Project: Enter the Blue Dragon (STARTING ALL OVER AGAIN)
Discussion in 'Project Logs' started by phoeneous, 4 Jan 2005.
  1. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    GA-7N400-L. Why?
  2. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    ****ing awesome!! I giv 5 stars from that case :) But im wondering a litle why u din't do those crawings by green? It will seen much better cause those uv cathodes is pretty bright blue, or do ur camera lying a bit?
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    damn nice job u did on this one :thumb: need job on sleeving also. continue the good work. all this for your girl? i know who gets lucky tonight :D
    keep on modding :dremel:
  4. keir
    keir S p i t F i r e
    5 Oct 2003
    whooo very clean and tidy really like it so far, keep up the good work :thumb:
  5. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    This is really starting to turn beautiful...dude, I'D be your g/f if you made something like this for me! I can call a surgeon, gender changes don't take that long! :thumb:
    Seriously, though, very nice. I might be inspired to do some of my own etching after seeing the job you did here! Looking forward to seeing this project when it's finished up.
  6. phoeneous
    16 Aug 2004
    Things have been very busy at work and Ive been studying for the A+ exam so I havent really had a chance to do much modding.
    Last month I primarily focussed on the stealthing of the two drives. The top bay will be unoccupied followed by a DVD, a CDRW and the bottom bay will be a surprise!
    :naughty:
    So, we start off with the stock 5.25" bay covers. I like these compared to most bay covers because they have a different locking mechanism. On the left is a screw hole and
    on the righ are two round tabs that snap the bay into place. This is much easier than the conventional bay cover but I have no clue why Im telling you all this because in the
    next 30 seconds, that cover gets MODDED! :clap:
    We need just enough metal to cover any openings behind the cover so about 1/4" should do the trick.
    The first rule of Modding: Measure twice, cut once!
    My trusty jigsaw handles aluminuminum very well.
    So far so good:
    Some dremel work to sand down the rough edges:
    Followed by some hand sanding wih 1500 grit paper:
    And voila!
    Thin profile shot:
    Here is the first drive that is going to get stealthed:
    You get the idea right?
    This is what will be used to attach the cover to the drive. It is 3M's dual-lock velcro. Its not like normal velcro, that scratchy fabric crap. Its made of a rubbery material
    that has interlocking phalanges that stick together.
    Two strips of equal sized dual-lock on the DVD drive lip.
    Can you guess what happens next? Yup, two strips of dual-lock in roughly the same spot as the first two to line up and hold the
    cover to the drive.
    BADA-BING! Perfect fit!
    Here is the fully stealthed drive in the case. Beautiful!
    Repeat the steps above for the other drive and you get...
    Hey, whered they go?!!!?! :jawdrop: :eeek: :hehe:
    Cleanliness is next to Modlessness!
    I have no idea how this happened. The filament in my ccfl snapped in half but the tube remained intact. Just like that. Pop. Weird. Trust noone.
  7. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    Were did you source the dual-lock velcro from? Is it available from HD? It looks clear...woo...I could use this stuff (I have crappy white fabric stuff).
    Good job with the stealthing.
  8. phoeneous
    16 Aug 2004
    You might be able to get it from HD but I always buy mine from Target. Should be no more than $3.00.
  9. automagsrock
    automagsrock What's a Dremel?
    18 Nov 2004
    Quick question
    (and totally n00b one) but with them stealthed, how do you open them? Do you just press the corner with the eject button or what? :confused:
    Otherwise, great job! :rock:
  10. phoeneous
    16 Aug 2004
    Yup. Thats why the double stick tape is there. On some cases Ive had to triple layer the double tape because not all eject buttons and drives are made the same.
  11. NoCoolOnesLeft
    NoCoolOnesLeft What's a Dremel?
    31 Dec 2004
    you could always right click the drive, and hit eject also (in windows) :thumb: :thumb: nice job, looks great!
  12. phoeneous
    16 Aug 2004
    That takes too long. Pushing the bottom right corner of the cover works fine. I might be re-wiring the eject buttons to a few bulgin switches if I can find them in black.
  13. phoeneous
    16 Aug 2004
    Mini Update
    A few goodies came in today. Coolermaster CoolDrive 4 and a SamSung SpinPoint UltraQuiet UltraATA133 HardDrive. This is the quietest harddrive on the planet, you dont even know its there!! :hip: My stupid harddrive sounds like a freakin marching band :( . If you'll noticed, I took out that generic 4 fan controller after I added the CD4.
    Anyway, on with the pics...
    The CoolerMaster CoolDrive 4, one of the best bay devices ever!
    Looking good!
    Since all drives were in at that point, the final setup of the cables was done. Remember, the idea is a clean and organized look. Many zip ties were harmed in the making of these photos. :eeek:
    These unsleeved wires are from the fan extensions used in CD4. They will be sleeved next week because I ran out of sleeving.
    I will be changing out the Vantec Aeroflow (very noisy) and putting in a CoolerMaster X-Dream III (very quiet) when it comes in. Im hoping by Friday.
  14. phoeneous
    16 Aug 2004
    Sweet!
    I found some more sleeving so I was able to finish the wires for the CD4!
    The finalized hidden wiring!
    Gotta get some studying done!
  15. phoeneous
    16 Aug 2004
    :dremel:
  16. Bandit_zoraK
    Bandit_zoraK What's a Dremel?
    29 Nov 2004
    excellent job of hiding your wires, looks s00per clean. About how much those cool drives cost?
  17. phoeneous
    16 Aug 2004
    Anywhere from $40 to $50. Its a great bay device!
  18. Jock
    Jock Banned
    12 Dec 2004
    Nice job m8 :D
    Pretty much how my new system is gonna look.
    **BUT, better! :dremel: lol **
  19. phoeneous
    16 Aug 2004
    Im starting all over
    Unfortunately Ive had to RMA the mobo. After loking at it for a few days, Ive decided to start all over. There are too many imperfections for this case to be a gift. I want it to be impressive and near perfect.
    Ill be keeping everything but the case and the psu i.e. all the sleeved cables, the stealthed drives, fans, etc..
    The new case should arrive in about a week. Until then...mod on.
  20. Tech-iT
    Tech-iT What's a Dremel?
    12 Aug 2004
    What are some of the imperfections? Were they manufacturing/design flaws or something you did?
