Modding Project: DIY CNC - V3 Reinforced Z Axis
Discussion in 'Modding' started by lenne0815, 16 Dec 2009.
  1. JB S
    JB S What's a Dremel?
    22 Apr 2011
    All I have available for testing is a 500W drill press with max RPM of 2800. But I get good results in aluminium and MDF is no problem. Having the right tool design was a bit tricky (for chips evacuation) but it can really make a difference.
    Anyways, thanks for your answer, I'll keep an eye on your posts to see your feeling about your new router motor.
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    eugh 1mm are evil! cant wait to see how you get on with the suhner :)
  3. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    AHHH was i mistake, meant 8mm bits ;)
  4. Editor22
    3 Jan 2009
    Makes more sense now why you would need the extra power :D
  5. lenne0815
    4 Jul 2009
    What im reallt trying to do is 19mm Chipboard ( Vakuum clamped ) with a 12mm diamond bit in one go :D i hope that works out alright !
  6. lenne0815
    4 Jul 2009
    Finally the aluminium Profiles arrived !
    Put in another support at the bottom
    Some more cutting
    Before
    And after !
    I didnt connect the profiles yet i just put them there ti figure out what ill need for connecting them
    Hmm, whats the best way to mount it ? :D
    Cutting down the motor clamp a bit
    and another toy arrived !
  7. Yaka
    Yaka Modder
    26 Jun 2005
    man im jealous, how much does it wigh btw and what did you lift it with?
  8. lenne0815
    4 Jul 2009
    :) im not really sure, i think its around a ton, we have a huge Steel H beam with an old crane trolley connected to it, so we just lifted it and pulled the trailer away.
  9. lenne0815
    4 Jul 2009
    Did some work over the past few days :)
    Bought some screws for the new machine bed and some parts for the suction
    Connected the new long profiles to the supports underneath ( that took ages, had to drill 80 holes :D )
    Put the stag back in place !
    Drilled the profiles on the short side ot the table
    Tapped all new profiles
    Fastened them back in
    Started to work on the new z axis
    Formatted the stepper holder ( was bend before :/ )
    Routed out bits from the profile which will hold the stepper ( ull see why later )
    Formatted the end where the holder will be screwed in to exactly 90 degrees
    Started to drill new holes in the now formatted holder
    And a first mock up to see if everything fits ( it did, quiet surprinsingly :D )
    Tried to fit some Brakets in to give it additional support, didnt fit.
    More routing :D
    outcome:
    Put ( almost ) everything together
    And just because i wanted to have a look at it, put the spinlde motor in, man this is huge :D
    Fitted a 220v air pressure switch for the cooling unit, there another 220v relais free on my breakout board, so why not use it :)
    Thats it for now, i still got some parts to come it, so hopefully tomorrow ill be able to mount the portal back onto the table :)
    phenoptix likes this.
  10. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    nice progress, what will you be routing with this beast ?
  11. lenne0815
    4 Jul 2009
    NAUTILUS MOLDS... atleast thats my plan ( im not gonna be the lenne that doesnt deliver ;) )
    And ill try to do more aluminium, now that theres no more wood i can finally cool the cutters with liquid.
  12. Dark~3nergy
    14 Jan 2007
    ohhhhhhh :D can't wait to see nautilus !!
    i thought you would use it for more things then modding since you have such a big workshop with such tools :eek:
  13. lenne0815
    4 Jul 2009
    Yeah i do obviously use it for my business aswell but i dunno if thats interesting for anybody here :D before we moved it was running atleast 6hrs a day doing whiteboard or other vakuum molds etc etc etc, so that probably stays the same, but after the change to v3 ittl be much more efficient at that.
  14. lenne0815
    4 Jul 2009
    I got it up and running again :D
    Joined the Portal back together
    Mounted it onto the new table ( man this thing is heavy now.... )
    Got some new cutters ( 12mm Carbide bits, this pic is especially funny if ure german and read the printed part :D )
    Halfway through
    Controller PC up and running again ( had some major problems with the breakout board, i ripped the usb port off when i disassembled the cnc and had to resolder some parts onto the pcb, luckily everything worked and i got it working again )
    What a beautiful backside :D
    This is a pic after i mounted everything, i routed a new PE plate to mount the suction and on the backside theres a reservoir now for the coolant.
    Reservoir
    In all its glory
    Some clamps i hacked together ( its so much easier to clamp stuff with the profiles now... )
    Wait, whats that on the monitor ???
    I took some videos aswell but i still have to cut and upload them...
    Gtek likes this.
  15. Yaka
    Yaka Modder
    26 Jun 2005
    man i am jealous:waah:
  16. Editor22
    3 Jan 2009
    Damn Lenne that's a beast! looks awesome though.. good work :D
  17. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Great job man! :thumb: It is really worth a while to go trough the whole worklog. It is very inspiring, full of handy info. Specially for me as I'm going to build my own this summer :dremel:
  18. lenne0815
    4 Jul 2009
    THX Guys :)
    Go for it ! even though its really time consuming, the reward is awesome !
    dark_avenger likes this.
  19. Thecyp31
    Thecyp31 Mini moddeur
    11 May 2011
    whaou !!! it's fantastic un cnc home made !!! good job ! you are un big moddeur !!!!!!!!!!!
  20. kowboy
    kowboy What's a Dremel?
    12 Jun 2011
    I just join this forum.. and this is the first "big" thread that i see... i'm truly amazed.... This is certainly one of the best (and coolest) projects I've ever seeing... Congratulations Sir!!!
    Diego
    PS: sorry for my bad english :p
