Scratch Build – In Progress Project: Evolutionary
Discussion in 'Project Logs' started by Franklin, 29 Nov 2006.
  1. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    I agree! This is starting to look like one kick ass case!!!
  2. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    I don't want to hide all the cables like I did in my previous case, but the cables will need to be ordered. That's why I made some cableholders. I used two layers of white aluminium from AC Ryan with some mdf in between. Strange I didn't see anyone use the white aluminium from AC ryan yet. It looks very nice in combination with the black panels.
    I won't use any bolts or glue to mount the holders. I will just slide them in.
    Need these small openings for mounting the cableholders. Just slide it in there.
    and the result
    The black aluminium sheet will divede the left and right compartment of the case.
    In the next picture you can see what the distance is between the hddbox and the cableholders.
    I'm also working on the side panels. Some aluminium profiles will give it some strenght and prevent it from bending.
  3. Guest-23315
    Guest-23315 Guest
    Brilliant as allways Franklin...
  4. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Very nice work. :thumb:
  5. razzta010
    razzta010 mod addict
    9 Aug 2007
    Incredible details you pay attention to. Great mod!
  6. Franklin
    24 Oct 2004
    I mounted the aluminium U-profile to the sidepanels.
    The profiles on the sidepanels fit inside the aluminium frame from the case. I'm happy with the result, it fits very well.
    On both the left and rightside panel I will mount a piece of the airduct.
    When the panels are in place the duct on the sidepanel touches the duct in the case. I will modify the duct inside the case a bit more to make sure there will almost leak no air.
    I'm also working on the two reservoirs I'll use for the watercoolingVerder ben ik de reservoirs aan het maken voor de waterkoeling. Need several circles og acrylic. The small ones will have to fit inside the tube.
    I used a file and some sandingpaper to get the small circles to fit into the acrylic tube. Now I'll need to glue the small and big pieces together.
    Need to file and sand the big circle till it has the same diameter as the tube.
    With the parts in place it's easy to mark acrylic that needs to be filed and sanded away. This one is almost ready.
  7. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    that case is starting took really great ....................:thumb:
    maybe get some Rubber sealing tape like used to seal windows.
    They are availible in a lot of different sizes and colors..................
    Alan
  8. Franklin
    24 Oct 2004
    That's just what I will use, rubber sealing for all the ducts.
    I glued some polyester parts, for mounting the duct to the sidepanel, to the sidepanel.
    Drilled some holes in those pieces to be able to use small bolts.
    All the parts I need to make the shocks, from the harddisk box, function are in now, so I started mounting all the parts to the case. The parts that came in yesterday I will show you in another update. It's something to prevent the harddisk box from flipping over to one side.
    Making some thread for the bolts.
    Ready to mount the part.
    and finished.
    The drivebay is also almost finished. It looks a bit funny, because the top is very small. That's because that's the place for the Aquaero and a VFD and those aren't as big (deep) as a DVD drive.
  9. customh
    customh conflagration.
    22 Oct 2005
    Looks good! It's coming together!!
  10. Franklin
    24 Oct 2004
    Time to work on some parts inside the case. The pump will be placed near to the motherboard. The area around the pump is covered with an black aluminium sheet from AC Ryan.
    The aluminium cover around the pump also comes in handy when I have to hide some cables.
    The pump itself will be covered by its own housing. I used some acrylic piping and cut it in half. This is just the base of the pumphousing, now I can add some more housing parts by glueing it onto this pipe.
    I can finish the construction of the hddbox now, this because of some great help from a company nearby in Eindhoven
    called Nebo http://www.nebobv.nl/
    Now it fits into the pipe.
    I drilled two big holes in the hdd box.
    These holes are there for the acrylic pipe that will go through there. I glued some black acrylic around the pipe. This is needed to attach it to the hdd box with some bolts.
    Couldn't glue it because I will need some space to adjust the construction when needed.
    A quick look underneath the hdd box.
    The two pieces of acrylic that fit into the pipes underneath the hdd box will be mounted on the bottom of the case. To prevent any movement I will use some aluminium profiles underneath the bottom of the case, but this will not be visible. This construction will prevent the box hanging in the rc shocks from flipping to one side.
  11. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Let's see:
    - creative mind ... check
    - crazy and great ideas ... check
    - brilliant execution ... check
    Everything for a really, really great mod is here. :thumb:
  12. wbdog206
    wbdog206 not me
    15 Jan 2007
    very original.
    every new update amazes me.
    first class all the way.
  13. widmod
    widmod Minimodder
    9 Oct 2006
    thats an really outstanding project log
    good ideas and a fine execution :jawdrop:
  14. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    i like that motherboard.
  15. Cheapskate
    13 May 2007
    Those sliding pins look great. It's too bad no one will be able to see them.
    I always loved the look of frosted acrylic.
  16. Franklin
    24 Oct 2004
    Not a very high quality movie, but I didn't want to wait showing the shocks in action. Haven't cleaned the harddiskbox yet and this just is a first test.
    It works!
  17. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Brilliant! :thumb:
  18. customh
    22 Oct 2005
    Looks like it may be a little too stiff and be a little too much connected to the frame to achieve silence, no?
  19. Franklin
    24 Oct 2004
    There is no weight in the box at the moment, because the box is empty. The sound you hear comes from the acrylic stabilizers. When the harddisks are installed I can adjust the shocks.
  20. Franklin
    24 Oct 2004
    Have been working on, what must be one of the last polyester parts, dust filter holders.
    Getting the fibreglass of the mold.
    Marked the part so I know where to cut it.
    Smoothened the edges with some sandingpaper.
    Made an opening in the filter holder.
    Ready to mount it on the aluminium. Used some bolts to do this.
    And from another angle.
    The acrylic part that will hold the filtermaterial can slide in now.
    Made two of these parts, one for the left side and one for the right side of the case. These holders will be mounted underneath the case, so you can't see them.
