Scratch Build – In Progress Project: Eagle 5 - Spaceballs PC
Discussion in 'Project Logs' started by TheGreatSatan, 27 Jun 2006.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Another update coming tonight
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Woohoo :clap:
  3. wbdog206
    wbdog206 not me
    15 Jan 2007
    love this mod. sweet
  4. TheGreatSatan
    5 Aug 2005
    So, here's this thin aluminum leg that came with the Weber grill I originally bought to obtain R2D2's head.
    I pounded it in to an oval shape as it is in the movie.
    I finished sanding the bondo I applied earlier.
    The area where the wings are attached to the winnebago go over the edge....
    So I folded them under with a hammer.
    And attached the engines.
    More bondo, sanding, cutting and paint to come.
  5. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    simply awesome. a great mod baded on a great movie by one of the greatest comdey directors ever!
  6. TheGreatSatan
    5 Aug 2005
    I started some patch work on the wings. LOTS more to do.
  7. FR34K
    FR34K What's a Dremel?
    1 Feb 2007
    haha, I remember the beginning of this one back in CMG.
    keep it up. :thumb:
  8. TheGreatSatan
    5 Aug 2005
    Here comes all the major Bondo-ing. I will ad several layers to the wings to make them thicker and smooth-er.
  9. TheGreatSatan
    5 Aug 2005
  10. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    I like where this one is going. Im glad to see you keeping up with this mod.
    Looks tight :D
  11. TheGreatSatan
    5 Aug 2005
    As usual, I like to add a coat of paint when nearly done sanding to find all the small areas that need to be filled in. Needless to say, I found some.
  12. TheGreatSatan
    5 Aug 2005
    I had to rebondo some of the holes.
    After another quick primer, it looks like I'll have to bondo. . . . . .again.
  13. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    yup it's a lot of bondo-work, but the wings are starting to look great. Will be nice when finished!
  14. TheGreatSatan
    5 Aug 2005
    I have this Mesh from the transformer of an old Tandy CoCo
    I cut and bent them into 3D triangles
    Then added them to the wings
    And I painted them to match
  15. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    HAHAAAAAAAAAAAAAA Lovin it! keep it up bro! this kicks ash!!!
    w0000t!
  16. dacust
    dacust What's a Dremel?
    10 Mar 2007
    That mesh works PERFECT! I'm loving the details as they appear!
  17. TheGreatSatan
    5 Aug 2005
    So the mobo will be in the back
    I had to use two stand offs together to get the height that I need.
    I then had to hold them in place on the bottom with nuts.
    Here's before...
    And immediately after. I obviously still have to make it look clean.
  18. dacust
    10 Mar 2007
    Oh, yeah. That's gonna look good.
    Kinda hard to tell, will you have room to put the bumper back on?
  19. TheGreatSatan
    5 Aug 2005
    Yes I will.
  20. TheGreatSatan
    5 Aug 2005
    I cannot find the IO plate so I bought this mesh garbage can for $4
    I cut a little piece out
    Then cut out the IO ports
    Now it's getting painted.
