Case Mod - In Progress Project Evolution by PEXON. 13th Jan 2K13 - FINAL (nearly) photos!!!!!! OMG1337SAUCE
Discussion in 'Project Logs' started by shrop, 4 Nov 2011.
  1. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Nice one man :thumb:
  2. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Resleeved the pump as it was annoying me, you could see some of the yellow wire through the sleeve. I could have left it but it was niggling me.
    I also sorted out the 24 pin extension as it was also looking a bit rough round the edges. Again it was annoying me, I could have left it, but that's not like me.
    Finally, I got an Alphacool pump top from Specialtech, it really finishes the pump off nicely, the stock D5 isn't exactly a beaut. I've also been wondering, does anyone know if some 3M double sided mounting tape would be sound for mounting the pump?
    Hopefully I should get my new CPU by friday too! So its looking exciting, fingers crossed new GPU next month as well as the last rad, 2 more fans and blocks!
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Come on Come on Come on ! You are nearly done with it :D
    yassarikhan786 likes this.
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I've used 3M double sided tape to mount pumps in the past. Not the best vibration dampener, but they sure stay put.
  5. shrop
    22 Jul 2011
    OK, thanks man, I think I'll give it a miss.
    I know its nearly there! :clap:
  6. shrop
    22 Jul 2011
    3820 and a CPU cooler to get me running for a few weeks have been ordered and should be here tomorrow. Cant wait!!!!!
  7. shrop
    22 Jul 2011
    Little update here... Had a play around with some screws and some spacers to help airflow and noise. Here is how it looks.
    The only thing I'm worried about is getting a card with a longish PCB, due to the pump, which will sit underneath the res. I may have to run the GPU in the second PCI 16x slot. Fingers crossed another big update tomorrow with the i7 2011.
  8. yassarikhan786
    10 Aug 2011
    Rad placement looks rad. C whut I did thur XD?
  9. shrop
    22 Jul 2011
  10. shrop
    22 Jul 2011
    Little video of the rad sandwich... just to test how loud the fans are, I'm pretty happy with the result, even at full whack, the Enermax Clusters don't get too loud. When at their lowest speed, when I'd turn them down when idle, they are nearly in-audible, but still throw out a decent amount of air.
  11. bulldogjeff
    2 Mar 2010
    Silly question time. With the fitting facing each other how are you planning on connecting it all up.
  12. shrop
    22 Jul 2011
    Ive turned it over now. Ill have to have a play with some 90s to get the tubing ran nicely.
  13. bulldogjeff
    2 Mar 2010
    Ah, now that akes a lot more sense now . You havd me worried for a while then..lol :D
  14. shrop
    22 Jul 2011
    I could have fitted a single length of 2 inch ish tubing in betweem the two barbs to connect them and worked some magic with some 90s for the input from the pump and outlet to GPU block mind.
  15. shrop
    22 Jul 2011
    Boom! Got my 2011 kit up and running after a Windows 7 install nightmare...
    And a temporary cooler....
    All ready to go for w/cing! :) Bad news though... :(
  16. shrop
    22 Jul 2011
  17. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Ouch going to have to respray the front , how much lacquer are you using on the panels ? and what caused the ding ? Also the C/F goes well with that Dark met Blue
  18. shrop
    22 Jul 2011
    2 coats. I've T-Cut them too :/
  19. chris8224
    chris8224 What's a Dremel?
    21 Apr 2012
    Them fans are beautiful mate, also liking how its all coming together :)
  20. yassarikhan786
    10 Aug 2011
    Fans look awesome playa :D
