[Project] Digidice @ Digiblack DONE
Discussion in 'Project Logs' started by FrODO_bAGINAS, 19 May 2006.
  1. FrODO_bAGINAS
    FrODO_bAGINAS What's a Dremel?
    19 May 2006
    Hi!
    I'am from Portugal and i will show what a did with my sff.
    If exist errors of english in the thread, the guilt it's of the translator :D :D
    The ideia is to put watercooling inside the case, and make some modifications.
    A review, to see the box from the beginning :
    http://www.digit-life.com/articles2/abit-digidice/index.html
    In the beginning it was thus, with that one cut made for a radiator 2*80
    Later i see ones mods in the Internet that had made me to change project, and begin to make the cuts on the top and on the sides
    This was the case for the 51/2 drives. I cut to inside have more space in the box.
    The grate of 120 of aquacomputer that I used to fix the radiator of 120 in the box. I cut bars for the airflow either bigger.
    This was my computer on the moment. :blush:
    The front of the box painted
    The waterblock painted
    The grate finished, without the bars
    One side of the box have one puncture, therefore I had of covering with cold weld.
    The cage 51/2 folded
    The front with the buttons.
    The original acrilic was striped , therefore I had to make a acrilic the measure and necklace with superglue.
    As it goes to be
    how to make a retention for the block in acrilic. I have used the retention of cuplex evo to to serve of mold.
    Xarammmmmmmmmmm
  2. FrODO_bAGINAS
    19 May 2006
    I took off the settings for fan in the radiator
    The sandpapered radiator already, and prepered to be painted.
    The primed base already and with the cuts made for the connectors of the radiator .
    The 51/2 prepared do be primed.
    try glue the acrilic and the top with silicone. In the top i had to use superglue.
    The base painted.
    Painting the connectors and the base of the waterblocks.
    The grate fixed in the box.
    Trying to fix the fan with the radiator.
    The waterblock's finished.
    The radiator finished with net.
    New fan in the power supply.
    A view inside the box of the radiator fixed.
  3. FrODO_bAGINAS
    19 May 2006
    The new place for the hrad disk.
    Preview
    Make a puncting to put water in the system.
    I ordered to make vinis and had been excellent
    Area that doesnt be painted covered.
    cut for new fan made only lacks to rasp
    Same photos of pump done
    now I am stopped because the pump had an escape and have to close the escape.
  4. Guest-23315
    Guest-23315 Guest
    sweet-
    i think escape is meant to mean leak...
  5. soldier35
    soldier35 What's a Dremel?
    19 May 2006
    Correct
    Força aí
  6. FrODO_bAGINAS
    19 May 2006
    Update:
    The powersupply done
    A peace of acrilic painted.
    the drive painted and the pump in place
    I had a leak :naughty: so a have to to strengthen with cold weld.
    I had to do a new support to the pump. I has used a peace of acrilic, and do a punctures.
    Testing the pump
  7. FrODO_bAGINAS
    19 May 2006
    update:
    The support to the pump sandpapered, and the excess of cold weld removed.
    My work place, with cold weld.
    Some punctures covered with cold weld.
    All the excess of cold weld removed.
    I had used vinyl to cover the pump, thus see more perfect.
    Covering some punctures with silicone.
    Xarammmmmmmmmmmmm
    Testing everything in the case
    I had to cut some parts of the psu fan to dont touch in the motherboard components
    Same photos
  8. FrODO_bAGINAS
    19 May 2006
    Hi!
    The project are done.
    I have to buy a good camera and take some good photos, this ones sucks :D
    Some photos
    Good mods!
  9. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    GREAT!!!! :D
    water cooling in a small pacage. this must be great for home cinema. complete silence :D
    correction
    This project is done
    I have to buy a good camera and take some good photos, this one sucks.
    VIVA AO MODDING PORTUGUES.
    *hurray for portuguese modding*
  10. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    Tha looks nice... although could you explain that pump a bit?
    I see 4 hose connections, but i couldnt work out how that worked....
  11. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Its a nice case. Althought pics explains almost all, comments all always welcome, forgot if your english is worst or better, we are all from everywhere in the world, don't worry about it.
  12. FrODO_bAGINAS
    19 May 2006
    Tanks to everybody.
    Ok, i will coment the photos, using the translator :D .
    DXR_13KE
    yeah. yeah. yeah. Portugal é que é lolololol :D
    The pump iam using is the pump of thermaltake aquarius kit.
    Two conections, is to the pump and the others 2 is to the resevoir.
    I had use the pump to be a reservoir to, so i had joined the two conectors.
    I hope i had explain you question.
    Good Mods
  13. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    It looks very elegant...good job!
