project : dark UV energy
Discussion in 'Project Logs' started by megaglowz, 5 Jan 2005.
  1. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    name to be added to or changed soon...maybe...
    ok.....here we go
    the victim.....an old compaq server case
    pic of whole case.
    pic of case almost stripped.
    pic of stripped case
    pic of case next to a regular size case for refrence.
    i will be using only some of these..probibly 8 or so
    i have some cool blower motor fans....these things are way cool.
    and the two fans for the rear....hehehe
    mmmmmmm 192mm goodness!!!!!
    thats an 80mm right next to them mwahahahaha
    again, i will not be using all of those fans....just a few.
    the theme of the case will be very dark and powerfull.as if its creating its own lifeforce...
    youll see. :D
    the mod's will consist of the following.
    paint chassis black.....gloss black....realy gloss black
    paint fans uv purple.(all will be black with the uv paint from pc toys that you cant see till it's all lit up.)
    custom acrylic hard drive and cdrom cage's with black mirror accents and UV lit edges.
    LOTS of UV led lighting...i have 500 uv leds....hehehe
    full custom paint,with image on mobo side.pic will be posted later....
    an acrylic window with a lil twist.....to show off my acrylic expertise
    paint job colors will be hi gloss black base with purple and green in the case and in the pic on the side.
    will update with cuts on window when i get done
    this window will be VERY difficult to pull off.but i think i have my technique near ready....lol
  2. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    wow.. thats alot of fans.. can't wait to see what you do with this.
  3. huren
    huren What's a Dremel?
    14 Aug 2004
    haha i had one of those 192mm fans in an old server case of mine.
    gl with the mod i love the older server cases soo much height, just a pitty about depth.
    subscribes :rock:
  4. WaZzUp115
    WaZzUp115 What's a Dremel?
    12 Feb 2004
    Sounds like a cool concept :).
  5. Badaró
    Badaró What's a Dremel?
    3 Nov 2004
    When I saw the first pics of the case, I thought to myself "just another Server Case mod... so common here in Brazil." Then I saw the pic of a table with big Fans and Blowers and went "Whoa! Guess I was wrong! Gotta subscribe now!" :D
    Those pics show a lot of potential... what kind of hardware is going inside of it when finished?
    I'm looking forward to the next update... good luck!
    /subscribe
  6. keir
    keir S p i t F i r e
    5 Oct 2003
    around 8 fans! bloody hell man.
  7. Eran
    Eran What's a Dremel?
    6 Nov 2004
    wtf ?! how much fans ?!
  8. gigik
    gigik What's a Dremel?
    18 Aug 2004
    when i trying to overclock to the max i put on my case
    3x 92mm
    8x 80mm
    1x 60mm
    2x 40mm
    but u are MAXX :) you can fly with this :)
    500 UV leds, oh **** :) i have only about 100red and its coool
  9. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    With all of those fans, you could make your case fly...
  10. thavok
    thavok What's a Dremel?
    28 Dec 2004
    Not sure if its a First but this will probably be the first hovering case mod i've ever seen. :dremel: :D
  11. Isuo
    13 Oct 2004
    Wait a minute!
    All those fans cost more than 100euros alltogether.
    Where have you bought them btw.?
  12. Jipa
    5 Feb 2004
    IMO those look like used. I have about 30 fans and I've stolen them from old AT-PSU's and copiers etc. Those radial blowers are nice :) And allso those 192mm. use them!
  13. rowan57
    rowan57 What's a Dremel?
    14 Dec 2004
    Wowzer, like everyone said very cool, but watch out it dont end up like concorde, out of comission :p
    Good luck
    + Subscribed!
  14. Franklin
    Franklin Minimodder
    24 Oct 2004
    The guy says he is not going to put in all the fans that you see in the picture. I think some people only watch the pictures instead of reading the post.
  15. megaglowz
    10 Oct 2003
    planned cuts
    rough drawing of window.no its not suppose to be even.
    you will see why when the window done.
    drive cages
    drive cages planed cuts
    areas with xxxxx to be removed and replaced with plexi.
    drive cages will be black with purple uv paint on them.
    and this will be the pic on the other side.
    as soon as i deside if i want to have it airbrushed on or use the paper under paint method like they use to do on motorcycle tanks.
    (you would sand panel,glue picture on,feather in edge with bondo and paint your base color around the pic,then clear,clear,clear,clear...lol)
    i also have an atx mobo tray i will be integrating into the case as the mount points are way wrong..but the back panel where it will sit is perfect less a custom mother board I/O shield holder as the hole there is to big.
    ill probibly do that in plexi to.
    :rolleyes:
  16. megaglowz
    10 Oct 2003
    changed window...the more i looked at it the more it didnt go with what i wanted.
    looots of work there.... :rolleyes:
    ok this is the front
    this is the inside front.it has this thing in it...for the original hd lights to shine through.
    i took it off and mounted led's along it
    leds will shine out like this.(crappy paint example...lol)
    also will put leds here.
    that will light these
    nice and bright.
    as soon as i figure out how to wire all these up..ill take some more pics of it actualy lit...lol
    the way im going to do it is put a resistor on each led and hook them up along one long wire.correct??
  17. megaglowz
    10 Oct 2003
    bought them off ebay...they were 32$..lol
    i saw what was in it,i didnt realy want all of them but hey...32$ who was i to argue.
  18. megaglowz
    10 Oct 2003
    nope..there all brand spankin new :hip:
  19. megaglowz
    10 Oct 2003
    this one is preaty nice for an old case..its about 2 inches deeper than a standerd midtower
  20. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I love that case megs! its an awsome tru modders case, not just some glammed up alloy trinket that gets filled with lots of epensive bling parts and and is called a mod,
    The fan collection make me drool ! and if that side panel cut ends up looking as good as i think it will, its ganna look freeken awsome :rock:
    i'll stop yabbin and let you get to it!
    Update!
