aug 2005
    That was suggested earlier, but I have a scoop and I'm adding hood pins, so I'm afraid it'll be out of place. I've looked online and I couldn't find any examples of that
  13. lost_modder
    lost_modder What's a Dremel?
    5 Dec 2006
    Mod is looking great. I was at Harbor Freight this weekend, and saw some neat chrome rings. Check them out here. Wish I had something that could use them. Good luck with the muscle build!
  14. mvagusta
    24 Dec 2006
    That trimmed radio fills the 3.5 bay nicely, and headlights would be very cool :rock:
    Yellow or amber would probably look a bit more retro/original, and white would probably look a bit more modern. Either one will be very good. Don't forget to light up the radio!
    Headlights did actually cross my mind aswell, and the size you've marked out is good :thumb:
  15. TheGreatSatan
    5 Aug 2005
    I'll be getting to those soon, but first I sprayed the inside till I ran out of paint. As you can see, I need to touch it up a bit more
    Here is a pic with the panel on
  16. mvagusta
    24 Dec 2006
    Very nice :clap:
    And btw, i'm guessing you're going to make some sort of wooden or plastic panel to fill the gap around the radio display/buttons area, but I just had an idea for the temp gauge...
    how about setting the temp gauge needle in the middle and lighting it's face, and then mounting it behind one of the grills, somewhere under the dvd area? If you've got more gauges then 2 or more would look even better i think!
  17. TheGreatSatan
    5 Aug 2005
    I will be adding a trim to the radio and I doubt I could pull off your idea on the guage
  18. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    I have a friend who is a big Hemi guy. I plan to show him this when you are done. Looks great so far!
  19. TheGreatSatan
    5 Aug 2005
    Next I cut out the headlights. Then I trace the holes on to the frame underneath
    (I also decided to add a 2nd DVD drive)
    After that I trace the holes on to the frame underneath
    ^^ I still have to paint the bottom of the case ^^
  20. BOBDBONE
    4 Feb 2009
    Now that is looking great!
    The black really helped on the inside.
    One other thing I would think about is to paint the top of the case black directly under the scoop. It might be just the flash on the camera but if you can see the orange in normal light I would maybe do the black. That way it helps look like the scoop is really legit and not just slapped on the top.
    This thing is really turning out cool. Makes me think I should have done one based on my Chevelle. But I don't want to be a copycat. I'll just drool on yours.
