Project 'Death by Caution', 7/March/07
Discussion in 'Project Logs' started by El1m1nate, 7 Mar 2007.
Polish the bottom of the case?(so underneath leds reflect).Main case polished 2 times
Poll closed 11 Mar 2007.
  1. None
    0 vote(s)
    0.0%
  2. 1 Polishes
    2 vote(s)
    25.0%
  3. 2 Polishes
    6 vote(s)
    75.0%
  1. El1m1nate
    El1m1nate What's a Dremel?
    6 Mar 2007
    Well im gonna start by saying this: its my first mod!!!
    Yay lets get right into it.
    My mod is going to be based on the radioactive sign and the 'caution' strip:
    This was roughly done in paint!
    Though, I hope it will turn out great :D
    So i bought my self a Dremel and got started on the crappy run down case i had
    This is the Dremel im using, pretty pro eh?
    and we have the case
    nothing pretty to look at.
    sorry about the angle
    Okay now the story with this hole is: I was bored, i had a spare fan(small) and i had a drill. i did this about a year ago and now this hole looks bad.
    so what did i do? use the dremel of course!
    look at that hole!
    Then i took out the rivets. the trick is to get the drill bit thats just a bit bigger than the hole for the rivets. then just drill it and it will come of.
    I though that i might start with something easy, so i took of the front panel (after drilling out about 20 rivets then realizing it wasn't riveted on!)
    ok here is the front
    then i cut out the usb port/bay
    At this moment my idea was to put a vertical cdrom drive somewhere on the front case.
    here is the back of the front ... lol
    i cut 2 peices of that wood that has several sections (forgot the name)
    then masking taped the wood to the plastic(for drilling[ i havent bought a vice yet!])
    i used some screws that i had left over:
    (close up)
    as you can see i cut/dremel off the ends so they wouldnt interfere with the cdrom drive(they still do but the drive fits)
    ok so i mounted the drive
    then, with my trusty dremel, i cut out the front
    and also sanded it
    since you cant reach the button im going to solder some wires onto the drive
    the round design didnt look to good so i cut it a bit
    ok thats what i did in the past 3 days... ill have more for you soon.
    Thanks 4 reading :D
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Looks good especially for a first time, can't wait to see more :rock:
  3. Jipa
    5 Feb 2004
    The fan hole doesn't still look too perfect, but definitely better than the old one.
    The idea of the optical drive is neat! I hope it works too :)
  4. Infenro
    Infenro What's a Dremel?
    7 Oct 2005
    Reminds me of my first mod went for that exact colour scheme, I love the hazard look and industrial look on cases, and i shall keep track of this as im liking the whole drive location i think thats wicked.
    Good job
  5. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I really like that idea you're doing for the CD-ROM... interesting. Do you plan on putting something behind the tray so when it's in the drive you're not looking into the case?
    You've got a nice project on your hands for your first case.. good luck!
    Not quite sure about the hole on the top though.. I've tried using square holes for fans and was disappointed in the end. Myself in your case I would cut out a top window and add a fan to that, that way if you screw up the fan hole.. you simply replace the piece of acrylic, I mean you already have the grooves to guide you there! Here's what I did that helped me ALOT when I was cutting out window panels with rounded edges.. use a bi-metal holesaw that is the diameter of the curved corners and drill those out first. Then use your nice Dremel with a reinforced cutoff wheel and slowly join the corners. Use a file and some light sandpaper to finish the edges. Also be sure to apply masking tape everywhere when you're cutting. It could save you from a couple scratches. I often put one layer everywhere and a second layer around the edge I'm about to cut off for that extra layer of dremel-slip protection.
    Good luck and keep at it!
  6. V3ase
    V3ase What's a Dremel?
    25 Jan 2007
    That cd tray is GREAT , i see first time somethink like that .
    Cant stand 4 next pic.
  7. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    Wow, I'm looking forward to how this will look in a more finished version! There are quite a few nice ways this can be designed =)
    Keep it coming!
    //ottzen
  8. El1m1nate
    6 Mar 2007
    Yeah im going to put an old CD-ROM drive back casing which will be polished!
    And in front there will be a motor operated mesh door :D
  9. El1m1nate
    6 Mar 2007
    ok im having a little trouble! there are 300+ viewers!!! and my photo buckets, monthly limit is already 2%... it hasnt even been 24 hours! lol does anyone know anything else i could do??
    Thanks
  10. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    hows it goin 'El1m1nate'? Or should i say fataL? Or even.. RAFAL Well.. ur sitting next to me anyways..(skool) so ur gunna know what im typing lol.. well i like the idea of ur drive.. i might incorporate it into mine but i cant.. maybe in the future.. ( im posting my mod now or at lunch ) ye.. anyways.. ill cya 2night for modding partay.. =O
    rofl..
    anyways.. have fun in skooll.. (sucker)
    Rage.
  11. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    http://pages.google.com/
  12. El1m1nate
    6 Mar 2007
    UPDATE 8/March/07
    Ok im back, a meer 12 hours later! and i have some more pics!!!!
    Though i had a bit of a stuff-up lol.
    as seen in my last post with pictures, i cut out that cd-rom drive with the dremel but i cut out an important part that didnt let it read the cd (ie the thing that turns the cd wouldnt come up).
    So i just got another cd-rom drive out and began modding that(last year sometime i found a whole bunch of cdrom drives [when the local tip collection comes around] so i just took them :D with Rage.(dot) lolz)
    I did a light spray paint of the whole front, just to see if it would look good all in black
    so this is what i have done :
    i have decived to put a modded hdd on the front near the top ie where the drive bays are!
    so here is my 10gig WD hard drive and im going to put a window in it!
    and ive made a clean room for the hard drive.
    Clean room/hdd mod articles
    I will post photos of the finished mod in 6 or so hours and maybe even a video
  13. HoffmanMyster
    HoffmanMyster What's a Dremel?
    31 Jan 2007
    Wow, I really like this mod, Im probably gonna end up stealing your idea, lol, hope ya dont mind, Ill give ya credit though, but its just so cool, I cant not make a cd drive like that...Im really liking this mod, and will be watching it closely. good luck with the mod.
  14. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    Hoffman. use. more. Periods. Period.:D
    hmm, again i wish you good luck on the HD, all the best and hope it works.
    Aiee on the front of the case tho! make sure you fix up the paint and spend WAYY too much time on details. Horray for modding!
  15. El1m1nate
    6 Mar 2007
    Sure u can use my idea.
  16. El1m1nate
    6 Mar 2007
    yeah i will spend some more time on it, im just applying the spray paint to see how it lookz.Period. Later today i will have more pics!!!!
  17. HoffmanMyster
    31 Jan 2007
    Hey, I already told you, I use "..."'s instead of periods lots of times...its just what I do...so really Im using more periods than you, ever think of that?
  18. El1m1nate
    6 Mar 2007
    HUH now i have more periods!!!
  19. HoffmanMyster
    31 Jan 2007
    He was talking to me cause I dont use that many periods...it wasnt anything you were doing, dont worry.
  20. El1m1nate
    6 Mar 2007
    lol spam my thread why dont you!(lol plz dont leave :D)
