Scratch Build – In Progress Project: Evolutionary
Discussion in 'Project Logs' started by Franklin, 29 Nov 2006.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    It will be black and with some nice details. But I'm not sure if I will be able to catch those details with my camera.
  2. Cheapskate
    13 May 2007
    Your poor pump.:D The case is so big it might not want to push coolant that high.:hehe: I can't wait to see this all together.
  3. The boy 4rm oz
    10 Apr 2008
    Perfect as always Franklin.
  4. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    this is too HOT to handle :D keep it up
  5. Franklin
    24 Oct 2004
    I will use some tubes to get some wires for the LEDs, from the bottom of the case to the back.
    As you can see the part I was working on a while ago isn't a fangrill. I filled the gaps with some frosted acrylic and it these spots will spread some light into the case.
  6. Guest-23315
    Guest-23315 Guest
    Amazing as all ways Franklin.
  7. The boy 4rm oz
    10 Apr 2008
    Looks really cool.
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    speechless. Impressive. Love it. 'nuff sed.
  9. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
  10. shaeffer
    shaeffer Houses Are Just Big Cases Right?
    4 Apr 2006
    I like the frame construction - very quick, simple, elegant. Also, the aluminum squares should be useful for hiding un-wanted cables. :D
  11. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    That is one insane case. Amazing job!!! HAX!!!
  12. Cheapskate
    13 May 2007
    1st::jawdrop:Then::eeek:and finally::rock:
    It's a LED array?!?! COOL!!!
    @shaeffer - He doesn't need to cut the frame. He's got the big space between the inner and outer walls.:D
    That freaking awesome wiring bypass is to go around the frame, and look totally slick doing it.
  13. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Someone said that too in the first stage of my casemod, but I found out that's not the easiest way to hide your cables. Being unable to remove parts of the frame was as major reason for that conclusion :hehe:
  14. badje
    badje boni
    30 Oct 2006
    I still like this project, the details are superb!
    How far are you now, like halfway or....?
  15. Franklin
    24 Oct 2004
    I think this case is done for about 60 percent now. Still need to do a lot of work and I don't have much time to work on this case. It needs to be finished before the end of november.
    Applied the first layer of primer and now it's easy to see where I need to add some more bondo. I'm still not satisfied with the result.
    Most of the flat parts are finished now and ready for paint, but the parts like the intakes still need some more bondo and sanding.
  16. The boy 4rm oz
    10 Apr 2008
    As always Franklin you work is top notch.
  17. Franklin
    24 Oct 2004
    Received the first hardware. Because it took me so long to build this case I needed to change the hardware. The old hardware hasn't been thrown away. It's all being used in another computer that I build for my dad.
    The new hardware: a Asus Striker II extreme, a 900 watt Tagan powersupply and 2 GB Corsair ddr3 Dominator memory.
    I need to decide whether I will use the watercooling block on the motherboard. Still not sure, because it looks very flow restrictive. The blue on the Corsair Dominator fans will need to be removed to match my color scheme.
  18. ry@n
    ry@n Minimodder
    31 Aug 2005
    :O :O *fap* acrylic work is awesome, need to see this one complete!
  19. GavX
    GavX What's a Dremel?
    5 Apr 2008
    case is looking fantastic, shame that Saphire motherboard doesn't get to be in it though, but damn, a Striker II and RAM to match? I wouldn't be complaining :D
    This case is looking really good, coming together nice now, the thing is huge! Excelent detail and alot of fresh ideas, good luck getting it done for november!
  20. Gup
    Gup What's a Dremel?
    3 Sep 2007
    Franklin,
    Really a nice project!!..........I like your eye for details and the design!
    Just wondering if your first statement is still true?
    "Some people told me they thought it was easier to mod an existing case then to build one yourself. I think it is easier to build it yourself and to prove it I will start building one"
