Project....ehmm...Work in progress? (mmm pics) update 8/21
Discussion in 'Project Logs' started by vtoe, 14 Aug 2004.
  1. vtoe
    vtoe What's a Dremel?
    22 Jul 2004
    Thats my extremely bored girlfriend. I made her keep me company :D
    I live in North Brunswick btw
  2. vtoe
    22 Jul 2004
    Update
    Hmmm today started out nice but ended bad. My cordless drill ran outa batteries so I wasnt able to finish. Heres the bracket I made for the font of my case to hold my dual 120mm fans. Since I wasnt able to find the evercool fans I wanted that are aluminum and blue led. I decided to build a shroud to vcover the side of the fans. It came out better then I expected. Just need to cut out holes, trim the tabs stickin out the side to fit my case and mount it. take a look!
    Im was too tired to pick out the good pics. I had to upload them on a diff pc so I dont know which is which.
    Btw. That lower hole I cut in my mobo tray was done with a jig saw thats why its not perfectly round. I was alittle dissapointed about it but it will be covered my a fan guard so all is good I guess.
    vtoe
  3. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    Nice Idea Keep Up The Good Work
  4. Leevi
    Leevi What's a Dremel?
    28 Jul 2004
    c'mon I need update! coz I'm planig to do something like that.
  5. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    lookin good m8, those cuts are real nice :thumb:
