Project Essential Machine
Discussion in 'Project Logs' started by hu$tla, 19 Jun 2007.
  1. hu$tla
    hu$tla What's a Dremel?
    19 Jun 2007
    hi!
    I started this case several months ago. As basis I used a Chieftech mesh Case which u can see on this picture:
    My First Idea was, to replace the grill in the front door with a piece of MDF and cut a hole into it to see the aquatube as shown in this sketch:
    Later I figured out to laminate the piece of MDF with carbon but i aint done yet because i'm not yet familiar with the material...
    But here are sum pics of the piece as worked on it in the past:
    First of all i had to do the outer reliefs of the piece. I did that with a dremel and a file:
    I marked the hole and cut it out with a saw
    then i started milling out the relief:
    Then i sanded it with 180 paper
    Then I assigned the holes for the screws
    And Finale mounted it
    then I grounded the plate and looked for unproper roughness
    and corrected it with sum spachtel
    Then I grounded it again and wetsanded it with 800paper
    So thats it :D
    Afterwards I build a "selfmade melvin pipe" for my aquatube. Cuz its rev 1.0 I couldn't use the aquajet. I took a G 1/8 push-in anglepiece, cut the winding a bit shorter and mounted it from inside. I had to cut the winding cuz otherwise the other piece wouldnt fit. After that I put a Plexiglas tube into the anglepiece.
    so thats done.
    Here is actually what the front looked like before:
    pretty ugla, eh?
    So ic cut ut a matchin piece of MDF:
    and milled another few reliefs for that piece:
    and it matched :D
    So then I started tp spachtel
    and this is what it looked like after a lot more hours of grounding and spachteling:
    so far....
    I had the idea of creating a selfmade plugn'energy powersupply but then i got the idea to make an external one, witch means that there will be a piece (MDF) which Ill mount in the back of the case were originally a 120mm fan should be mounted. (I hope ya'll understand this :worried: )
    And this is what my first try looked like:
    But then i decided to do sum more sketching for that one and here they are:
    and an animation :D
    Thats all my work for now, hope ya'll like it :D
    Im forced to stop working until friday next week cuz i have to take care of my turkish exchange student :cooldude:
    mfg, hu$tla
  2. Teyber
    Teyber ******
    18 Mar 2007
    nice man!
    Love it...
    What do you mean by schapnell or whatever you said? is it pudy-ing?
    and when you say mill, are you using a engraving bit on the dremel?
  3. Nsonic
    Nsonic What's a Dremel?
    5 Jun 2007
    Lovely project, Following this one!
    And Nice sketchups also!
    Nsonic
  4. hu$tla
    19 Jun 2007
    thanks guys :D
    yeah with mill i mean using the dremel with this:
    i don't really know the right for that :worried:
    I think I meant spachtel thats the white paste I used for the roughness, I don't know the right expression for that one, too :D
    mfg, hu$tla
  5. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Spackle, or Spackling compound.
    This project is off to a good start. I like the sketch of the fan/power setup.
  6. tolis86
    tolis86 What's a Dremel?
    3 Nov 2006
    thumbs up!!!
  7. Colossous
    Colossous Minimodder
    28 May 2007
    Looking well tasty !! :rock:
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    So the top MDF plate is solid, but is the one below it hollow, to cover the wiring? Love the idea anyway!!
  9. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Looks realy nice !
  10. Particle Man
    Particle Man What's a Dremel?
    9 Jun 2007
    Whats the point of the external power supply plugs? Seems like a cool concept and it looks good, but what exactly do you plan to power?
  11. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    Looking good so far!
    Keep it up!
  12. ice-tea
    ice-tea Mr.PC-Max
    28 Apr 2006
    ... my daily view at the bit-tech.net forum and what did I see? the essential machine from my friend hu$tla from germany :D
    but nice to see the worklog here ;)
    (so und jetzt auf deutsch^^ - in wirklichkeit postest du doch nur hier um die gewinne abzustauben, von denen ich auf exclaim in der news bereichtet habe oder? :D naja wird dir mit dem case auch sicher gelingen)
    keep on modding hu$tla :thumb:
  13. Amon
    Amon inch-perfect
    1 Jun 2007
    What paint was used for this? (colour code, if possible, please) Thanks.
  14. widmod
    widmod Minimodder
    9 Oct 2006
    nice case idea
    german: ja wie wo was gibts hier zu gewinnen, erst mal des case fertigmachen :idea:
  15. Dead Ghost
    Dead Ghost What's a Dremel?
    11 May 2007
    @Amon: I think that's just a primer.
    Anyway, intersting project, good luck.
  16. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    @wid ... einmal in die monatsworklogs reicht fuer nen gewinn ...
  17. Teyber
    Teyber ******
    18 Mar 2007
    maxk shnell!
    ich monatsworkslog reich ICH!
    SHOQUA LA EINMAL!!!
    lol i have no idea what i just said. all you germans: watch this:http://www.youtube.com/watch?v=NpRqvCps_MQ
    sorry for being off topic. Lookin forwards to the next update!
    en engles porfavor.
    Hago razon!
  18. hu$tla
    19 Jun 2007
    hmm, I don't know which one u mean?
    I haven't planned yet what i'll connect to those plugs. The plugs are primary for a good look :D
    ja, in die logs zu kommen, wäre schon nicht schlecht und ich muss gestehen dass ich durch die news erst auf die Idee kam, auch hier mein TB zu posten.
    Aber in erster Linie will will ich den Mod populär machen :D
    it's just primer, but i'll look for a code (if there is one)
    and thanks for the propz :D
    mfg, hu$tla
  19. exitus
    exitus What's a Dremel?
    25 Apr 2007
    @ Hu$tla: lass ihn doch wenn er will ;-)
    on topic: nice work there, i like that red/black theme, very dark and evil at the same time :)
  20. ReFredzRate
    2 Sep 2002
    Hey hu$tla, here's a little explanation.
    You're trying to make kind of a power supply from the two mdf plates. The top plate (1) is solid as far as I can see, but how about the bottom (2) plate? If you're using it to hide wiring, will the bottom plate be hollow?
