Modding Project: DIY Dual Remote
Discussion in 'Modding' started by Warrior_Rocker, 2 Apr 2008.
  1. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    View the updated project log on my personal site, XodusTech.com
    Hola bit-tech'rs,
    Been a while since I did a mod worth taking pictures of and this one is certainly worth it. Project DIY Dual Remote was an aim to simply cut down on the amount of devices I would use in my car to control both my headunit and my carputer lcd. Even though the LCD will have an auto on circuit once installed I felt it was a nice touch to include the remote to switch video modes and to turn off or on the LCD should the need arise.
    Anyway, the basic idea here was to take two essiential buttons from the LCD remote and and integrate them into two existing buttons on my headunit remote. I picked two buttons I don't think I've ever used and went to town (not literally, but it feels like it).
    Picture Log:
    [​IMG] [​IMG]
    This first set is to show how small not only the Sony remote is, but just how small and thin the LCD remote is.
    [​IMG] [​IMG]
    The first promising shots of the project, appears that once those cross bars are removed from the back of the Sony remote, there should be ample room.
    [​IMG] [​IMG]
    Far out and close up shots of the LCD remote board, very sparse and thin.
    [​IMG] [​IMG]
    First shots of the excess battery assembly dremel'ed off and the buttons and battery wires soldered up.
    [​IMG] [​IMG]
    Next The LCD board was tacked to the back of the Sony board with super glue. Not the cheap stuff :)
    [​IMG] [​IMG]
    After the glue dried the battery wires from the LCD remote were soldered to the connections on the Sony remote. Now they can share power.
    [​IMG] [​IMG]
    Next the most difficult phase of this mod. The wires from the LCD remote now need to be connected to pads on the Sony remote. Traces were cut in several places to ensure there was no residual connection between the LCD and Sony remote boards. The soldering for this ranks high on difficulty.
    [​IMG] [​IMG]
    Here is where it got even trickier. Two wires had to be soldered to either side of a small solder pad that connected the traces on the Sony remote to the pads where the buttons connect. The pad had to be sliced in half and wire soldered to either side. This is because electrically the two buttons on the Sony remote shared a common wire. However the LCD remote did not share the same setup, so to make it work they had to be electrically isolated.
    Finished product. Doesn't look much different does it? Well on the outside there is no difference. Though it feels just slightly heavier now with two remotes inside.
    Thanks for taking a look, I look forward to what bit-tech has to say!
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Nice work there. :thumb:
    You forgot to mention you hooked the LED up as well.
    Have you tested it?
    By testing I mean dropping it as well to make sure it wont come loose. But then based on your projects I find that to be unlikely.
  3. Warrior_Rocker
    26 Jun 2005
    Actually two things I remember now I didn't mention.
    One was I had to relocate what appears to be the timing oscillator. (square yellow thing on the PCB). It took up about an extra millimeter of space that I was not going to give up. The other as r4tch3t pointed out is the IR LED. When inspecting both remotes the circuits were setup almost identically. I tied in the lead that came off the LCD's IR LED transistor to the same pin on the Sony IR LED that was connected to the Sony transistor.
    Upon further testing the LCD functions seem to work farther away than they did with the previous remote. I can only assume it is due to the larger LED.
