Scratch Build – In Progress Project: Eagle 5 - Spaceballs PC
Discussion in 'Project Logs' started by TheGreatSatan, 27 Jun 2006.
  1. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Also "We brake for nobody" :D
  2. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    I'm gonna have to pick up the movie
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    This mod will totally rule!
    You just need some action figures for the front seats :D
  4. deiol
    deiol What's a Dremel?
    14 Jun 2001
    A UPS mod, what a great idea! A spaceballs mod makes it even more kick ass.
  5. TheGreatSatan
    5 Aug 2005
    I can't any action figures.
  6. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I have that same Winnebago! Actually it's at my parent's house and now my daughter plays with it. Hmmm...maybe I need to see what other toys my parent's still have that I could build a computer in. :idea: I'll be watching this closely. :thumb:
  7. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    no offense or anything, but i want to see some work on this, its been almost a week of hype so far...
  8. TheGreatSatan
    5 Aug 2005
    I'm currently finishing my Hard drive PC and project CLOWNED.
    www.tgsmods.com
    Let me finish those first.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    That's the bumper sticker on Spaceball One, he was asking for the one from the Eagle 5.
  10. ElThomsono
    18 Mar 2005
    Sorry, I thought that was clear.
  11. TheGreatSatan
    5 Aug 2005
    Alrighty let's get started. I gutted the Winnebago.
    I opened the top.
    And dropped in the UPS. It's a perfect fit as far as length and width, but height.....
    When I measured it before I assumed that the height of the winnebago was the same on the inside as the outside. But I never really considered the bottom.
    The inside is just 17cm
    The UPS is 22cm
    And the outside of the winnebago is 22cm....
    I could fabricate some kind of shell with the wings attached that could go on top to cover the top of the winnebago. Or pull out the bottom and set it lower. What to do?
    I rented the movie too.
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Chop the bottom and mount the wheels lower will prob be the easiest option I'd think.
  13. Guest-23315
    Guest-23315 Guest
    wow, thought this wasn't going anyware...
    great idea.... v. original......
  14. TheGreatSatan
    5 Aug 2005
    I just had to finish two other projects first. One is done, so now I have more time.
  15. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    How much space is wasted inside the UPS? From the 1 photo you showed there seemed to be a lot of room inside it. Is it possible to cut-and-shut the frame of the UPS and remove some of the extra space in it to make it fit inside the shell. Or a partial disassemble an relocation of some parts perhaps to make it fit better?
  16. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Go with ..Constructacon.. idea, before cutting the wagon, then you would have to cut less of the wagon..IMHO
  17. scifi3018
    6 Feb 2005
    Im glad to see this project taking off :)
    I will 3rd the idea of disasembling the UPS before cutting the wagon to much.
    I hope lots of pics will come soon :thumb:
  18. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Mod the UPS instead of the Winnebago. It looks like there is plenty of space between the components that you could knock of the 5 cm moving stuff closer together.
  19. thedragon7786
    thedragon7786 What's a Dremel?
    18 May 2006
    How high did you want the wings to be? Maybe just construct some sort of extended frame for the wings out of bondo or aluminum to just cover up the UPS that sticks out on top. This way you won't have to cut the winny, or change the UPS.
    Edit: I think you already mentioned something like this. So, I would agree with that idea.
  20. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I think if he cuts the PS down it may overheat. But The Winner can't be cut. So I say that you Give the camper a large whole roof airscoop for the engines right?
