Modding Project: DIY CNC - V3 Reinforced Z Axis
Discussion in 'Modding' started by lenne0815, 16 Dec 2009.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    No, i did not, wasnt aware of that, read up on it, seems certain silicone types are quiete agressi, i have to check that !
    Alu soon, ill probably rig the cnc with water cooling and a massively longer table in two weeks !!!
  2. lenne0815
    4 Jul 2009
    First sketches of V2, ordering parts all day long...
    Size Comparison
    With ball screws and parts of the assembly
  3. capnPedro
    11 Apr 2007
    What are you doing with your old machine?
  4. talladega
    talladega I'm Squidward
    18 Aug 2007
    :D
    MOAR!!!!
    i want the old one!
  5. lenne0815
    4 Jul 2009
    Many parts are taken into the new machine, but not all :D
  6. lenne0815
    4 Jul 2009
    Two boxes arrived, and i have heaps new parts :D
    First box
    Hmm bearings, Holders for the motors and jeah uhm, whats the name in english for the big bearings which sit on the spindles ?
    Motor - spindle couplings
    Bearings to hold the spindle
    Mounting things for the motors
    Big Spindle bearings
    Cases for the bearings ( whe the big bearings are mounted they sit inside this case )
    Spindle mounted with bearings and coupling
    Closup on the motor sinde of the spindle
    Another one with the motor mount in place
    Everything together with the bearing inside the case
    Second Box
    Everything together
    Another stepper with its driver in the foreground
    Kress 1050 FME routing spindle
    Euro 43 Mount for the kress Router
    Noga cooling assembly
    Thats it for now, theres more to come soon :D !
  7. Allmighty Loki
    Allmighty Loki GP modder
    8 Nov 2009
    Nice project!
    Haven't you tought about using a variable frequency spindle? (1hp must be enough with those steppers) They are very silent and you can reduce their RPM without loosing torque!
  8. meh
    meh What's a Dremel?
    8 Nov 2008
    I'm fairly sure your 'Big Spindle Bearings' are the ball nuts for the screw.
    What's the pitch on the ballscrew and what rating are the steppers?
  9. lenne0815
    4 Jul 2009
    pitch is 5mm and the steppers are 3nm. Ball nuts is correct i suppose ;) The kress spindle is atm the only thing i can afford :D
  10. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    oh god, that cnc will be huge. what are you going to mill with it ?
  11. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Another CNC mill GOSH :lol:
  12. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    What accuracy grade is that ball screw?
  13. lenne0815
    4 Jul 2009
    Very close, but actually there will be some hardcore modding done !
    (atleast i hope so :) )
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    How do you export sketchup files to the CNC machines? And do know the tolerances of V1?
    Thanks and great projects BTW :thumb:
  15. Droih
    Droih Your too close if you can read this
    17 May 2010
    Sure hope so, when you get this baby done you should be able to do some badass stuff:thumb:
  16. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Now this looks more like it :D
    Would it be possible to get a list of the places where you got all the various bits?
    Btw, that spindle is a bit so-so when it comes to aluminium, revs a bit too high and with too little torque. I'd recommend one of these instead:
    http://www.cnc-plus.de/Spindles---Accessories/Spindles/AW-FSE-1500-Spindles.html
    (Isel spindles are also fine as they are almost identical to Suhner)
  17. Allmighty Loki
    8 Nov 2009
    I use the ArtCam Pro for that purpose, It can accept a sketchup - 3dstudio - rhino - autocad 3d model and lers you program the toolpaths :thumb:
  18. Cheapskate
    13 May 2007
    I just choked! I'm hoping there's a bug in the US currency settings. $800+?:jawdrop:
  19. Dark~3nergy
    14 Jan 2007
    i forgot to ask but where did you buy all those stuffs ?
  20. lenne0815
    4 Jul 2009
    Its all from german Machine suppliers, dunno if it would help youse :D
    I use mastercam x4 to get my G code and Mach 3 to control the motors.
    Accuracy of the ball screws ? i wouldnt have a clue, im here to make stuff not to look at it :D lets just say, if u try to move it it doesnt, even if u use a larger amount of force, so the accuracy should be around 1/1000mm, better consult isel technical documentation for that question :D
    But if u meant the overall accuracy that would be 5 / 200 mm (motor moves 1,8 degree per step) but it doesnt take into account any of the factors which take part in the overall accuracy and there are millions of them.
