Project: Dark Clarion - Update: 8-11-Side Window Done
Discussion in 'Project Logs' started by wo^tron, 2 Aug 2004.
  1. wo^tron
    wo^tron What's a Dremel?
    28 May 2004
    Should I remove the window tint? It would look like this if I did.
    Keep in mind the inside is still a mess and untouched so it might look ugly, but picture a clean, painted, etc inside. But here it is with normal light.
  2. wo^tron
    28 May 2004
    Also here is the lcd I bought and am in the middle of modding.
    I am going to grab a electronic box for the circuit boards, etc. I already chopped off the power supply piece and attached a male molex to it. Works great. Tested it with a portable dvd player.
    Starting to mod this into the front this week!
  3. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    omg that looks awsome!! did you cut out that side window?? great job!
  4. wo^tron
    28 May 2004
    Thanks. No, what I did was design a window I wanted. Then I drew it on contact paper. From there I cut it out and stuck it to the inside of the side of the case. Then I spray painted the entire thing.
    Once dry I pealed it off and voila, simple as that. :)
  5. wo^tron
    28 May 2004
    should I go with or without the window tint?
  6. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    I think tinted looks better. Just my $0.02.
    Keep up the great work! :thumb:
  7. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    cant make up my mind about the windowtint
    but i can make up my mind about the design
    and thats just plain GREAT :D
  8. Vox
    Vox What's a Dremel?
    7 Aug 2004
    window looks great nice idea :D
    are you going to paint the rest the same black or a different color ?
  9. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I like the window tint idea, kinda stealthy, can't wait to see this finished. :D Are you using the Sony brand monitor?
  10. wo^tron
    28 May 2004
    Yes, the rest is being painted black as well. There will be another window with tint on the top, and the other side will have another applique.
    Nope this is an offbrand. "intec" is the type. I cannot use the How To made for the sony one as its different so I am working on it myself. Getting the electronic box tonight to start the electronic work.
    Thanks for the feedback on the tint, I decided to go with it but get more lighting inside for when its on. Also in the mean time I am going to look for one shade less of a tint.
  11. z\\\\ffs
    z\\\\ffs What's a Dremel?
    2 Aug 2004
    omfg,very nice!
    keep :dremel:
  12. Rocket733
    27 Dec 2003
    I saw the intec lcds on ebay for a fair price, if everything works out well for you i might just take a stab at one. anyways can't wait to see the next update :D
  13. wo^tron
    28 May 2004
    Yeah that's where I picked mine up from. So far so good but be careful because I almost killed it when I attached the male molex because I connected the cords backwards! Unlike the PS1 mod for the cig adapter the wires to connect are the opposite. I connected them at first and smoke came out of the first circuit board. I was about to cry. lol So I switched them and to my surprise it still worked!!
    That is coming this weekend when i get off work tomorrow. The front panel and lcd area is my next stuff to do.
  14. Acid Burn
    14 Mar 2004
    keep the tint as long as you follow up on the theme :thumb: the tint looks sweet
  15. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    yeah tint looks good keep it, cant wait to see the rest,.....and the LCD i love lcd mods.
  16. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    good idea and keep the tint.
  17. OverFloW
    OverFloW What's a Dremel?
    30 Jul 2004
    yeah! keep the tint! :rock:
