Modding Project: DIY CNC - V3 Reinforced Z Axis
Discussion in 'Modding' started by lenne0815, 16 Dec 2009.
  1. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    that's no answer :(
  2. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    I thing it might be somewhere around 7 to 10000 Euros, plus countless hours of work...
  3. Razer2007
    18 Jul 2010
    Wouldn't it be cheaper to buy one? But well having one you built yourself is much better :)
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Go look for one of that size and those features... won't be any cheaper than that ;)
  5. lenne0815
    4 Jul 2009
    Hey guys, heres as promised the routing aluminium vid in 720p as usual !
    And i did install a side channel blower for vacuum clamping already but didnt take pics of it, ull see it soonish ;)
    Razer2007 likes this.
  6. Yaka
    Yaka Modder
    26 Jun 2005
    prolly said a few times already buut great job building it and thanks alot for keep us all updated with pics and vids
  7. lenne0815
    4 Jul 2009
    Thx Yaka :) some moar pics from the recently added side channel blower ( Its much quieter than the shop vacuum cleaner i used befor and has aprox 3 Times more Power ;) )
    I just duct taped everything together for testing purposes :D
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    That is simply more than impressive!!
    I've always fancied a cnc machine but find using cad tricky!
    Is there anyone in the UK that has a cnc machine? and a 3d scanner?
    :D :D :D
  9. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Can i ask how mutch did you spend in these plus the motors, and where did your bought them ?
    Best Regards
  10. lenne0815
    4 Jul 2009
    They were like 350 euros in a set or something, got them off ebay, some chinese seller ( these are actually still the same aside from the bob and the psus im still using )
  11. Overminde
    15 Sep 2011
    Thanks for the reply mate, and congradulations for the projects its something from the other world.
  12. lenne0815
    4 Jul 2009
    Ok guys, im back in cnc upgrading business, today i ordered one of these [​IMG]
    thts a digital stepper driver, they claim "servo like stepper performance" lets see if it lives up to it :D
    The reason why i ordered it is rather simple, the stepper driver on my z axis is **** the stepper starts resonating badly at about 3,7m/m whereas my other drivers are able to speed it up to 8m/m without resonating at all.
    But this is only the first step im gonna take, im doing heaps and heaps of 3D stuff lately ( Pretty much only 3d... ) and having high velocity on all axes is essential to keep routing times low, for example i just startet routing big foam blocks, doing that right now just takes way too long.
    what i do hope to achieve is
    7000mm/m on Y vs now 2200mm/m
    7000mm/m on X vs now 4000mm/m
    7000mm/m on Z vs now 3800mm/m
    Especially the Y axis has been causing the biggest headaches for me, i did need to shorten it from 2,2m to 1,8m in order to avoid heavy resonances caused by the huge ballscrews.
    My error when buidling it for direct drive was that i didnt calculate the ballscrew length before, so i ended up with 2200m /m on y which is really slow :/
    I do have a solution for that now and the parts to realise that are ordered.
    If u guys are interested i could do a little closer view on the software side aswell, explaining the basics of mach3 running my machine.
  13. RonanH
    RonanH mod-envious
    30 Mar 2010
    Would love to see more of this. Would also love to see some of the stuff you've made already on it :) It's an amazing project, something I'm certain a lot of people on here would want to be able to do but can't afford or just wouldn't have the use for. All the same I loved watching it evolve and look forward to seeing more :thumb:
  14. blackrock
    blackrock What's a Dremel?
    8 Feb 2012
    Wow man! Started reading this yesterday from beginning to here. You got some skill and feck! All best for you and CNC. Im waiting to see more! :)
  15. lenne0815
    4 Jul 2009
    Cheers Guys :)
    I did install the new Leadshine driver now and i tell u, its a night and day difference to older analog driver, resonating is effectively eliminated and i can push the accel rates on the x axis almost twice as high, plain awesome.
    I did some other changes aswell, now im using an xbox controller to control jogging and a bunch of other features furthermore i have mach3 running with gerrys mach3 2010 Screenset which almost feels like a brand new controller software.
    Im uploading a video right now ( will take some time be patient ;) )
    For anyone whos interested in the Screenset from the Video more info here: link
    The XBox Controller Plugin can be found @ www.machsupport.com
    BTW the vid was taken with the Samsung galaxy note n7000 for comparison ;)
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    LENNE! I've been looking at that X-box controller plugin but wondering how useful it would actually be... you just answered my question! Looks amazing, likewise so does your entire set up!
  17. lenne0815
    4 Jul 2009
    Cheers Editor, after i configured and tried the xbox controller i simply asked myself why i didnt use it earlier, its cheaper than any other pendant and much better...
    Today i finished the updated vacuum clamping system and my driven ball nuts are coming propably on wednesday, im so exited :D
  18. Editor22
    3 Jan 2009
    Oh man it's really turning into a bit of a beast now! I had contemplated using a joystick but the fact the the x box controller can function wire free must be a massive bonus when setting up small parts!
    You still doing a lot of plywood work?
  19. lenne0815
    4 Jul 2009
    It is indeed, having a wired pendant is really inconvenient.
    A big plus for the xbox controller is the reliability, i didnt encounter a single situation where it didnt work as expected or caught noise in the signal, it just works very well.
    I dont do much ply anymore, now its mostly 3d Molds / press dies etc, a lot has changed in the last year ;)
  20. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    :jawdrop::jawdrop::jawdrop::jawdrop::jawdrop:
    thats all.
