Scratch Build – In Progress Project: Der_Meister - custom alu case *Epilogue Nov 8th, 2007*
Discussion in 'Project Logs' started by jokkos, 20 Mar 2006.
  1. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    LOL! I would love to see the project log for that!
  2. ComputerKing
    8 Sep 2006
    LOL! yup that old CRT only can be a Fish tank, That will be good use for it, get for your self a 19" LCD they are cheap now :D
    good luck and wait to see what you will do, Good luck.
  3. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    19"??? That's not Der_Meister style :naughty:
  4. ComputerKing
    8 Sep 2006
    ..... You make me feel that your style is 30" Dell... Come on you make me feel **** with my 19" :( :waah:
  5. jokkos
    10 May 2005
    I decided to go for the active 240 rad. I've just ordered part of the stuff I need together with the last components for my HTPC. Next week I'll order the rest.
  6. ComputerKing
    8 Sep 2006
    Nice I'm waiting, :D Good luck.
  7. jokkos
    10 May 2005
    The story continues – watercooling stuff arrived
    After a few difficult deliveries, all the stuff I ordered and need for the changes I’m about to make has arrived. Work will probably start in a week or so, I’m going to install my HTPC first so I have a computer to process pics on while Der_Meister is on the operation table.
    Here are a few pics of the new stuff…
    Two chipset blocks…AquaComputer Twinplex XT in the same style as the CPU waterblock
    Another Airplex EVO 240 rad and mounting plate. This will go inside the ‘box’ under my monitor. The mounting plate is handy to, well get it mounted of course. More detail on this later on.
    I also bought some fittings…
    Because watercooling the NB means I have to take off the heatpipe array on my mainboard, and this will leave the Mosfets bare, I needed a solution for them. I found these nice heatspreaders…
    Some fans I have lying around, they will be put to use. The Noctuas will go on the external rad. It won’t be visible so their colour doesn’t matter. I’ll try the Scythes as replacements for the fans on my internal rad. They should be a lot quieter than the Noiseblockers I’m currently using (at roughly the same CFM).
    I needed some more tubing as well. It seems to be more whitish than the tubing I currently have, although it should be the same stuff. I also bought two quick-disconnect fittings for the external assembly. The blue spiral is Smartcoil, should be UV-blue but will probably not be used. I just bought it in case I can’t put the tubing without the risk of kinks. It seems like good quality stuff, pretty stiff but still very bendable.
    This is the current plan of the new loop. Ignore the tubing you see, just look at the lines I added.
    The pump is at the bottom right, so the loop goes: pump – GPU – CPU – NB – SB – external rad – internal rad – Aquatube – back.
    I like it this way, the placement of the pass-through fittings to the outside of the case means I can put the tubing that goes out and the one that comes in and to the internal rad out of the way. Much better than my previous plan (see previous post) where everything would be cluttered together.
    A couple of pics that don’t have anything to do with Der_Meister, but are a bit related. Here’s the HTPC case I bought: Silverstone ML02. It looks really really nice. Would not look back next to Der_Meister, it’s completely my preferred material and colour scheme. The front is made of shiny plexi, on the right there’s a VFD-display.
    Another one.
    The HTPC is a different story than the one in this thread so that’s all I’m currently posting about it. If you want, I can post some more pics of the hardware and the installation. Just let me know, I don’t think it’s worth starting a thread for.
    Finally, because you were all so picky on my CRT after my previous post that contained pics of my desk: here’s a pic of the box of the monitor I’m currently using (the pic of the screen itself was a disaster – it’ll be something for later on). Samsung 215TW.
    Stay tuned!
  8. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Plans look good. Looking forward to seeing it done!
  9. Guest-23315
    Guest-23315 Guest
    ^^ Agreed.
  10. Brett89
    Brett89 Minimodder
    15 Dec 2005
    How appropriate, as I click this project log, Los by Rammstein comes on my iTunes. But anyways, looks awesome, i love those waterblocks, b-e-a-utiful
  11. razzta010
    razzta010 mod addict
    9 Aug 2007
    "Because watercooling the NB means I have to take off the heatpipe array on my mainboard, and this will leave the Mosfets bare, I needed a solution for them. I found these nice heatspreaders…"
    Hi mate, where did you buy those heapreaders? and the pass pass-through fittings?
    Can´t wait to check the temps you will get!!!
  12. jokkos
    10 May 2005
    Hi,
    the heatspreaders are made by Microcool, I bought them on ebay. They have 4 types: chipset, PLL, mosfet and micro. I bought the PLL and not the mosfet type, since those are small (for video cards). The PLL's should be a nice fit. All the dimensions of the 4 types are on Microcool's website www.microcool.it
    The pass-trough fittings come from a german webstore, www.heranke.de
    They have good prices for most of the common fittings.
    I can't wait either to see the results :D
  13. ComputerKing
    8 Sep 2006
    I SWEAR German Water Cooling Gear RULE! It's hot, Strong, Nothing wrong with it! It's same mercedes enguine water cooling!
    I love the new LCD ;) Well done now this is The best from Zero to top Project I ever saw :D Can't wait to see the new water cooling
  14. jokkos
    10 May 2005
    thanks for the comments guys. Hi ComputerKing, I was wondering when you were going to post :D Welcome back :thumb:
    I'm currently building the HTPC. All is going well. I guess I'll start on the external rad next week. I'll keep you updated of course!
  15. ComputerKing
    8 Sep 2006
    WOOOT you are my hero :D sorry That I didn't post :( I was have some shits going with me but I kinda got throw it :D
    Don't worrry Computer King IS BACK :rock:
    I love that HTPC I wish if you will mod it little bit :cooldude:
  16. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Looking forward to the update and nice to see all the Aqua-Computer gear! :thumb:
    Thats what is cool about these projects. We have the option to do a "rev.2" and reinvent what we have.. And thus the ability to make something great even greater!
    MS
  17. jokkos
    10 May 2005
    well, some unexpected things that came along in real life kept me from really starting on the upgrade. I did take apart the wooden box under the monitor; the top piece will be re-used but a part off it needs to be sawed off, and new side pieces will be sawed from a left-over part of a furniture panel.
    To make sure the cuts are as straight as possible, I'm getting help from a friend who owns a decent table-saw. Probably somewhere this week-end or next monday.
    Pics will follow, I just wanted to report the 'official' start :D
    Since Der_Meister will need to be opened up and the mobo taken out to add the extra waterblocks, I'll probably take the opportunity to do a clean windows install once it's back together. So it's time to backup as well. Also need to swap 8" screens (the touch screen one I have now will be used with the HTPC, I'm replacing it with a non-touch screen one, since the touch screen software was very very confused about my three screen extended desktop). And there are a few other things I would like to do before opening up the case. So I'll be working 50% on that and 50% on the wooden box and the external rad.
    Stuff to do on the wooden box / external rad:
    - saw the pieces with my friend's table saw, adjust them if necessary
    - assemble the pieces and add some inner woodwork (basic stuff, the box is wider than the rad so I need to add a support for the alu angle that will hold the rad grille)
    - sand down the top piece, fill up obsolete holes and scratches, prepare to paint
    - make alu pieces to hold the rad grille, tap holes to attach the fan grille
    - paint the wood
    - attach the alu pieces
    - rinse the radiator, add fittings, sleeve the fans, prepare the wiring from the fans to the case
    - attach fans and radiator
    All in all, this won't take too long I guess. :D
    Unless I start doing extra stuff of course. Like, the wooden box up till now had a few compartments made of plywood underneath the top where I put my pens, controller for my speakers, etc. I don't think I'll put them back in because they would hinder the airflow coming from the rad. I could put in something made of Mesh though, although I don't really need it. Oh well, let's see what happens next week...
    See you soon with an update and some pics!
  18. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Can't wait!
  19. Sobek
    Sobek What's a Dremel?
    27 Sep 2007
    hi jokkos,
    first of all, sorry for my bad english...i`m from germany...
    found your work-log, - guided by fortune :D- yesterday, and now im done. i have been gone through the complete log ( an i really mean the c o m p l e t e log :jawdrop:).
    going sad when i thought its going to be over and finished. but now tadaa... your on the road again...
    so i signed in to let you know that you deeply impressed me. that was an outstanding good work and come not only to a sweeeet case than a nice piece of art!
    i love the "blue look"! blue is my favourite too!
    so keep on going!
    praying for an update!
    Sobek
  20. Guest-23315
    Guest-23315 Guest
    Glad to hear this project is still moving on as its one of my favorite ones. :thumb:
