Modding Project Enter the USB
Discussion in 'Article Discussion' started by CardJoe, 1 Aug 2007.
  1. completemadness
    completemadness What's a Dremel?
    11 May 2007
    your 8800GTX ? :p
  2. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Pretty neat.
    Just a note, E6000 isn't epoxy. Epoxy is always a two-part mixture. It's not silicone, either.
  3. Kurtis
    Kurtis What's a Dremel?
    9 Apr 2004
    Oops, I thought I had edited that. E6000 is industrial strength adhesive. You're right, it is not epoxy or silicone.
  4. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I have been very happy with a "mod" i did a while back when i broke the casing on my Attache USB drive, i just covered it in electrical tape. It made it much smaller, and also had my name permanently attached to it :)
  5. Sandwich
    Sandwich What's a Dremel?
    21 Jun 2007
    How about some of Sandisk's new Ducati memory?
  6. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    I'll think about it. I might make my own if thats ok with you.
    -CollinstheClown
  7. Kurtis
    9 Apr 2004
    Have at it, my friend. :)
  8. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    Kurtis Kronk, mate, really, please grow up...mentally.
Tags: Add Tags
