Case Mod - In Progress ⭐ Project Ecthelion - Thermaltake Tower 900 Build, Dual Loop Hardline Liquid Cooling
Discussion in 'Project Logs' started by Mr_Armageddon, 30 Apr 2018.
  1. Peter J Milanese
    Peter J Milanese What's a Dremel?
    12 Jun 2021
    Very well done. I have a similar build, currently refactoring for a 3090 (was dual 480's), I love what you did with the display wrap. I might learn from that trick. I've decided also to remove the complex hard lines / passthroughs and just go straight / 90 out of the bottom of the case. I do wish that someone fabricated a full backplate so I didn't have to do just the bottom half though!
    How did you mount the display?
  2. kim
    kim hardware addict
    10 Jan 2016
    :idea: Necro bumb ... might be hard to get a reply :grin:
  3. Cheapskate
    13 May 2007
    Missed this one. It looks great. :D
    @Peter J Milanese - It looks like that screen comes with an auto mount bracket, so he probably just screwed one side to his bulkhead plate.
  4. Peter J Milanese
    12 Jun 2021
    Ah nice. Thanks for the detail!
