Scratch Build – In Progress Project: Eagle 5 - Spaceballs PC
Discussion in 'Project Logs' started by TheGreatSatan, 27 Jun 2006.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Before I started painting and after each coat.
  2. stevehp
    stevehp What's a Dremel?
    6 Jul 2002
    How about primer; paint needs something to latch onto. How long was the dry time between coats? Not sure how you're going to remedy the monster truck look, but side skirts should do the trick, but it might require some fabrication to make it look like part of the winnie.
    Love the idea the movie is a classic.
  3. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    well damn =/ sounds like steve is right
  4. stevehp
    6 Jul 2002
    Well both sanding and primer are necessary for paint to stick to a surface like metal so.. really we both were right. Sanding allows the primer to stick and the primer allows the color coats to stick.
  5. TheGreatSatan
    5 Aug 2005
    I've done it all, but I'll do it again.
  6. thedragon7786
    thedragon7786 What's a Dremel?
    18 May 2006
    try a different brand of paint.
  7. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    There's not a lot that can be done about the position of the W logo. Don't worry as most theme mods are done "in the spirit of" and are not exact replicas. Only the most die hard of Spaceballs fans (and those who read this work log) would know that the W is slightly in the wrong place. I'd never have known if it wasn't pointed out.
  8. TheGreatSatan
    5 Aug 2005
    I hadn't posted this before, but this is my 3rd try painting this damn thing.
    When I peeled off this piece a long strip of paint came off too.
    Almost looks good from here.
    But it still looks like crap.
    I hereby cancel this mod. I've wasted nearly 3 cans of spray paint on it and would still have to start over agian. But I am not going to. I quit, lock this thread.
    There are better mods ahead.
  9. mattthegamer463
    26 Nov 2004
    Don't give up!
    Why don't you just paint it by hand? If you did several small coats of it with a brush, the brushmarks would be minimal, and could be sanded away. Give it a try, don't give up!
  10. kbates666
    kbates666 What's a Dremel?
    24 Jan 2006
    Yeah dont quit, I was lookin forward to seeing this project completed
    Obviously your Paint is not sticking to your surface, so try something new like hand painting like Matt said or Airbrushing, Etc.
  11. TheGreatSatan
    5 Aug 2005
    Let me finish my HD PC and I'll look into using paint brushes for the brown stripes.
  12. deiol
    deiol What's a Dremel?
    14 Jun 2001
    no nned to quit, it looks like its coming along great! just need to do a little hand painting to touch up some spots thats all. spray paint isn't the best paint anyway, hand painting would probably work better.
  13. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I would recommend lighter coats of paint.
  14. TheGreatSatan
    5 Aug 2005
    A lighter coat would just come up easier.
  15. MageOutlaw
    MageOutlaw What's a Dremel?
    3 Apr 2006
    NOOOOO dont give up plz, theres got to be somthing to put over the paint that will make it not come up
  16. Dark_Bone_04
    Dark_Bone_04 What's a Dremel?
    8 Aug 2005
    sand everything again then wash everything with soap so u clean very well the surfes dont give up go go go xD sorry my english its nat very good xD
  17. htm_elle
    htm_elle What's a Dremel?
    8 Sep 2005
    Adhesive Vinal
    You could always use some adhesive vinal like what they use for signs. Comes on rolls in tons of colors. Easy to work with if your fed up with paint. Best part is if you mess up just peel it off.
  18. TheGreatSatan
    5 Aug 2005
    As soon as the Superbee is done, this worklog will reopen. I had real problems getting the HD's to behave in my HD PC and I won't let the pitfalls of this mod stop me from completing it.
    See you mid-Sept.
  19. ssR
    ssR Carbon God
    11 Aug 2006
    man too bad u quit on this mod i loved the idea.
  20. TheGreatSatan
    5 Aug 2005
    I'm trying to recreate the sticker on the door just like:
    But due to lack of any useful software and very little in the way of skills....
    And I painted the other side with no problems.
