Scratch Build – In Progress Project: Evolutionary
Discussion in 'Project Logs' started by Franklin, 29 Nov 2006.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    It's all handmade. The button is about 6 centimeters. Big I know, but perfekt for this case, that is also big.
    I cut out the opening in the aluminium for the button.
    and with the button in place.
  2. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    All done with a scroll saw? :thumb:
  3. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    Very nice.
    This is probably my favourite project log on B-T right now.
  4. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    uh the button is n1 . i tried something similar myself and kicked it arround the workshop cause i dindt turn out the way i like it
  5. Lupo_IM
    Lupo_IM ItaliaModding staff
    30 Jul 2007
    you're the king of fiber-glass!!! :D great work!!! the button is very very very beautiful!!! ;)
  6. Dira
    Dira What's a Dremel?
    1 Sep 2005
    Hawt!
  7. kimandsally
    kimandsally What's a Dremel?
    28 Jun 2005
    Really nice to see you doing another Franklin, it was your Alumax that had me join Bitech just so I could post on your project log, I read every single part of Alumax and have done this up to here, people like you are an inspiration to us all.
    Really looking forward to following this again.
  8. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    :nono: No no Goodfriend, please dont spam this project log :nono:
  9. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    spam post reported!
  10. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    pwned!!
    Really love how the project is coming along though.
  11. Franklin
    24 Oct 2004
    I bought a 2.1 Philips speakersystem.
    The satellites will be integrated in the case and the subwoofer will get the same look as the case. Before I can mount the satelittes I will have to cut of the feet and cover up the steel fronts with something more suitable for my black case.
    mark the acrylic before cutting it.
    Cut out the circles
    They almost fit, still need a bit of sanding.
    Because of a thunderstorm I had to quit working on the polyester sidepanels. I was bored and used some tape to put some parts onto the frame.
    It far from finished, but just to give you guys an idea of what it will look like.
    Please keep in mind that the case will be painted and that I will add so many details, like windows and decoration.
    I glued in the airducts in the left side panel. Used some heavy materials to press the polyester sheet down.
    Used some bondo to fill up the small gap between the airducts and the sidepanel.
    The airducts themself also need some bondo and I will have to sand them several times.
    I also need another mold, a mold for yet another airduct. It will look like in this sketch.
    The fan will be mounted on the right side and I already made the acrylic to hold the fans. These are two AC Ryan 90mm. fans.
    The duct will be placed over here (one on the left side and one on the right side of the case)
    and the mold is almost finished. Only need to paint, sand, paint, sand and paint it before I can use it.
  12. wbdog206
    wbdog206 not me
    15 Jan 2007
    coming along very nicely.
    good work.
  13. weasal
    weasal What's a Dremel?
    22 Jul 2007
    really like the acrylic fronts for the speakers. cant wait to see the end result
  14. Teyber
    Teyber ******
    18 Mar 2007
    wow.
    If someone can find a cubeloc retailer in the us, i will kiss your feet
  15. THEkorean
    THEkorean 42
    10 Jun 2005
    Nice project!
    What scroll saw blades are you using and where do you get them?
  16. Franklin
    24 Oct 2004
    Normally the blades are used to saw metal.
    First duct is ready. It will be painted black of course.
    This is what will be visible in the endresult. The bottom of the case will be covered with some aluminium later on. The black aluminium plate is still covered with a layer of plastic, I only removed a piece around the fan.
    Underneath the fan you can see an opening, won't be visible in the finished case. This opening is for the dustfilter that will come underneath the intake. It needs to be removable to clean the filter, that's why I cut that opening, so it can slide underneath the intake and back when it needs to be cleaned.
  17. ComputerKing
    8 Sep 2006
    WOW this is nice now I didn't think it will be really
    well done and wait to see more
    Update faster, good luck
  18. Franklin
    24 Oct 2004
    AC Ryan send me a lot of new materials for this casebuild, but not only the acrylic and aluminium comes in handy, but also the cardboard that protects the materials. I made a model from the duct that will guide the air from the intakes on the sidepanel to the radiator.
    And this is what it will look like withe the black aluminium panel, that will divede the front of the case from the two compartments in the back, in place
    From the side, without the sidepanel on, it will look like this.
    With this cardboard model it's easy to see if you missed something and if the thing will fit in there and it does, so it's time to make the same thing from acrylic.
  19. Cheapskate
    13 May 2007
    I know you hear this a lot, but...
    Holy sh*t! That is awesome!:jawdrop:
    Also- Giant on buttons are bad ass! You have made my 1 1/4" marble seem small and Insignificant...:waah:
  20. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    my first post here
    hi all modders
    my first post here..................
    subscribed...........
    this is coming along great,beautiful fiber-glass skills:thumb:........
    Alien
