Scratch Build – In Progress Project: Evolutionary
Discussion in 'Project Logs' started by Franklin, 29 Nov 2006.
  1. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    That's some killer hardware Franklin!
    As for the NB block...I've heard mixed reviews as far as its reliability. A friend of mine has the same board and his block leaked, but in ASUS's defense, said friend re-pasted everything on the motherboard so who's not to say he didn't damage the block somehow during that process. Personally, I'm a nit-picky perfectionist type of guy and I'd put an aftermarket block on it for no other reason than just to color-match my CPU block... :lol: At least I can say that here and not be labeled 'insane' ...I think :worried:
  2. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Yes this is the right place to say things like that ;) I chose my motherboard because of its color and the position of the connectors and everything, so I think I'm just as 'insane' :hehe:
  3. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    I made a simple housing to mount the harddisks. Just two plates of aluminium and acrylic.
    Now it's time to place the harddisks into the harddisk box, the box with the RC shocks. To prevent the harddisk from sliding in the box I glued some acrylic onto the bottom and to, some sort of rail.
    The harddisks slide in between the acrylic rail and are being stopped at the end by another piece of acrylic.
    From the backside of the case I can slide the harddisk into the box.
    To prevent the harddisk from sliding out again I made something else. Just two acrylic blocks glued onto the acrylic that will cover the backside of the box.
    The acrylic will be mounted with 4 small bolts.
    Need to mount the logo, at the moment it's being kept in place with some sticky tape and need to add some leds on the backside of the logo, so from inside the harddiskbox.
  4. The boy 4rm oz
    10 Apr 2008
    Seriously nice work on the HDD rack. That orange plei grill really ties the whole thing together.
  5. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    nice work on that hdd rack! keep it up dude, good work as always :)
  6. Cheapskate
    13 May 2007
    Are you still using the decorative panel on the HD case? I really liked it.
  7. Franklin
    24 Oct 2004
    No I'm not going to use it Cheapskate.
    Before I start working on the watercooling I needed to test my hardware, but not before I mounted some leds in the harddisk box. I used 18 leds and these leds will shine on the back of the FJW logo. I used some acrylic to guide the wires a bit.
    I needed enough clearance for the harddisk holder, because it needs to slide into the box. On the right side you can see there enough room between the wires/leds and the harddisks.
    The top of the box is mounted with small hexheaded bolts and not glued, because I need to be able to reach the leds in case a led dies and needs to be replaced. The blue you see is from the Tagan powersupply, I need to replace those leds with white ones ofcourse.
    To test the hardware I installed Windows on the Velociraptor harddisk. No problems at all, so I'm ready for the next step, the watercooling setup.
  8. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    that looks soo amazing !!
    but what does FJW stand for ?
    :clap:
  9. Franklin
    24 Oct 2004
    That stands for Franciscus Johannes Wilhelmus. Strange names that you get when being baptised as a baby. I'm a atheist but I'm stuck with those names till I die :eyebrow: But the first letters of those names are perfect as a logo.
  10. Dark~3nergy
    14 Jan 2007
    ok,
    And your 100% right, they look realy good in the logo.
  11. ComputerKing
    8 Sep 2006
    DUDE The HardDisk CAGE ROCKS!!!!! PURE PORN!!! Buddy I really LOVE IT! dam you are doing awesome job here. I can't wait to see more.
    Well Done.
  12. Gott-Maschine
    Gott-Maschine I overheated my dremel and it died.
    16 Aug 2008
    Simply awe inspiring, you got my subscription. Keep up the excellent work.
  13. The boy 4rm oz
    10 Apr 2008
    If anyone doesn't think that looks cool they deserve to be shot.
  14. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Now I'm afraid to say that I don't really like the look of the fan in there :blah:
  15. The boy 4rm oz
    10 Apr 2008
    Don't make me get my gun lol.
  16. Franklin
    24 Oct 2004
    Because I changed my hardware plans, I needed to use a heavier powersupply. The problem was that the cables from the new Tagan PSU are somewhat differently situated on the psu, so I needed to make some new brackets for the cables. This time I used some black anodized aluminium from AC Ryan and transparant orange acrylic, instead of the white sheets I used for the old brackets.
    The cables in the picture above are the standard sleeved Tagan cables, but that will change soon. I will use some tubing to cover them and this will also make it possible to pl;ace the cables in an almost perfect straight line.
    On the left side of the picture you can see 4 cables going through an aluminium sheet. I needed to make holes in the sheet that were big enough to pull the cables through, but that was a problem because that would mean there was a gap between the cables and the holes. So I made an acrylic parts that fits tight around the cables and can be opened on the left and right side to pull the cables through.
  17. Guest-23315
    Guest-23315 Guest
    Fantastic.
    How much more work before you think it'll be finished Franklin?
  18. Franklin
    24 Oct 2004
    Really don't know that. I want to finish it just before december, but there is still a lot of work to do. Painting all the polyester parts, some cablemanagement, installing the watercooling parts and ofcourse some things that are just for the looks. I have got I nice idea how to use the mirror acrylic from AC Ryan :naughty:, the acrylic that you can only see through when there is light behind it.
  19. GavX
    GavX What's a Dremel?
    5 Apr 2008
    wooooo! That is a properly cool HDD rack ya got there, ace work! As said the orange and black really looks the part, looking forward to seeing this done, bets of luck getting it done for xmas time. I haven't seen the ACRyan Mirror used in many mods yet, it does look really cool but prone to smudges and fingerprints. It might tint what is inside too much though obscuring the detail
    Out of interest what do you use to polish your acrylic? After sawing
  20. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    I love the orange grill.. looks so tasty I want to chew on it!! 8D¨ FJW logo and the whole compartment looks fantastic too!!
    I was kind of sad hearing that you will cover the PSU cables with tubing.. I think it looks really good the way it is... don't really understand why, cause it is a mix of colors.. but still I do like it... perhaps I'm just tired. *shrugs* I hope it will look even better with the tubing.
    Keep up the good work!
