Project: Dumb Terminal
Discussion in 'Project Logs' started by TheGreatSatan, 22 Feb 2007.
  1. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Nice!
    Where are you going to mount it? Is there room in the screen area for a possible HDD cage or something?
  2. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
  3. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    lol @ TGS. EBay spree?
  4. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    Wouldn't under the motherboard be a better place for the hard disk?
    Seems like there'll be room enough for two disks maybe.
    Also wondering about your plans for the rest of the monitor space.
    Honestly I don't know what to think about that HS.
    Even if it isn't as naff as I think it will be, it's the sort of thing you'd want to show off, not hide in a stealth mod like this.
    Just my 2p of course.
  5. TheGreatSatan
    5 Aug 2005
    I was thinking because of limited cooling and a cramped space the heatsink's special abilities would be most useful even if not seen.
  6. TheGreatSatan
    5 Aug 2005
    I'm sorry for the delay. I'm anxiously waiting for all the parts to arrive.
  7. sparkyftw
    sparkyftw What's a Dremel?
    10 Nov 2006
    hey its all good. Can't wait to see more from this
    I started a mod back in Decemember and I only have 4 cuts and some sanding done, I am way behind
  8. TheGreatSatan
    5 Aug 2005
    I put the heatsink and memory on the board
    And added a mobo tray. I'll clean it up...
    I got a cheap optical mouse from Office Depot!
    I'll have to color match it later.
    On to the keyboard
    Here's how it will go.
    There will be gaps to fill.
    But it's too thick...
    So I removed the bottom... I'll finish that later
    Now for the new ports and power button
    I made a new backing
    And added the USB/Firewire
    Then I wired the power button (From MNPCTech)
    And that's done
    Mounting the PSU and keyboard are next :)
  9. sparkyftw
    10 Nov 2006
    now I know I am a little late, but I have an awesome idea for this.
    Ever thought about getting on of the laserball mouse, taking it apart, and putting it onto the case on the right of the keyboard. it wouldn't be that hard to rig up the 2 buttons either, just need 2 momentary switches, and you could also mount the scrool wheel on there with a little work. i think that would be pretty killer.
    also looking awesome. love how you got a keyboard to fit
  10. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
  11. TheGreatSatan
    5 Aug 2005
    I added the keyboard.
    But in the process broke the framing....:hurt: I'm gonna have to glue it or something.
    Here's the bottom of the keyboard with a protective layer.
    Lastly I added the standoffs and the PSU.
    Next up is the HD mounting.
  12. DarkLord7854
    22 Jun 2005
    Looks nice :)
  13. randosome
    randosome Banned
    17 Sep 2006
    :jawdrop: how big is that HSF
  14. TheGreatSatan
    5 Aug 2005
    I think 92mm
  15. TheGreatSatan
    5 Aug 2005
    I found an old cage to hold my HD...
    But had to cut it to fit in the case
    Here it is so far. I just bought the monitor and it will be here soon.
    I put the HD on this side because the bottom is too narrow and the other side will be eaten up by the heatsink.
    Here's the PSU. It was really annoying trying mount it on an angle like this.
  16. TheGreatSatan
    5 Aug 2005
    The LCD will be here soon...
  17. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    U are doing a great work with this old terminal and im looking forward to see it with the lcd mounted .That HSF looks so freaking big on that small mobo :D
  18. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    love this nice retro project ...
  19. TheGreatSatan
    5 Aug 2005
    I got the LCD in the mail recently and have finally gotten the time to add it to the Mod. Here's where I removed the shell.
    Here's it out.
    Then I had to make notches so it could be fitted in the case.
    And it does....
    Here's the overhead.
    And fortunately, I won't have to cut the original screen opening
  20. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Sweeeeeet! I just love this :D It's a really funny project, with a nice finish. You make modding look very easy with this mod :)
