Case Mod - In Progress Project .::District 9::. Cooler Master 840 ATCS Case Mod
Discussion in 'Project Logs' started by mnpctech, 24 Dec 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This Case Mod was done by bit-tech's MOTM Sponser, Mnpctech!
    Customize your PC or window with custom Stickers from Mnpctech HERE
    This PC is for the Cooler Master suite at the 2010 CES show. It will be showcasing a Heat Sink design to be announced at the show.
    You can watch video in HD here
    Final photos
    Mitron Interlink Fan Controller was cannibalized and mounted in the rear of the chassis.
    The prawn canister resides in the front 5.25 bays, under a single DVD drive.
    MNU logo painted on the optical drive face. Did Christopher steal this to access archived files?
    Flexible conduit seen through exploded hole in the right side panel.
    The Prawn lettering was hand painted. You can download the font, http://www.district9movie.com/downloads/fontdownload.html
    Rusted and scratches were hand painted on the exterior.
    The theme for this PC was inspired by this Prawn Arc gun.
    The canvas for the "PRAWN" PC build is the Cooler Master 840 ATCS
    Log Update 10/02/09
    CNC milled front intake plate with "DISTRICT 9" theme
    I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
    The window will be fastened with 1/4" socket head screws, for reinforced armour look
    Using center punch to mark each fastener hole.
    Using 3/8" drill bit
    Using wire cutter to make cracks around the hole
    Etching Rotary Tool (or Dremel) Engraving Bits
    Using the dremel to emulate some cracks
    I'm adding bullet holes to the case too, so I drilled holes in the 840's aluminum panel. I then used a tin snip and needle nose plier to cut and rip the 3/8" hole open
    Exploded hole in right side panel.
    One of the easiest steps to fit this theme was replacing the OEM handle on the Cooler Master 840 motherboard tray with machined aluminum handle. I had one spare handle left over from our previous stock. The new version has been revised with rounded finger grips, as shown here, http://www.mnpctech.com/MnpctechBillethandleGrooved.html
    Diamond Knurl Computer Case Feet
    http://www.mnpctech.com/Aluminum_Computer_Case_Feet.html
    1/4" thick acrylic sheets as the reinforced segments of the side panels.
    The "Pumpkin" Orange color was done first. The perimeter of the " exploded hole" will be airbrushed by Brad with a burned surface effect
    The 840 normally comes with Black frame 230mm fans, no leds.
    side panel
    Left side panel, the hole will have burned effect airbrushed on later
    Flexible conduit cables!
    Here is some screen shots taken from the movie trailer on Youtube. I think it's important to have the prawn canister implemented into the case. If Cooler Master had requested watercooling, it would been fun to make a reservoir based on the canister, but the system will be air cooled.
    Original Prawn canister from a screen shot taken from the movie.
    My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover.
    Once it's painted and the window is darkened a bit, it should look eerie.
    canister back cover
    for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic, http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html
    Prawn canister window was tinted like original
    RUSTED GPU!
    Watch E.E.L. Embiense demonstrate how to use the Sophisticated Finishes products for adding a rust effect to your Mods.
    http://www.youtube.com/watch?v=26Ud9T-doAc
    I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get.
  2. mnpctech
    21 Apr 2003
    The lighting needs to be dimmed down a bit,for a more eerie looking feel
  3. Colossous
    Colossous Minimodder
    28 May 2007
    Top notch as ever duder :thumb:
  4. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Have been following it on TMD forums. Looking good Bill!
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    This is just a thing of beauty!
    I love the rust! :thumb:
  6. xDeaDReckoninGx
    xDeaDReckoninGx ****ing delete my account,
    22 Oct 2009
  7. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    very nice job... looks awesome
  8. Bu Do
    Bu Do Crazy Kiwi
    25 Dec 2009
    Love this mod :hip: Keep it up Bill.
  9. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    I love the detail you put into all your builds Bill :)
  10. mnpctech
    21 Apr 2003
    Thanks for tuning into this build and commenting!
    MERRY CHRISTMAS!
    I've gotta keep plugging away at this, so it's finished in time to be shipped to Vegas for the 2010 CES.
    Whats this? It's a cannibalized Mitron Interlink, 3.5" bay fan controller
  11. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    I am ashamed at you. Your American and faked bullet holes.
    I am sure if you went down a firing range some one would help you out, could have made it interesting by marking the location of the desired hole and let them tune there target practice abilities. :D
    Except the fact that the acrylic would have pretty much been totally ruined by a single shot causing massive cracks potentially splitting the whole window into several pieces....
  12. stonedsurd
    11 Mar 2009
    Sorry, had to be done.
    But I agree. I would've shot the sucker, just to see what would happen :D
  13. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    This is a valid point. I had a thread in the modding section about shattered acrylic. I took my .22 Ruger and shot some 6mm acrylic and it held perfectly well and the results were fantastic.
    .22 subsonic hollow-points silenced. Might incorporate it into something some day.
    Liking the look of this build as ever Bill :thumb:
    Javerh and Burnout21 like this.
  14. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Ooooh very nice indeed!
  15. badje
    badje boni
    30 Oct 2006
    Lol naloc good point, like ur acrilic panels to!
    OT: even if the bullet holes aren't real, they still look very nice.
    That prawn canister looks nice too, the gray color is cool.
    keep on modding
  16. Burnout21
    9 Sep 2005
    +rep
  17. mnpctech
    21 Apr 2003
    Creating the illusion is more challenging and more FUN :thumb:
    Mnpctech Painter, Brad Galvin starts the transformation from pristine to weathered and dilapidated. He starts by creating the illusion of a scratched-up exterior, imagine Christopher dragged his computer in the gravel. Did he have to wrestle it away from somebody at one time?
    The Orange & White exterior finish has been scratched done to the bare metal. This is done by hand using enamel "One Shot" Silver paint and a paint brush.
    Notice the paint is chipped around the bullet holes.
  18. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Wow, looking good! (As usual!)
  19. mnpctech
    21 Apr 2003
    Thank you for commenting Pure! Brad has painted a variety of Prawn insignia, language and graphics by hand. The bolts are given weathered effects. Christopher left his PC out in the rain. ....Acid rain perhaps?
    There was an expolsion in the right side panel at one time.
  20. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    DUDE!!! that is insane, love it!
