Modding Project: DIY CNC - V3 Reinforced Z Axis
Discussion in 'Modding' started by lenne0815, 16 Dec 2009.
  1. Karrek
    Karrek Minimodder
    7 Jun 2011
    Wow. Hard core modding. I'm impressed. So do you have both v2 and v3 up and running? Or did v2 get disassembled? Great job on these projects! incredible...
  2. Shael
    Shael What's a Dremel?
    19 Jan 2011
    :jawdrop: and thats all i can say after reading through 19 pages WOW :jawdrop:
  3. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Hats off to you. Taken me a about 5 days (not constant!) to get through the 19 pages. I've considered it a learning experience and it's been like watching a craftsman at work.
    I was a click away from purchasing a cheap chinese CNC a couple of weeks ago, I now think a home build would be a more rewarding experience give a better understanding, leading to better use of said machine.
    Great work and great work log. Thanks
  4. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    Thanks to everyone, ur nice guys, there are still some big modifications to do which will start very soon...
    for now, just an appetiser :)
    A new Toy
    Proper metal saw
    And another new toy a Lathe:
    lets get startet...
    Formatting the rough 40mm dural pieces
    Beveling
    Drilling
    Moar drilling
    erm i just realised i didnt really take enough pics :D
    so... a quick jump
    Finished Product :D :
    So whats this :
    before cheap item profile hack
    Now uber awesome edge fences
    With my new Vaku pods ( driven by a normal vakuum shop cleaner )
    If the workpiece is in place i can remove the top part of the fences to format the workpiece !
    to be continued :)
  5. Cheapskate
    13 May 2007
    Cool toys. How long before you go 5 axis?:naughty:
    http://www.cnc-toolkit.com/ -Haven't had the time to look into this yet...It sounds promising.
  6. lenne0815
    4 Jul 2009
    It is on the list, ittl be the step after the next :)
  7. lenne0815
    4 Jul 2009
    I really start to like aluminium :)
    theres a vid aswell but i have to edit and upload it first...
  8. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Heh, I don't think I've ever seen someone use a drill press vise on a cnc before. Cool idea!
  9. lenne0815
    4 Jul 2009
    Unfortunately... i dont have a better one ( yet ;) )
  10. lenne0815
    4 Jul 2009
    I never thought this will work that good...
    The aluminium is used as stock is AlZnMgCu1,5 which is one of the hardest aluminiums one can get ( 500nm )
    These are the cutting feeds i used:
    2 Flute 6mm straight bit 15000rpm 1mm depth 2000mm/m and i used the minimal cooling unit to make a very fine mist to cool the workpiece and bit, the stock didnt get warm at all, the bit got "lukewarm" not more :)
    After doing the first part i realised all the spindles came loose on the machine so i had to re tighten everything and level the machine again, it wasnt noticeable in wood at all, afterwards pure cutting bliss :D
  11. Yaka
    Yaka Modder
    26 Jun 2005
    man that must be so fun to use. wish i had some like to use at the weekends as a hobby
  12. lenne0815
    4 Jul 2009
    It certainly is a lot of fun, only drawback is that if u make a mistake u can kill 10000€ in less than a second ;)
  13. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    I went trough this thread do many times :) Epic journey... from old table mounted rails, to high precision machining device. Every time I feel unsure about my own cnc project, this thread puts me back on track.
    So... thanks for sharing :thumb:
    ... this is my Z axis in making
  14. lenne0815
    4 Jul 2009
    Looks good :) even though i think ur baseplate and the linear rails are to short ;)
    im gonna do some more updates on mine aswell i got a new side channel blower for vakuum clamping but i didnt install it just yet, i hope it works well, one other thing is the conversion of the long spindles to 'Powered' ball bearings, its a different type of drive concept where the ball bearings are rotated and not the spindle ( thus eliminating vibrations and allowing much higher speeds )
  15. Gtek
    10 Oct 2009
    short... yes, but it depends on requirements I would say. all I need from Z is 100mm, base plate is 300mm and rails 250mm long. That will do I believe.
    hmm, interesting... I was looking into alternatives to steppers as well. Found linear motors and something like ''powered'' linear rails, based on electromagnetism I think. Never heard about powered ballscews. Do you know any suppliers? (link maybe?)
  16. lenne0815
    4 Jul 2009
    Have a look here http://www.cnc-shop.mobasi.com/popup_image.php?pID=464&imgID=0
    but i think with a z depth of only 100m ur build will be rather small averall ? they are only really better if u have quiet long spindles ( ~above 1m )
    I meant to short in relation to ur ballscrew, it would support atleast 100mm more travel.
  17. Gtek
    10 Oct 2009
    Thanks :thumb:
    Well, yes it's small on that one axis, and I could make it bigger, but I didn't see a point adding extra mass, if I simply don't need to. But it's much larger on the other axis. 1000mm rails on X and 800mm on Y.
    ... talking about speed :D
    http://www.youtube.com/watch?v=BhcZBr38Kmc&feature=related
    next upgrade 1million rpm spindle :lol:
  18. lenne0815
    4 Jul 2009
    :D oh lord thats quick, i dont think u would achieve similar speeds in an full build because the spindle etc make it a lot heavier but it is really quick nonetheless.
    I think sevos are too expensive though and they dont have any large advantages for a diy build.
    Razer2007 likes this.
  19. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    this is awesome! I'd love to do this myself some day too. How much have you spent so far?
  20. lenne0815
    4 Jul 2009
    way too much ;)
