project : dark UV energy
Discussion in 'Project Logs' started by megaglowz, 5 Jan 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I can, and you may not be able to accomplish what you're trying to do without a vaccuforming table. Hot acrylic is the consistancy of taffy (toffee) and isn't going to fill holes easily.
    You may however be able to coax it to conform a little bit with leather gloves or some metal tongs.
  2. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    practice peice.
    ive done this befor so i know it will work
    i work in the glass industy so i think it will turn out cool.
    and i use a leather shamy for the forming :thumb:
  3. Captain Slug
    25 Nov 2001
  4. megaglowz
    10 Oct 2003
    hmmmmm....i just might do this..... :dremel:
  5. Pelihirmu
    Pelihirmu What's a Dremel?
    2 Jan 2005
    :clap: This mod is looking very nice :clap: I like that skull and UV lights. Are you gonna paint that case black? Black would be best color. :)
  6. The Lost Monk
    The Lost Monk What's a Dremel?
    16 Sep 2004
    i like the skulls, this ting is going to be bad a**. Im going to be keeping my eyes on this thing :thumb:
  7. quadbox
    quadbox What's a Dremel?
    13 Jan 2005
    the skull was nice i really like it... :D if you want to paint a black i would recommend to put some effects like a flat or mettalic red paints. :D :rock:
  8. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    ah hah! Exactly what I thought you where going to do. That window is going to look so awesome when its done.
  9. BaDDaSS
    BaDDaSS What's a Dremel?
    30 Oct 2002
    wow, i don't think I have seen a 3D window before :)
    mod-on! :D
  10. Shadowcaster
    Shadowcaster What's a Dremel?
    31 Dec 2004
    It makes sense now why you cut those long lines down the framing of your hole on your panel, so they can bend out. Nice job.
  11. megaglowz
    10 Oct 2003
    small update....what can i say...its cold right now.
    but im in louisiana so it wont last long.
    i went and picked up my "intake" today....hehehe
    WOOT FOR THE STEALTH INTAKE... :eeek: :eeek:
    its the air vent for the 2005 mustang...hehehe
    perfict fit.... :eek:
    where it will be.
    ill cut the hole this weekend and update again!!!!!!
  12. munky
    munky What's a Dremel?
    27 Jan 2005
    looking good, I like the a/c vent idea, very nice touch. :rock:
    One question though. Have you tried those UV led's to see if they make UV reactive things react?
    I have a few UV led's in my case, and some UV ccfl's. The led's dont actually give off UV light, just purple light. The only thing that makes the UV things react is the ccfl's.
    This is a UV reactive fan with 4 'UV' led's in it. They light it up purple, but its a blue fan, and the tubes that have a slight purple glow to them, blue too.
    This is the same fan when I switch on my ccfl's. The tubes and fan actually react and glow, not just reflect light.
    Its not that they are cheap led's either, they are these ones. (clicky linky)
    sorry, not meaning to hijack the thread, the purple light is nice, but if you want blacklight and UV reactive glow then stick with ccfl's imo.
  13. megaglowz
    10 Oct 2003
    your not hi-jacking!!!!!!
    and i dont think i am going to have a problem with lighting
    as i have 500 of these...3000 mcd UV Violet 5mm LED Lamp..hehe
    no im not putting in 500 led's...just about 120...hehehe
    and these things are BRIGHT!!!!!!
    put my ccfl to shame!!
    specs on the led's!!!!
    Emitted Colour : ULTRA VIOLET
    Size (mm) : 5mm T1 3/4
    Lens Colour : Water Clear
    Peak Wave Length (nm) : 380 ~ 400
    Forward Voltage (V) : 2.8 ~ 4.0
    Reverse Current (uA) : <=30
    Luminous Intensity Typ Iv (mcd) : 2000 ~ 3000(Max)
    Life Rating : 80,000 ~ 100,000 Hours
    Viewing Angle : ±10°
    Absolute Maximum Ratings (Ta=25°C)
    Max Power Dissipation : 80mw
    Max Continuous Forward Current : 30mA
    Max Peak Forward Current : 75mA
    Reverse Voltage : 5~6V
    Lead Soldering Temperature : 240°C (<5Sec)
    Operating Temperature Range : -25°C ~ +85°C
    Preservative Temperature Range : -30°C ~ +100°C
    *edit to add specs.
  14. munky
    27 Jan 2005
    ooh, never thought I would say this about an LED, but nice specs!
    Safety in numbers :rock: me likey :D
  15. Firehed
    15 Feb 2004
    that's BRIGHT for UV LEDs. The ones I'm looking at are ~500mcd. Where'd you get them? And are they really UV or are they more purpley (the LSDiodes ones say 395nm wavelength so we're in the same range anyways). Of course I'm looking for more just blacklight effect and not color at all and let the UV stuff take care of that.
    actually... care to send a few dozen my way? :hip: :thumb: :naughty:
  16. megaglowz
    10 Oct 2003
    there very bright purple and thats what i wanted
    and they light up uv things from across the room... :eeek:
    i got them from besthongkong led on ebay...but i cant find there store at the moment.
    i bought them 5 months ago.
  17. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    wrong on UV leds not working.
    What do you think makes UV LED fans light up?
  18. munky
    27 Jan 2005
    look at the fan in the pics above!!
    Does it look like those 'UV' led's are making it react and light up?!
    NO!! but they aren't the same specs, all I was saying was that SOME claimed UV led's are actually not UV, just purple! :rolleyes: :miffed:
  19. Tulatin
    16 Oct 2003
    right, misread. Sorry.
  20. megaglowz
    10 Oct 2003
    ok weather is FINALY :clap: going to get better here in the next week.
    :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
    i will be cranking up again this week and posting more pics.
    still have to figure out how to do that front intake and keep the chrome ring intact(ie no bondo can be used :sigh: )
    i got all my uv lighting in,and will be getting the hardware soon.
    will be an amd 64 based sys.
    LATER.
